Cristi.Radu 0 Posted October 9, 2016 Posted October 9, 2016 (edited) Hello, Yet again a problem with live streaming not starting in Internet Explorer/Chrome on the server computer (didn't try on any clients yet, didn't see the point if it's not working here). I have been struggling with this for several hours maybe some fresh ideas from you guys will be useful. Confirguration: HDHomerun Expand 4 tuner config. Windows 10 64 bit + ServerWMC . Windows Media Center installed and running, Live TV working very well, even better than HDhomerun's own app (switching channels is faster + EPG is available). HDHomerun View app working. Installed the lastest ServerWMC and the previous version as well, same problem. 'Http Service' tab checkboxes - tried all combinations, no difference (apart from getting the channels info). When I hit play on any channel, the 'wait' spinning circle starts rotating and that's all. The relevant error in the emby log: Error HttpServer: Error processing request for /emby/LiveStreams/Open?UserId=91ea7b35259c4d68a59680f35a9a458d&StartTimeTicks=0&ItemId=26fb9ee1b5904973fd90764e4e192912&PlaySessionId=654b6b56d7c84cfdb194357e68622663 *** Error Report *** Version: 3.0.7300.0 Command line: C:\Users\Radu\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Radu\AppData\Roaming\Emby-Server Application Path: C:\Users\Radu\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Object reference not set to an instance of an object. ServiceStack.HttpError No Stack Trace Available InnerException: System.NullReferenceException Object reference not set to an instance of an object. at wmc2mb.WMCService.<GetChannelStream>d__10.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<GetLiveStream>d__3a.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<GetChannelStream>d__23.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvMediaSourceProvider.<OpenMediaSource>d__8.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.Library.MediaSourceManager.<OpenLiveStream>d__3c.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Playback.MediaInfoService.<Post>d__4.MoveNext() Attached the log files for both ServerWMC and Emby. server-63611609426.txt ServerWMC.log Edited October 9, 2016 by Cristi.Radu
krustyreturns 191 Posted October 9, 2016 Posted October 9, 2016 Thanks for that. In the log you posted you have dlna mode turned on for Emby. Not sure if that's the way you want to run or if you were just trying things, but your log showed me that there was a bug in that mode that caused emby to not be able to open the dlna stream. I fixed this now, so look for version 1.0.0.73 of the serverwmc plugin and dlna mode should work for you. As to why it wasn't working when you turned dlna mode off, I can't say since that isn't in the serverwmc log you posted. If that's the way you want to run and it still doesn't work, post the log after trying to start a live stream with dlna turned off for emby.
Cristi.Radu 0 Posted October 10, 2016 Author Posted October 10, 2016 Thank you for your prompt response, I will update the build later today and report on the results.
