jbuyense 0 Posted October 8, 2016 Posted October 8, 2016 I am running Emby Version 3.0.7200.0. I installed the Trailer Plugin but realized it wasn't very usefully unless I was an Emby Premier subscriber. I' tried to uninstall the plugin and restart, but it's still there. Is there a way to manually delete it?? Please help! Thank You! Emby Log.txt
Solution ebr 16340 Posted October 8, 2016 Solution Posted October 8, 2016 Could be a permissions problem of some sort causing the removal to fail but you can simply go into your Plugins folder under your Emby server folder and delete the dll and restart the server.
