inzombyac 69 Posted October 6, 2016 Posted October 6, 2016 (edited) I was re-configuring the guide data as I had changed channel packages. When I went to edit my XMLTV configuration I received an error Alert There was an error adding the lineup to your Schedules Direct account. Schedules Direct only allows a limited number of lineups per account. You may need to log into the Schedules Direct website and remove others listings from your account before proceeeding. Note: Should probably fix that spelling error (proceeeding = > proceeding) I thought that was odd so I deleted the guide configuration and then tried adding a new one. When I try to save the guide configuration, the same error occurs. Log file: https://dl.dropboxusercontent.com/u/9445055/XML_Log.txt Running 3.1.113.0 Edited October 6, 2016 by inzombyac
Solution Luke 42242 Posted October 6, 2016 Solution Posted October 6, 2016 It can't find the file C:\Applications\zap2xml\xmltv.xml It just happens to be displaying the wrong errror message. thanks. 1
inzombyac 69 Posted October 7, 2016 Author Posted October 7, 2016 It can't find the file C:\Applications\zap2xml\xmltv.xml It just happens to be displaying the wrong errror message. thanks. Thanks that did it.
