stettler 31 Posted October 5, 2016 Posted October 5, 2016 Hello, I just tested (quickly) an HDHomeRun. It's working fine but whatever channel I play, there is only one audio/language track listed. Usualy a "Dolby Digital" track for HD channels and a mpeg track for SD when there should be at least 2 or 3 audio stream. I noticed that in the HDHomeRun View software, there is no option to select the audio track so I am wondering if it's normal with HDHR tuners that we get only a single audio track in Emby? (if that's the case, which one it choose??)
stettler 31 Posted October 5, 2016 Author Posted October 5, 2016 To answer my own question: I used VLC to connect to the HDHR and I could see and select the various audio tracks. So there is a bug in Emby that wont let select audio track. 2
stettler 31 Posted October 16, 2016 Author Posted October 16, 2016 Hello, Seems the problem is mostly fixed in Emby 3.0.8100.0: Using ET or the Android app, I can see the various audio stream and subtitles, select them and play them ok. Thank you! But it is still not working with Chromecast: The audio or subtitle buttons are still greyed out in the application (whatever you try to cast from the web app or from android app) so it is still not possible to select the audio track or turn-on subtitle.
Luke 42242 Posted October 16, 2016 Posted October 16, 2016 Thanks for the report. We'll take a look at that.
stettler 31 Posted October 23, 2016 Author Posted October 23, 2016 The audio and subtitle buttons are still not available (greyed out) when casting to a Chromecast in server 3.0.8300.0 So it is still not possible to select the language or the subtitle when using a Chromecast.
