Ability to allow content with certain tags
Hi, I'd like an option in parental control of each user that says Allow content with tags: (similar to how Plex does it) in addition to the existing Block content with tags:
Since I guess these would conflict with each other if used at the same time, I think it'd be great to have a select box where you can choose either option, and then under it a text field to write the tags in, and a note under it saying "Please seperate with commas".
Thanks! :)
Also, am I missing something? Is there no easy way to apply metadata to multiple items at once? Like a tag or a custom rating? It's quite tedious to go through every item individually.
Edited by deanylev
Guest
