brrzba 0 Posted October 3, 2016 Posted October 3, 2016 Hi, I have been fiddling around with this for too long, so here is what I did for all you after me: Activate backported sources Install backported kernel - reboot Install all the packages needed for Hardware Acceleration from backports (perhaps not all of them are neccesary): mesa-va-drivers va-driver-all vainfo i965-va-driver mesa-vdpau-drivers libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa libvdpau-va-gl1 libva-drm1 va-drive vdpau-va-driver libva-intel-drivers libdrm-intel1 DONT use the static ffmpeg build linked somewhere in the install guide. For me it did not work at all. If you did, switch from custom ffmpeg to system installed in your emby interface. Except install ffmpeg from debian backports activate VA-API in emby Thats it, I had very little idea how to do this when I started trying this. As wrongly suggested to me you dont need any xorg stuff. Now we only need this issue fixed in stable Hope I can help someone, also correct me if something is not right here.
brrzba 0 Posted October 3, 2016 Author Posted October 3, 2016 hm, seems I posted that too early. Vaapi transcoding with the exact same command line as in the emby logs works with ffmpeg, but not in emby itself.. It always crashes with something like that in the logs: 2016-10-03 17:28:50.1442 Info App: ffmpeg -ss 00:00:41.219 -fflags +genpts -hwaccel vaapi -hwaccel_output_format vaapi -vaapi_device /dev/dri/renderD128 -i file:"/somemovie.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -force_key_frames "expr:gte(t,n_forced*5)" -vf "format=nv12|vaapi,hwupload" -b:v 1808000 -maxrate 1808000 -bufsize 3616000 -vsync -1 -level 41 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 6 -ab 192000 -af "aresample=async=1" -f mp4 -movflags frag_keyframe+empty_moov -y "/emby/transcode/transcoding-temp/a2b41f3f7b04f453af7b5fd82305bb6f.mp4" 2016-10-03 17:28:50.3279 Info HttpServer: HTTP Response 200 to 192.168.0.210. Time: 222ms. http://server.lan:8096/emby/Videos/a9b589c6898158e98e3c63f242f82fc6/a9b589c6898158e98e3c63f242f82fc6/Subtitles/2/412191150/Stream.vtt 2016-10-03 17:28:51.5252 Info HttpServer: HTTP POST http://server.lan:8096/emby/Sessions/Playing/Stopped. UserAgent: Mozilla/5.0 (X11; Linux x86_64; rv:49.0) Gecko/20100101 Firefox/49.0 2016-10-03 17:28:51.5354 Info App: Stopping ffmpeg process with q command for /emby/transcode/transcoding-temp/a2b41f3f7b04f453af7b5fd82305bb6f.mp4 2016-10-03 17:28:51.5913 Error ServiceStackHost: Error occured while Processing Request: Unable to write data to the transport connection: The socket has been shut down. *** Error Report *** Version: 3.0.7300.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.7.0.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.4.2 (Stable 4.4.2.11/f72fe45 Tue Aug 30 15:47:09 UTC 2016) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Unable to write data to the transport connection: The socket has been shut down. System.IO.IOException at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) <0x41df1a80 + 0x0027b> in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) <0x41df19d0 + 0x0008f> in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) <0x41df0880 + 0x001c3> in <filename unknown>:0 at ServiceStack.Formats.HtmlFormat.SerializeToStream (IRequest req, System.Object response, IResponse res) <0x420cca60 + 0x00cd8> in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteErrorToResponse (IResponse httpRes, IRequest httpReq, System.String contentType, System.String operationName, System.String errorMessage, System.Exception ex, Int32 statusCode) <0x420e47e0 + 0x00213> in <filename unknown>:0 at ServiceStack.ServiceStackHost.HandleUncaughtException (IRequest httpReq, IResponse httpRes, System.String operationName, System.Exception ex) <0x420e46a0 + 0x0011f> in <filename unknown>:0 at ServiceStack.HostContext.RaiseAndHandleUncaughtException (IRequest httpReq, IResponse httpRes, System.String operationName, System.Exception ex) <0x420e4500 + 0x00077> in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.HandleResponseWriteException (System.Exception originalEx, IRequest request, IResponse response, System.String defaultContentType) <0x420e42e0 + 0x0005b> in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal+<WriteToResponse>d__6.MoveNext () <0x41deb520 + 0x018af> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x7f9ee11bd2a0 + 0x00029> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x7f9ee11bb170 + 0x000a7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x7f9ee11bb0f0 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x7f9ee11bb0a0 + 0x0003a> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x7f9ee14b1140 + 0x00012> 25569 in <filename unknown>:0 at ServiceStack.Host.RestHandler+<ProcessRequestAsync>d__13.MoveNext () <0x41dda6b0 + 0x011b7> in <filename unknown>:0 InnerException: System.Net.Sockets.SocketException The socket has been shut down at System.Net.Sockets.Socket.Send (System.Byte[] buffer, Int32 offset, Int32 size, SocketFlags flags) <0x41df1e70 + 0x000e3> in <filename unknown>:0 at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) <0x41df1a80 + 0x000b3> in <filename unknown>:0 2016-10-03 17:28:51.5913 Info HttpServer: HTTP Response 500 to 192.168.0.210. Time: 1488ms (slow). http://server.lan:8096/emby/videos/a9b589c6898158e98e3c63f242f82fc6/stream.mp4?DeviceId=159981806e8d66a50688bc9eb941f09bd5172e1a&MediaSourceId=a9b589c6898158e98e3c63f242f82fc6&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1808000&AudioBitrate=192000&MaxAudioChannels=6&StartTimeTicks=412191150&Level=41&Profile=high&PlaySessionId=6aeee5b6d9a348ac95d42a570675805e&CopyTimestamps=false&EnableSubtitlesInManifest=false&Tag=04ad89f62440722c7cd64f762aad5f07 Any Ideas?
Luke 42244 Posted October 3, 2016 Posted October 3, 2016 That generally means the client video player disconnected because it saw something it didn't like.
brrzba 0 Posted October 4, 2016 Author Posted October 4, 2016 (edited) So what can I do to fix this? Open an issue on github for that? As I said ffmpeg is trasncoding the files with the exact same command, and vaapi is beeing used for that. Could it be my browser? Edited October 4, 2016 by brrzba
brrzba 0 Posted October 5, 2016 Author Posted October 5, 2016 I did, it is working flawlessly, the thing is I need Hardware Acceleration for transcoding 1080p movies, my CPU alone is too weak for that. But I guess I have to decide.. Either beeing able to watch most of the movies, not the 1080p ones I have to transcode, or beeing able to play some of them, but not all because it seems that not all codecs are supported with VAAPI. Or is there something else I could do?
mastrmind11 722 Posted October 5, 2016 Posted October 5, 2016 I did, it is working flawlessly, the thing is I need Hardware Acceleration for transcoding 1080p movies, my CPU alone is too weak for that. But I guess I have to decide.. Either beeing able to watch most of the movies, not the 1080p ones I have to transcode, or beeing able to play some of them, but not all because it seems that not all codecs are supported with VAAPI. Or is there something else I could do? Install Ubuntu 16.04 instead of Debian and the ffmpeg build from the other post about vaapi. It works great in that distro.
brrzba 0 Posted October 5, 2016 Author Posted October 5, 2016 Install Ubuntu 16.04 instead of Debian and the ffmpeg build from the other post about vaapi. It works great in that distro. I have some other services running on this server, so I cant just switch OS, but perhaps I can run Ubuntu inside of an container. Or the more important question would be, can I have vaapi support inside of that container? Will try that eventually By other ffmpeg build you mean this? https://johnvansickle.com/ffmpeg/ Thank you anyways!
mastrmind11 722 Posted October 5, 2016 Posted October 5, 2016 I have some other services running on this server, so I cant just switch OS, but perhaps I can run Ubuntu inside of an container. Or the more important question would be, can I have vaapi support inside of that container? Will try that eventually By other ffmpeg build you mean this? https://johnvansickle.com/ffmpeg/ Thank you anyways! No, the one mentioned here: http://ubuntuhandbook.org/index.php/2016/09/install-ffmpeg-3-1-ubuntu-16-04-ppa/
