ads 2 Posted October 3, 2016 Posted October 3, 2016 Hi Guys Finally ordered a hdhomerun and the media center is being turned off. This means that my Fire TV becomes the default. Looking to really streamline the process as much as possible regarding remote handling I really happy with content with Amazon and can see myself switching from amazon into the emby app and back again alot Wondering if its possible to switch by shortcut into the emby app (back and forth would be cool) using a harmony remote (have a flirc plugged in) Thanks
ebr 16337 Posted October 3, 2016 Posted October 3, 2016 Hi. I don't think there is any way to setup remote shortcuts on the Fire TV like that. The only thing I can think of for you to do is try going "home" from Emby and then doing your Amazon stuff and then try backing your way back to Emby. I'm not positive that will work in all situations but it may in some.
jonours 3 Posted October 4, 2016 Posted October 4, 2016 (edited) I haven't tried but this may work. How to launch Kodi (or any app) by double pressing the HOME button http://www.aftvnews.com/how-to-launch-kodi-or-any-app-by-double-pressing-the-home-button/ Edited October 4, 2016 by jonours
theniteow1 25 Posted October 5, 2016 Posted October 5, 2016 (edited) I haven't tried but this may work. How to launch Kodi (or any app) by double pressing the HOME button http://www.aftvnews.com/how-to-launch-kodi-or-any-app-by-double-pressing-the-home-button/ Just FYI FireStarter no longer works with FireTV. Amazon successfully made it obsolete, so much so the author had abandoned the original intention of the app sadly. http://www.aftvnews.com/amazon-essentially-declares-war-on-alternate-fire-tv-launchers-that-replace-the-default-home-screen/ Edited October 5, 2016 by theniteow1
ads 2 Posted October 7, 2016 Author Posted October 7, 2016 That is a shame, as this would exactly be what i am looking for Any other apps able to do the same thing with the home button?
theniteow1 25 Posted October 7, 2016 Posted October 7, 2016 That is a shame, as this would exactly be what i am looking for Any other apps able to do the same thing with the home button? Not that I've seen without rooting it, which I'm always nervous to do. Hopefully some genius comes up with something.
