b0mb 36 Posted October 2, 2016 Posted October 2, 2016 Hi! When i start my NUC with libreelec jarvis build it starts my NAS with OMV which needs about 60 seconds before its up and running. Now i did try to login via emby connect .... i´ve set the emby addon to a 75 seconds timeout before trying to connect btw since i´ve tried connecting to my server via emby connect i get the emby connect login screen where i have to ender my username und password. i can skip this choosing cancel but i what to tun it off completely. I´ve already set the connection method in the kodi addon from emby connect to manual, so does some1 have any advice for me? thanks in advance! b0mb
Angelblue05 4132 Posted October 2, 2016 Posted October 2, 2016 How did you set this timeout? Was it in the addon settings > advanced? It should prevent the addon from even being started... if that isn't happening the post your Kodi log. Thanks
b0mb 36 Posted October 2, 2016 Author Posted October 2, 2016 How did you set this timeout? Was it in the addon settings > advanced? It should prevent the addon from even being started... if that isn't happening the post your Kodi log. Thanks i´ve set the timeout in the addon and it starts after 75 seconds - that´s ok but i also get the emby connect screen after 75 seconds - this would also be no problem if the addon would remember my username and pw
Angelblue05 4132 Posted October 2, 2016 Posted October 2, 2016 That's not supposed to happen, please post your Kodi log, thanks.
b0mb 36 Posted October 2, 2016 Author Posted October 2, 2016 That's not supposed to happen, please post your Kodi log, thanks.OK... I'll try to post later when I find some time... Family first now ;-) Gesendet von meinem LG-D855 mit Tapatalk
b0mb 36 Posted October 3, 2016 Author Posted October 3, 2016 (edited) it doesn´t matter whether i connect manual or using emby connect ... problem appeard first time with one of the last addon updates 13:25:13 T:140525574498368 NOTICE: special://profile/ is mapped to: special://masterprofile/ 13:25:13 T:140525574498368 NOTICE: ----------------------------------------------------------------------- 13:25:13 T:140525574498368 NOTICE: Starting Kodi (16.1 Git:c327c53). Platform: Linux x86 64-bit 13:25:13 T:140525574498368 NOTICE: Using Release Kodi x64 build 13:25:13 T:140525574498368 NOTICE: Kodi compiled Jun 22 2016 by GCC 5.3.0 for Linux x86 64-bit version 4.4.13 (263181) 13:25:13 T:140525574498368 NOTICE: Running on LibreELEC (official) - Version: 7.0.2, kernel: Linux x86 64-bit version 4.4.13 13:25:13 T:140525574498368 NOTICE: FFmpeg version: 2.8.6 13:25:13 T:140525574498368 NOTICE: WARNING: unsupported ffmpeg version detected 13:25:13 T:140525574498368 NOTICE: Host CPU: Intel(R) Pentium(R) CPU N3700 @ 1.60GHz, 4 cores available 13:25:13 T:140525574498368 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi 13:25:13 T:140525574498368 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi 13:25:13 T:140525574498368 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata 13:25:13 T:140525574498368 NOTICE: special://home/ is mapped to: /storage/.kodi 13:25:13 T:140525574498368 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp 13:25:13 T:140525574498368 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin 13:25:13 T:140525574498368 NOTICE: Local hostname: LibreELEC 13:25:13 T:140525574498368 NOTICE: Log File is located: /storage/.kodi/temp/kodi.log 13:25:13 T:140525574498368 NOTICE: ----------------------------------------------------------------------- 13:25:13 T:140525574498368 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files 13:25:13 T:140525574498368 NOTICE: load settings... 13:25:13 T:140525574498368 NOTICE: Found 2 Lists of Devices 13:25:13 T:140525574498368 NOTICE: Enumerated ALSA devices: 13:25:13 T:140525574498368 NOTICE: Device 1 13:25:13 T:140525574498368 NOTICE: m_deviceName : @ 13:25:13 T:140525574498368 NOTICE: m_displayName : Default (HDA Intel PCH ALC283 Analog) 13:25:13 T:140525574498368 NOTICE: m_displayNameExtra: 13:25:13 T:140525574498368 NOTICE: m_deviceType : AE_DEVTYPE_PCM 13:25:13 T:140525574498368 NOTICE: m_channels : FL,FR,BL,BR 13:25:13 T:140525574498368 NOTICE: m_sampleRates : 48000 13:25:13 T:140525574498368 NOTICE: m_dataFormats : AE_FMT_S32NE 13:25:13 T:140525574498368 NOTICE: Device 2 13:25:13 T:140525574498368 NOTICE: m_deviceName : @:CARD=PCH,DEV=0 13:25:13 T:140525574498368 NOTICE: m_displayName : HDA Intel PCH 13:25:13 T:140525574498368 NOTICE: m_displayNameExtra: ALC283 Analog 13:25:13 T:140525574498368 NOTICE: m_deviceType : AE_DEVTYPE_PCM 13:25:13 T:140525574498368 NOTICE: m_channels : FL,FR,BL,BR 13:25:13 T:140525574498368 NOTICE: m_sampleRates : 48000 13:25:13 T:140525574498368 NOTICE: m_dataFormats : AE_FMT_S32NE 13:25:13 T:140525574498368 NOTICE: Device 3 13:25:13 T:140525574498368 NOTICE: m_deviceName : iec958:CARD=PCH,DEV=0 13:25:13 T:140525574498368 NOTICE: m_displayName : HDA Intel PCH 13:25:13 T:140525574498368 NOTICE: m_displayNameExtra: ALC283 Digital S/PDIF 13:25:13 T:140525574498368 NOTICE: m_deviceType : AE_DEVTYPE_IEC958 13:25:13 T:140525574498368 NOTICE: m_channels : FL,FR 13:25:13 T:140525574498368 NOTICE: m_sampleRates : 44100,48000,88200,96000,192000 13:25:13 T:140525574498368 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE 13:25:13 T:140525574498368 NOTICE: Device 4 13:25:13 T:140525574498368 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0 13:25:13 T:140525574498368 NOTICE: m_displayName : HDA Intel PCH 13:25:13 T:140525574498368 NOTICE: m_displayNameExtra: MJI marantz-AVR on HDMI 13:25:13 T:140525574498368 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 13:25:13 T:140525574498368 NOTICE: m_channels : FL,FR,LFE,FC,BL,BR,BC,BLOC,BROC 13:25:13 T:140525574498368 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000 13:25:13 T:140525574498368 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_DTSHD,AE_FMT_EAC3,AE_FMT_TRUEHD,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_AAC 13:25:13 T:140525574498368 NOTICE: Enumerated PULSE devices: 13:25:13 T:140525574498368 NOTICE: Device 1 13:25:13 T:140525574498368 NOTICE: m_deviceName : Default 13:25:13 T:140525574498368 NOTICE: m_displayName : Default 13:25:13 T:140525574498368 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO) 13:25:13 T:140525574498368 NOTICE: m_deviceType : AE_DEVTYPE_PCM 13:25:13 T:140525574498368 NOTICE: m_channels : FL,FR 13:25:13 T:140525574498368 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000 13:25:13 T:140525574498368 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT 13:25:13 T:140525574498368 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml 13:25:13 T:140525574498368 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are... <?xml version="1.0" encoding="UTF-8" ?> <advancedsettings> <showexitbutton>false</showexitbutton> <cputempcommand>cputemp</cputempcommand> <gputempcommand>gputemp</gputempcommand> <video> <latency> <delay>0</delay> <refresh> <min>23</min> <max>24</max> <delay>175</delay> </refresh> </latency> <busydialogdelayms>750</busydialogdelayms> </video> <samba> <clienttimeout>30</clienttimeout> </samba> <network> <readbufferfactor>4.0</readbufferfactor> </network> </advancedsettings> 13:25:13 T:140525574498368 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml) 13:25:13 T:140525574498368 NOTICE: Default DVD Player: dvdplayer 13:25:13 T:140525574498368 NOTICE: Default Video Player: dvdplayer 13:25:13 T:140525574498368 NOTICE: Default Audio Player: paplayer 13:25:13 T:140525574498368 NOTICE: Disabled debug logging due to GUI setting. Level 0. 13:25:13 T:140525574498368 NOTICE: Log level changed to "LOG_LEVEL_NORMAL" 13:25:13 T:140525574498368 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml 13:25:13 T:140525574498368 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml. 13:25:13 T:140525574498368 NOTICE: Loaded playercorefactory configuration 13:25:13 T:140525574498368 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml. 13:25:13 T:140525574498368 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping. 13:25:13 T:140525574498368 NOTICE: Running database version Addons20 13:25:13 T:140525574498368 NOTICE: ADDONS: Using repository repository.xbmc.org 13:25:13 T:140525574498368 NOTICE: ADDONS: Using repository repository.emby.kodi 13:25:13 T:140525574498368 NOTICE: ADDONS: Using repository repository.membrane 13:25:13 T:140525574498368 NOTICE: ADDONS: Using repository repository.aeon.nox.silvo 13:25:13 T:140525574498368 NOTICE: ADDONS: Using repository repository.beta.emby.kodi 13:25:13 T:140525574498368 NOTICE: ADDONS: Using repository repository.libreelec.tv 13:25:13 T:140525574498368 NOTICE: Setup SDL 13:25:13 T:140525574498368 NOTICE: Checking resolution 16 13:25:13 T:140525574498368 NOTICE: Using visual 0x20 13:25:13 T:140525574498368 NOTICE: GL_VENDOR = Intel Open Source Technology Center 13:25:13 T:140525574498368 NOTICE: GL_RENDERER = Mesa DRI Intel(R) HD Graphics (Cherryview) 13:25:13 T:140525574498368 NOTICE: GL_VERSION = 3.0 Mesa 11.2.0 13:25:13 T:140525574498368 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30 13:25:13 T:140525574498368 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_texture_compression_bptc GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shader_image_load_store GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_framebuffer_no_attachments GL_ARB_invalidate_subdata GL_ARB_program_interface_query GL_ARB_shader_image_size GL_ARB_shader_storage_buffer_object GL_ARB_stencil_texturing GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_shader_draw_parameters GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_derivative_control GL_ARB_get_texture_sub_image GL_ARB_pipeline_statistics_query GL_ARB_shader_texture_image_samples GL_ARB_texture_barrier GL_EXT_polygon_offset_clamp GL_KHR_context_flush_control GL_ARB_shader_clock GL_EXT_shader_samples_identical 13:25:14 T:140525574498368 NOTICE: Running database version Addons20 13:25:14 T:140525574498368 NOTICE: Running database version ViewModes6 13:25:14 T:140525574498368 NOTICE: Running database version Textures13 13:25:14 T:140525574498368 NOTICE: Running database version MyMusic56 13:25:14 T:140525574498368 NOTICE: Running database version MyVideos99 13:25:14 T:140525574498368 NOTICE: Running database version TV29 13:25:14 T:140525574498368 NOTICE: Running database version Epg11 13:25:14 T:140525574498368 NOTICE: start dvd mediatype detection 13:25:16 T:140525574498368 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList" 13:25:16 T:140525574498368 NOTICE: ActiveAE DSP - starting 13:25:16 T:140525574498368 NOTICE: initialize done 13:25:16 T:140525574498368 NOTICE: Running the application... 13:25:16 T:140525574498368 WARNING: Skin has invalid include: 13:25:16 T:140525574498368 WARNING: Label Formating: $VAR[WeatherFanArtSingleImage_Current] is not defined 13:25:17 T:140525574498368 NOTICE: starting zeroconf publishing 13:25:17 T:140525574498368 NOTICE: WebServer: Started the webserver 13:25:17 T:140525574498368 NOTICE: starting upnp client 13:25:17 T:140523318789888 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777 13:25:17 T:140523318789888 NOTICE: UDP: Listening on port 9777 13:25:17 T:140524417709824 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15) 13:25:17 T:140525373982464 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Starting NextUp Service 13:25:17 T:140525373982464 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> ======== START NEXTUP SERVICE NOTIFICATION ======== 13:25:17 T:140525373982464 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> KODI Version: 16.1 Git:c327c53 13:25:17 T:140525373982464 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> NEXTUP SERVICE NOTIFICATION Version: 1.0.25 13:25:17 T:140525373982464 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Platform: Linux/RPi 13:25:17 T:140525013296896 NOTICE: script.grab.fanart: Grab Fanart Service Started 13:25:18 T:140524392531712 NOTICE: ## LibreELEC Addon ## 0.7.3 13:25:18 T:140524392531712 WARNING: CSkinInfo: failed to load skin settings 13:25:18 T:140524979726080 NOTICE: Skin Helper Service --> skin helper service version 1.0.109 started 13:25:18 T:140524979726080 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307 13:25:18 T:140524996511488 NOTICE: EMBY.service -> Delaying emby startup by: 0 sec... 13:25:19 T:140524996511488 NOTICE: EMBY.service_entry -> ======== START EMBY ======== 13:25:19 T:140524996511488 NOTICE: EMBY.service_entry -> Python Version: 2.7.11 (default, Jun 22 2016, 19:52:26) [GCC 5.3.0] 13:25:19 T:140524996511488 NOTICE: EMBY.service_entry -> Platform: Linux 13:25:19 T:140524996511488 NOTICE: EMBY.service_entry -> KODI Version: 16.1 Git:c327c53 13:25:19 T:140524996511488 NOTICE: EMBY.service_entry -> EMBY Version: 2.2.38 13:25:19 T:140524996511488 NOTICE: EMBY.service_entry -> Using plugin paths: False 13:25:19 T:140524996511488 NOTICE: EMBY.service_entry -> Log Level: 1 13:25:19 T:140524996511488 NOTICE: EMBY.videonodes -> Clearing nodes properties. 13:25:19 T:140524996511488 NOTICE: EMBY.kodimonitor -> Kodi monitor started 13:25:19 T:140524996511488 NOTICE: EMBY.clientinfo -> DeviceId loaded: 55B73F6418E94592936A991D1845D6FC 13:25:19 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin ConnectionManager constructor 13:25:19 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin connect 13:25:19 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin getAvailableServers 13:25:19 T:140524996511488 NOTICE: EMBY.credentials -> credentials initialized with: {u'ConnectUserId': None, u'ConnectAccessToken': None, u'Servers': [{u'LocalAddress': u'http://192.168.178.28:8096', u'Name': u'Emby_b0mb', u'AccessToken': u'bc94e534bfd1491bac1b137982565779', u'RemoteAddress': u'http://178.201.101.129:8096', u'UserId': u'bb256b34b63c49f8af84204549c38926', u'WakeOnLanInfos': [{u'MacAddress': u'E8-39-35-23-31-74'}], u'ManualAddress': u'http://192.168.178.28:8096', u'DateLastAccessed': u'2016-10-03T12:36:52Z', u'LastConnectionMode': 2, u'Id': u'587bf8d35260417db06071d06c915595', u'Users': [{u'IsSignedInOffline': True, u'Id': u'bb256b34b63c49f8af84204549c38926'}]}]} 13:25:19 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin getConnectServers 13:25:19 T:140524409317120 NOTICE: [Artist Slideshow] script version 2.0.3 started 13:25:19 T:140524409317120 NOTICE: [Artist Slideshow] debug logging set to false 13:25:20 T:140524996511488 NOTICE: EMBY.connectionmanager -> Found Servers: [] 13:25:20 T:140524988118784 WARNING: CPythonInvoker(19): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version. 13:25:20 T:140524996511488 NOTICE: EMBY.credentials -> credentialsupdated 13:25:20 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin connectToServers, with 1 servers 13:25:20 T:140524996511488 NOTICE: EMBY.connectionmanager -> begin connectToServer 13:25:20 T:140524996511488 NOTICE: EMBY.connectionmanager -> beginning connection tests 13:25:20 T:140524996511488 NOTICE: EMBY.connectionmanager -> testing connection mode 2 with server Emby_b0mb 13:25:20 T:140524996511488 NOTICE: EMBY.connectionmanager -> tryConnect url: http://192.168.178.28:8096/emby/system/info/public 13:25:23 T:140524996511488 NOTICE: EMBY.connectionmanager -> ERROR:: HTTPConnectionPool(host='192.168.178.28', port=8096): Max retries exceeded with url: /emby/system/info/public (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x7fce194903d0>: Failed to establish a new connection: [Errno 113] No route to host',)) 13:25:23 T:140524996511488 NOTICE: EMBY.connectionmanager -> ERROR:: test failed for connection mode 2 with server Emby_b0mb 13:25:23 T:140524996511488 NOTICE: EMBY.connectionmanager -> skipping LocalAddress test because it is the same as ManualAddress 13:25:23 T:140524996511488 NOTICE: EMBY.connectionmanager -> skipping test at index: 1 13:25:23 T:140524996511488 NOTICE: EMBY.connectionmanager -> testing connection mode 1 with server Emby_b0mb 13:25:23 T:140524996511488 NOTICE: EMBY.connectionmanager -> tryConnect url: http://xxx.xxx.xxx.xxx.:8096/emby/system/info/public 13:25:26 T:140524996511488 NOTICE: EMBY.connectionmanager -> ERROR:: HTTPConnectionPool(host='xxx.xxx.xxx.xxx', port=8096): Max retries exceeded with url: /emby/system/info/public (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x7fce1a146dd0>: Failed to establish a new connection: [Errno 113] No route to host',)) 13:25:26 T:140524996511488 NOTICE: EMBY.connectionmanager -> ERROR:: test failed for connection mode 1 with server Emby_b0mb 13:25:26 T:140524996511488 NOTICE: EMBY.connectionmanager -> Tested all connection modes. Failing server connection. 13:25:26 T:140524996511488 NOTICE: EMBY.connectionmanager -> resolving connectToServers with result['State']: {'ConnectUser': None, 'State': 4} 13:25:26 T:140524996511488 NOTICE: EMBY.connectmanager -> Started with: {'ConnectUser': None, 'State': 4} 13:25:26 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin connect 13:25:26 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin getAvailableServers 13:25:26 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin getConnectServers 13:25:27 T:140524996511488 NOTICE: EMBY.connectionmanager -> Found Servers: [] 13:25:27 T:140524996511488 NOTICE: EMBY.credentials -> credentialsupdated 13:25:27 T:140524996511488 NOTICE: EMBY.connectionmanager -> Begin connectToServers, with 1 servers 13:25:27 T:140524996511488 NOTICE: EMBY.connectionmanager -> begin connectToServer 13:25:27 T:140524996511488 NOTICE: EMBY.connectionmanager -> beginning connection tests 13:25:27 T:140524996511488 NOTICE: EMBY.connectionmanager -> testing connection mode 2 with server Emby_b0mb 13:25:27 T:140524996511488 NOTICE: EMBY.connectionmanager -> tryConnect url: http://192.168.178.28:8096/emby/system/info/public 13:25:29 T:140524996511488 NOTICE: EMBY.connectionmanager -> ERROR:: HTTPConnectionPool(host='192.168.178.28', port=8096): Max retries exceeded with url: /emby/system/info/public (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x7fce071f9090>: Failed to establish a new connection: [Errno 113] No route to host',)) 13:25:29 T:140524996511488 NOTICE: EMBY.connectionmanager -> ERROR:: test failed for connection mode 2 with server Emby_b0mb 13:25:29 T:140524996511488 NOTICE: EMBY.connectionmanager -> skipping LocalAddress test because it is the same as ManualAddress 13:25:29 T:140524996511488 NOTICE: EMBY.connectionmanager -> skipping test at index: 1 13:25:29 T:140524996511488 NOTICE: EMBY.connectionmanager -> testing connection mode 1 with server Emby_b0mb 13:25:29 T:140524996511488 NOTICE: EMBY.connectionmanager -> tryConnect url: http://xxx.xxx.xxx.xxx:8096/emby/system/info/public 13:25:32 T:140524996511488 NOTICE: EMBY.connectionmanager -> ERROR:: HTTPConnectionPool(host='xxx.xxx.xxx.xxx', port=8096): Max retries exceeded with url: /emby/system/info/public (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x7fce0662d2d0>: Failed to establish a new connection: [Errno 113] No route to host',)) 13:25:32 T:140524996511488 NOTICE: EMBY.connectionmanager -> ERROR:: test failed for connection mode 1 with server Emby_b0mb 13:25:32 T:140524996511488 NOTICE: EMBY.connectionmanager -> Tested all connection modes. Failing server connection. 13:25:32 T:140524996511488 NOTICE: EMBY.connectionmanager -> resolving connectToServers with result['State']: {'ConnectUser': None, 'State': 4} 13:25:32 T:140524996511488 WARNING: CSkinInfo: failed to load skin settings 13:25:44 T:140524996511488 NOTICE: EMBY.initialsetup -> ERROR:: No server selected Traceback (most recent call last): File "/storage/.kodi/addons/plugin.video.emby/resources/lib/initialsetup.py", line 114, in _user_identification server = self.connectmanager.select_servers() File "/storage/.kodi/addons/plugin.video.emby/resources/lib/connectmanager.py", line 113, in select_servers raise RuntimeError("No server selected") RuntimeError: No server selected 13:25:44 T:140524996511488 NOTICE: EMBY.downloadutils -> ERROR:: Server unreachable at: http://192.168.178.28:8096/emby/Users/Public?format=json 13:25:44 T:140524996511488 NOTICE: EMBY.service_entry -> Server is offline 13:26:39 T:140524996511488 NOTICE: EMBY.downloadutils -> ERROR:: === Bad status response: 503 === 13:26:52 T:140524996511488 NOTICE: Previous line repeats 7 times. 13:26:52 T:140524996511488 NOTICE: EMBY.service_entry -> Server is online and ready 13:26:52 T:140524988118784 NOTICE: EMBY.userclient -> ----====# Starting UserClient #====---- 13:26:53 T:140524996511488 NOTICE: EMBY.service_entry -> Not authenticated yet. 13:27:06 T:140524988118784 NOTICE: EMBY.downloadutils -> requests session started on: http://192.168.178.28:8096 13:27:13 T:140523302004480 NOTICE: EMBY.librarysync -> ---===### Starting LibrarySync ###===--- 13:27:13 T:140525021689600 NOTICE: EMBY.websocket_client -> websocket url: ws://192.168.178.28:8096?api_key=xxx&deviceId=xxx 13:27:13 T:140525021689600 NOTICE: EMBY.websocket_client -> ----===## Starting WebSocketClient ##===---- 13:27:13 T:140523302004480 NOTICE: EMBY.librarysync -> current: 2.2.38 minimum: 1.1.63 13:27:13 T:140523302004480 NOTICE: EMBY.librarysync -> Database version: 2.2.38 13:27:13 T:140523302004480 NOTICE: EMBY.librarysync -> SyncDatabase (started) 13:27:15 T:140524988118784 NOTICE: EMBY.userclient -> current user: b0mb 13:27:15 T:140524988118784 NOTICE: EMBY.userclient -> current userid: bb256b34b63c49f8af84204549c38926 13:27:21 T:140523302004480 NOTICE: EMBY.librarysync -> Sorted views: [u'Live-TV', u'Movies', u'REMUXES', u'HEVC', u'Motti', u'Serien', u'Dokus_Serien'] 13:27:21 T:140523302004480 NOTICE: EMBY.videonodes -> Clearing nodes properties. 13:27:22 T:140525021689600 NOTICE: EMBY.downloadutils -> SessionId: 5f8275be8646de2c02c07c4bd2b1e609 13:27:22 T:140525021689600 NOTICE: EMBY.downloadutils -> List of permanent users added to the session: ['b0mb'] 13:27:22 T:140525021689600 NOTICE: EMBY.downloadutils -> ERROR:: === Bad status response: 400 === 13:27:22 T:140523302004480 NOTICE: EMBY.librarysync -> Removing views: [] 13:27:22 T:140523302004480 NOTICE: EMBY.librarysync -> Commit successful. 13:27:22 T:140523302004480 NOTICE: EMBY.librarysync -> Last sync run: 2016-10-03 10:08:30 13:27:22 T:140523302004480 NOTICE: EMBY.librarysync -> RetentionDateTime: 1900-01-01 00:00:00 13:27:22 T:140525021689600 NOTICE: EMBY.websocket_client -> Message: {"MessageType":"ScheduledTaskEnded","Data":{"StartTimeUtc":"2016-10-03T11:30:38.5453130Z","EndTimeUtc":"2016-10-03T11:31:10.8341050Z","Status":"Completed","Name":"Check for application updates","Key":"SystemUpdateTask","Id":"7717368eb904db8e2522240726ba251a"}} 13:27:24 T:140523302004480 NOTICE: EMBY.librarysync -> Fast sync changes: {u'FoldersAddedTo': [], u'UserDataChanged': [], u'ItemsRemoved': [], u'ItemsUpdated': [], u'FoldersRemovedFrom': [], u'ItemsAdded': []} 13:27:24 T:140523302004480 NOTICE: EMBY.librarysync -> SyncDatabase (finished in: 0:00:10) True 13:27:56 T:140525574498368 NOTICE: NFS is idle. Closing the remaining connections. Edited October 3, 2016 by b0mb
Angelblue05 4132 Posted October 3, 2016 Posted October 3, 2016 Thanks, I'll look into it. Thanks for helping test beta and the new login system. I'll let you know once I got something for you to test.
b0mb 36 Posted October 3, 2016 Author Posted October 3, 2016 thak u for your work on this it seems like the timeout is beeing skipped. it would be also gr8 if you could make it configurable that the addon checks at startup if the server is already running or not. in case of that the server is up the timeout can be skipped.... 1
Angelblue05 4132 Posted October 3, 2016 Posted October 3, 2016 It does. That's the whole point of testing if the public page for your server is reachable. Something else is the matter.
Angelblue05 4132 Posted October 4, 2016 Posted October 4, 2016 @@b0mb I fixed this for the next beta. However, I do not understand what timeout you are changing. Please do not change the code itself. There is an option in the add-on settings that will delay when the add-on actually starts in Kodi. This is where you need to apply your 75 seconds. Head over to the add-on settings > advanced > Delay startup and enter 75. This should automatically fix your issue, as I have no idea what timeout you are referring to, I'm starting to think you are playing with the code in downloadutils.py to fix this, which it wont.
b0mb 36 Posted October 4, 2016 Author Posted October 4, 2016 (edited) Nah.... I just chat the setting in the addon, not the code itself. Btw a few versions ago I did not have to set any timeout because the addon connected automatically when the server was up ;-) Gesendet von meinem LG-D855 mit Tapatalk Edited October 4, 2016 by b0mb 1
Angelblue05 4132 Posted October 4, 2016 Posted October 4, 2016 Ok, whew! Well I'm looking into one more thing before releasing the new beta. Just let me know if your issue is resolved then. Thanks again for reporting 1
b0mb 36 Posted October 4, 2016 Author Posted October 4, 2016 Fine. Let me know when it's ready ;-) Gesendet von meinem LG-D855 mit Tapatalk
b0mb 36 Posted October 4, 2016 Author Posted October 4, 2016 @@b0mb It's available. Thx a lot. Will try it in the evening when I'm back from work. The update will run automatically via repo, right? Gesendet von meinem LG-D855 mit Tapatalk 1
b0mb 36 Posted October 4, 2016 Author Posted October 4, 2016 Hmmmm The repo still shows the old version of the addon.... Gesendet von meinem LG-D855 mit Tapatalk
Angelblue05 4132 Posted October 4, 2016 Posted October 4, 2016 (edited) The beta repo? I'll check thanks. You can find the latest beta also via our no sideloading method, in the public testing folder. Edit: the new version is already available in the beta repo. Edited October 4, 2016 by Angelblue05
b0mb 36 Posted October 4, 2016 Author Posted October 4, 2016 Yep! If it doesn't work later I'll try the version from github ;-) Gesendet von meinem LG-D855 mit Tapatalk
Angelblue05 4132 Posted October 4, 2016 Posted October 4, 2016 Check for updates in the side panel in Kodi then. It is definitely there...
b0mb 36 Posted October 4, 2016 Author Posted October 4, 2016 Ok.... Got it now ;-) I'll tell you how it works after watching some series first :-D Gesendet von meinem LG-D855 mit Tapatalk 1
b0mb 36 Posted October 4, 2016 Author Posted October 4, 2016 Just tested... Everything it's working fine again. Thx a lot :-) Gesendet von meinem LG-D855 mit Tapatalk 1
b0mb 36 Posted October 5, 2016 Author Posted October 5, 2016 So when I start my server and I don't set a timeout for the addon the server needs about 60 second until it's up and it needs about 90 seconds before the addon it's connected to Emby. Is there any way to influence this process to get faster connected? Actually I'm connecting via Emby Connect from NUC to local server or from FireTVStick ;-) Gesendet von meinem LG-D855 mit Tapatalk
Angelblue05 4132 Posted October 5, 2016 Posted October 5, 2016 It will try to connect automatically, locally/(manual)/remote. After trying (and failed), it will just try to connect to the server every few seconds. Why are you not setting the delay at start up for 60 seconds?
b0mb 36 Posted October 5, 2016 Author Posted October 5, 2016 When I do this I also have to wait 60 seconds when the server is already up and running. So I would appreciate if there would be a double check ;-) Gesendet von meinem LG-D855 mit Tapatalk
