dwwarden 0 Posted October 2, 2016 Posted October 2, 2016 (edited) After upgrading to 3.0.7300.0, Emby will only allow up to 480p on many of my mp4 files, that is the max offered when clicking on the gear icon when streaming. Can duplicate on PC and iOS devices. Attached are the server, ffmpeg, and screen shot of the file properties reported by Windows. Thanks for any guidance. ffmpeg.txt server.txt Edited October 2, 2016 by dwwarden
Luke 42186 Posted October 2, 2016 Posted October 2, 2016 Hi, it's not related to the server update. The sizes offered are limited by the size of the video. Since your video has a resolution less than 480p, that is why you are not offered any higher. If you try a 1080p video, then you'll see higher sizes offered. This is normal and has always been that way. Thanks.
