tocks 4 Posted October 1, 2016 Posted October 1, 2016 Hello, I have a problem with my first scan. The scan is finisch, but emby mark some film as view. But i view nothing movie. In second, emby find two X-Men and Warcraft film. I have : Film ->Mon film (2016) ->Fichier.mkv ->Fichier_3D.mkv Can you help me ? Thanks
tocks 4 Posted October 1, 2016 Author Posted October 1, 2016 I had a TV SHow I have the same problem, i view nothing, and emby say : i view E1, E2, E3, E4
Luke 42240 Posted October 1, 2016 Posted October 1, 2016 Hello, I have a problem with my first scan. The scan is finisch, but emby mark some film as view. But i view nothing movie. In second, emby find two X-Men and Warcraft film. I have : Film ->Mon film (2016) ->Fichier.mkv ->Fichier_3D.mkv Can you help me ? Thanks Hi, If you would like those movies to appear together, then please refer to our wiki on multi-version naming: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming Thanks !
Luke 42240 Posted October 1, 2016 Posted October 1, 2016 I had a TV SHow I have the same problem, i view nothing, and emby say : i view E1, E2, E3, E4 Check your nfo files, they probably have watch data inside.
tocks 4 Posted October 1, 2016 Author Posted October 1, 2016 thanks you a lot for your reply. but, I don't have any nfo file in all folder movies.
tocks 4 Posted October 1, 2016 Author Posted October 1, 2016 I never copy nfo file, i have only *.mkv in my librairy. I create my librairy today, i am sur the directory of the tv show in the capture
Luke 42240 Posted October 1, 2016 Posted October 1, 2016 Maybe you clicked the checkmark, that's about all i can think of. Everything is unwatched by default.
tocks 4 Posted October 2, 2016 Author Posted October 2, 2016 I am sure of myself, i never clicked the checkmark. I have a lot of movies ans tv show as clicked view. If i delete the librairy in emby en add the folder of the librairie. Emby create new nfo and don't check the view ?
tocks 4 Posted October 2, 2016 Author Posted October 2, 2016 i delete the librairie TV, and add the directory TV. I have the same problem, but not on the same EP
solabc16 379 Posted October 2, 2016 Posted October 2, 2016 Hello @@tocks If you get a moment, can you run the diagnostics and send logs utilities. Details on the Wiki here:- https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Run-Diagnostics https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs - James
tocks 4 Posted October 2, 2016 Author Posted October 2, 2016 (edited) hello, ok this is my diagnostics *** I've removed the diagnostic data from the post, as it's contained in the archive send logs uploads *** Another thing to do? Edited October 2, 2016 by solabc16 Removed diagnostic data
Darkjeje 11 Posted October 2, 2016 Posted October 2, 2016 Salut Tocks, Si tu ne t'es pas trompé dans la langue d'Emby, je suppose que tu es francophone Pour les séries, j'utilise le classement suivant : Nom de la série --> Saison X --> XX - Nom de l'épisode
tocks 4 Posted October 2, 2016 Author Posted October 2, 2016 salut @@Darkjeje, Merci pour l'information c'est toujours bon a prendre. Mais la emby trouve bien le nom des épisodes. Mon soucis est que quand je scan ma librairie TV ou Film, il me met certain film ou Episode de série en vue. Alors que je n'ai rien vue. Juste scanné les librairies.
Darkjeje 11 Posted October 2, 2016 Posted October 2, 2016 Ah oui pardon, j'avais compris ça pour les films, mais je pensais que les séries avaient un soucis dans les noms/numérotation,... C'est étonnant ton soucis.
solabc16 379 Posted October 2, 2016 Posted October 2, 2016 Thanks for information @@tocks, I'll review and get back to you. - James
