Carlo 4561 Posted February 9, 2022 Posted February 9, 2022 5 hours ago, Luke said: Yes, tvg-group is supposed and you'll see categories in the Tags section. @cayars can update our documentation. Thanks. done 1 hour ago, jathe said: Is there any option to group/tag image? maybe "tvg-group-logo" or something like that. The automatic image creation from emby is very ugly(sorry). tvg-logo is the standard for setting logos in the m3u files. @Luke have a quick read here to make sure this issue is covered.
ebr 16337 Posted February 9, 2022 Posted February 9, 2022 8 hours ago, cayars said: tvg-logo is the standard for setting logos in the m3u files. He's looking for a custom logo for the group/tag. I'm not sure how that would be expressed in the m3u since those are just derived from metadata on each channel. There is no entry for the group/tag itself.
EODCrafter 181 Posted February 9, 2022 Posted February 9, 2022 (edited) 12 hours ago, jathe said: I dont know, Im asking if exist some propertie on m3u file Are you downloading the m3u_plus version of your m3u? That format is the only format that contains groups (tags) > Should look like this url.... http://192.168.1.8:9004/get.php/?username=test&password=test&type=m3u_plus&format=mpegts Edited February 9, 2022 by EODCrafter 1
EODCrafter 181 Posted February 9, 2022 Posted February 9, 2022 3 hours ago, ebr said: He's looking for a custom logo for the group/tag. I'm not sure how that would be expressed in the m3u since those are just derived from metadata on each channel. There is no entry for the group/tag itself. yea, if OP is looking for that, it doesn't exist......
jathe 9 Posted February 10, 2022 Posted February 10, 2022 Thank you guys for your help, I allready setup the livetv... Now im reading about the guide.
Luke 42243 Posted September 7, 2025 Posted September 7, 2025 You also have more tools at your disposal now using the new webstreams plugin:
