ssl how and why
Hi
I have read the stickied post here.
but how and why.
I am running my server on a windows 10 machine and it only runs emby and utorrent.
where do i get the ssl certificate from ?
why do i need it ?
do i only install on the server or do it need to be installed on all devices that connects to the server too ?
I guess i'm looking for an explanation/clarification on this !!!!
I dont really know anything about it
hope you guys will take the time
KRONZO
I personally went with https://www.ssls.com/ssl-certificates/comodo-positivessl - Due to cost per year and ease of purchase.
why do i need it ?
You don't and you do. SSL is just a wrapper around the stream going from your server to your device. It is good because it prevents(to a certain extent) anyone from seeing what is being transmitted, all they can see is traffic but not what kind. I find it to be piece of mind. I like the idea of my ISP and anyone else not knowing what goes through my network.
Do i only install on the server or do it need to be installed on all devices that connects to the server too ?
Only on the server
Thank you for the answer.
it clarifies it a bit, but if i set up a vpn for my network would that not achieve the same thing ?
For the most part yes, the VPN will do it. VPN will enclose the connection from  your computer/network to their exit node. From there the traffic is unencrypted whereas a SSL will be end to end.
