Jake404 1 Posted September 26, 2016 Posted September 26, 2016 I'm using Emby Theater on a Surface Pro 4 and there are a few issues. When I use the UWP version it closes when I use the hardware volume buttons while playing video. See this screencast: http://recordit.co/BY8hF57peD (the stop button at the top is for the screen recorder) When I use the regular version, the back, minimize, maximize and close buttons do not work. I have tried both touch and a mouse.
Luke 42242 Posted September 27, 2016 Posted September 27, 2016 Thanks for the report. I will test the volume button. I cannot reproduce the button issues with the desktop app though.
Jake404 1 Posted September 27, 2016 Author Posted September 27, 2016 The buttons work fine on my laptop. But on my Surface it feels like something is layered on top of the buttons. If I double-tap on the buttons it does react and goes to fullscreen. But a single tap does nothing. Could it be related to high DPI?
Jake404 1 Posted September 30, 2016 Author Posted September 30, 2016 200%, which it says is recommended.
Luke 42242 Posted September 30, 2016 Posted September 30, 2016 Ok yes, I think you're right, at least when using really high zoom settings there are some display issues that we need to look into. Look for improvements in upcoming releases. Thanks.
