CVerrier 0 Posted January 17, 2014 Posted January 17, 2014 I bought my kids 'Clash of the Titans' (The 1981 original) but MB coded it as the recent remake. Everything I try within the admin console fails - I tried altering the IMDB reference in the 'Edit' screen, tried deleting the XML files from the folder, etc, but no dice. (The folder name does have the year in brackets, but that hasn't helped). Is there a technique for a) Manually overriding the auto-selected Metadata if MB doesn't do the job correctly Forcing a cleardown and refresh of the Metabase (either for a single entry, or for the whole volume) from scratch.
Luke 42289 Posted January 17, 2014 Posted January 17, 2014 editing the id, clicking save, then refresh all on the edit page should do the trick.
dkindig 1 Posted January 17, 2014 Posted January 17, 2014 Did you say brackets? The year should be in parentheses...
bloodtaker 71 Posted January 17, 2014 Posted January 17, 2014 (edited) on the web interface try these numbers on the ids for the movie http://localhost:8096/mediabrowser/dashboard/edititemmetadata.html find the clash of the titans on this area 99% of the time if you don't change themoviedb code it will stay as the current movie not the updated one that you put on imdb themoviedb - 10323 imdb - tt0082186 Edited January 16, 2014 by bloodtaker
CVerrier 0 Posted January 18, 2014 Author Posted January 18, 2014 Worked it out. As suggested, you need to clear the MovieDB ID as well as change the IMDB number. Then the metadata changes. Thanks. PS - Yep when I say brackets, I mean (). In UK, [ is called a 'square bracket'
