Buckaroo 6 Posted September 23, 2016 Posted September 23, 2016 Hello, I recently had to re-install my Emby Docker on UnRAID. Everything is working fine except that I have yet to be able to compete a media library scan. Every time it gets stuck at about 28% (this time it's 26.8%), and when I try and stop it, it just says stopping until I restart the server. Log attached. Any help that folks can offer is appreciated! Emby UnRaid server Log.txt
Luke 42244 Posted September 23, 2016 Posted September 23, 2016 Hi, I would suggest removing plugins and seeing if the issue persists with just the core server. Additionally I would suggest bumping up to mono 4.4.2. Thanks.
Buckaroo 6 Posted September 23, 2016 Author Posted September 23, 2016 (edited) Hi, I would suggest removing plugins and seeing if the issue persists with just the core server. Additionally I would suggest bumping up to mono 4.4.2. Thanks. Luke, I've gone ahead and removed my plugins, and that seems to have worked. I believe it might have been the Genre Cleaner plugin. Thanks for your help! Edited September 23, 2016 by Buckaroo
