Slow interface on DS414
Go to solution Solved by solabc16,
  • Solution
Hi @@MikeyMan
Thanks for the update, keep us posted. It's taken a bit of work to get Mono 4.6 running well on the ARM based systems.
That's the change between the 3.1.2.0-1 and 3.1.2.0-2 packages.
If possible, I'd appreciate if you could run the diagnostics followed by the send logs utilities detailed on the Wiki: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Help-and-Support
Best
- James
just ran the diagnostics... Don't really understand how i can point you to them tough...
Its called rundiags_20161230T200040UTC.log, but its stored on my nas.
Edited by MikeyMan
Hello @@MikeyMan
If you run the 'send logs' utility, that will send the diagnostics across.
I just need the file reference it will give you at the end.
- James
getting an error while sending @@solabc16 :
tr: write error: Broken pipe
tr: write error
Script invoked as [./sendlogs] by [root].
File Version : 3.1.2.0-2
This script will collect support logs into a single compressed archive and send
them to Emby over a HTTPS connection to assist with support issues, future
developemnts and package improvements. PLEASE ONLY USE AS DIRECTED BY SUPPORT
Type [yes] and press return to continue: yes
ERROR: Confirmation not given to proceed, exiting script.
Edited by MikeyMan
Hi @@MikeyMan
From the above, it looks like there was some unexpected data either sent to (copy/paste?) or already in the terminal buffer.
That's why you're seeing the 'tr: write error: Broken pipe'.
Can you try it again...
- James
@@solabc16
ahem... It seems that telnet and ssh are not the same :X
the filename is sendlogs_NAS_synology_armadaxp_ds414_20161231T085246UTC.tgz
edit: the delay is still there, but it has improved a lot! Thanks for your hard work!
To clarify; it takes around 5 seconds after entering the "Friends" folder before i see the Seasons.
Edited by MikeyMan
Hi @@MikeyMan
Thanks for the update and getting the logs across.
I've taken a look through and everything looks good, all of the platform updates are working as intended.
How does the 5s you are seeing now compare to the previous release (3.0.8500)?
Best
- James
Its heaps better! Think it's gone from 15 to 5 secs
Thanks for reporting back.
solabc16
Thanks @MikeyMan, good to hear we've taken a good step in the right direction.
- James
Guest
