MikeyMan 8 Posted September 21, 2016 Posted September 21, 2016 (edited) Hi guys! Installed Emby Server on my DS414 yesterday. Works like a charm, but the interface is rather slow. I'm using direct play through path substitution and that is playing like a charm. It's just that starting/logging on and navigating through the folders is slow. Is that something that's work in progress, or do i need to buy a faster NAS? I'm running a Gbit Network. BTW: library Refresh takes around 6 minutes, compared to 1 minute when server was also running on my HTPC, but that's something i can live with. Edited September 21, 2016 by MikeyMan
Happy2Play 9811 Posted September 21, 2016 Posted September 21, 2016 I would suspect system specs but could wrong, not a nas users but is there a way to monitor your system resources? I bet they are nearly maxed out with any process. As for your issue are there any schedule task running when you have this issue? You would need to post a log file. Also do you have "real time monitoring" enabled on your libraries?
Happy2Play 9811 Posted September 21, 2016 Posted September 21, 2016 Could be related to this topic also.
MikeyMan 8 Posted September 21, 2016 Author Posted September 21, 2016 (edited) The fact that the dbase scan is slow was just a matter of me putting the performance into perspective. It's not an issue, i can understand that it costs some effort, but it runs scheduled. Might be an idea to specify the priority of the reload to low. I'll have a look into the system resources. Don't know if there's a log for that. At idle i run at 22% cpu load and 55% ram load. Forgot to mention; Web performance is quite good actually. IT's the MCE Plugin that's rather slow. Just disabled DLNA, let's see how that goes. Edited September 21, 2016 by MikeyMan
MikeyMan 8 Posted September 21, 2016 Author Posted September 21, 2016 Just tested. Cpu is going up, but not maxing out. It goes wrong upon opening a tv show folder. It sort of hangs for a while. Whereas when i use the webview at the Same time it works okay.
solabc16 379 Posted September 21, 2016 Posted September 21, 2016 Could be related to this topic also. Hello Folks Just to avoid any confusion here, the topic above is on a beta thread and does not apply here. Best - James
MikeyMan 8 Posted September 22, 2016 Author Posted September 22, 2016 (edited) I have been looking at the logs, and see a lot of these: 2016-09-22 08:30:42.8762 Info HttpServer: HTTP Response 200 to 10.0.0.6. Time: 2671ms (slow). http://10.0.0.4:8096/emby/Items/4754464f3bc44b5771d3022fb5afaab5/Images/Primary?width=563&tag=1db3ae313ec5d7566fca1ccbe27633f2&quality=90 2016-09-22 08:30:42.8966 Info HttpServer: HTTP GET http://10.0.0.4:8096/emby/Items/254d491742a9ef4d5fc7587b46388c35/Images/Primary?maxWidth=117&tag=92648d8ee46987e94ae3a887bcd3df2f&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/2.5.22 Chrome/53.0.2785.113 Electron/1.4.0 Safari/537.36 2016-09-22 08:30:42.9262 Debug App: ConvertImageToLocal item 254d4917-42a9-ef4d-5fc7-587b46388c35 - image url: https://www.thetvdb.com/banners/actors/315146.jpg 2016-09-22 08:30:42.9274 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/315146.jpg Full Gist at: https://gist.github.com/anonymous/3a33ff9b955afe8a17bb926532ff4c59 Edited September 22, 2016 by MikeyMan
MikeyMan 8 Posted September 23, 2016 Author Posted September 23, 2016 Been thinking about this; it seems that the delay happend when entering 'larger' folders. Folders with single files are quick enough. What causes this delay? Logically thinking only some text and JPEG's have to be sent over the network? This shouldn't take up to much resources?
solabc16 379 Posted September 23, 2016 Posted September 23, 2016 Hello @@MikeyMan Thanks for the feedback and updates so far, sorry I haven't been able to give this some more attention sooner. Could you send me your supports logs, details here: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs - James
MikeyMan 8 Posted September 28, 2016 Author Posted September 28, 2016 (edited) No problem. I'm in Cuba at the moment, so that'll have to wait till i'm Back. Does the log provided above give any insight? Edited September 28, 2016 by MikeyMan
MikeyMan 8 Posted October 15, 2016 Author Posted October 15, 2016 Just sent the logfiles: sendlogs_NAS_synology_armadaxp_ds414_20161015T120159UTC.tgz
MikeyMan 8 Posted October 19, 2016 Author Posted October 19, 2016 Anything strange in the logs, or is my NAS just too slow?
solabc16 379 Posted October 19, 2016 Posted October 19, 2016 Hello @@MikeyMan Sorry for the delay in getting back to you. If you haven't already updated to the latest stable (3.0.8200), can you do so and send the logs again please. One thing I can see, is that you have debug logging switched on, can you switch this off. It's generating a lot of IO, especially when new media is detected or there are changes to your media. On your system, I would also suggest disabling "Enable real time monitoring", which you can find under "Manage Folders" for each configured library. - James
MikeyMan 8 Posted October 26, 2016 Author Posted October 26, 2016 I disabled both and updated to the latest verslon. Seems a very little bit quicker, but not by much.
MikeyMan 8 Posted October 28, 2016 Author Posted October 28, 2016 Latest logs sent: sendlogs_NAS_synology_armadaxp_ds414_20161028T144054UTC.tgz
MikeyMan 8 Posted November 15, 2016 Author Posted November 15, 2016 Anything strange in the logs? Do i need to buy a faster Nas?
Luke 42240 Posted November 15, 2016 Posted November 15, 2016 I would try again with the next release of emby server. Thanks.
solabc16 379 Posted November 15, 2016 Posted November 15, 2016 Hello @@MikeyMan A bit of further information for you. There's an issue with the Mono runtime that has prevented us updating to the latest version on ARM based devices. We've almost got to the bottom of that and should be in a position to start testing within the week. If you'd be happy to test, I can make it available to you once we have it built. - James
MikeyMan 8 Posted December 30, 2016 Author Posted December 30, 2016 Should this be fixed in toydays release @@solabc16 ? Although i notice it being quicker, it's still not very snappy...
Luke 42240 Posted December 30, 2016 Posted December 30, 2016 Hi there @@MikeyMan, in order for us to best help you, please provide the information requested in how to report a problem. thanks !
solabc16 379 Posted December 30, 2016 Posted December 30, 2016 Hello @@MikeyMan Did you notice any difference with today's refresh (3.1.2.0-2)? Best - James
MikeyMan 8 Posted December 30, 2016 Author Posted December 30, 2016 Hi @@solabc16, I do notice a difference! Keep up these updates
