farside847 39 Posted September 21, 2016 Posted September 21, 2016 Sorry for the simple question, but where do I set the number of days of guide data to download? I have an hdhomerun and schedules direct set up any running perfectly, but I seem to remember setting it to only a few days when I first set it up, and now I can't find it for the life of me to increase. Thanks!!!!
Solution blade005 185 Posted September 21, 2016 Solution Posted September 21, 2016 Go into the Dashboard on Emby Server and select the following: LIVE TV under Dashboard Selections, then SETTINGS at top of Live TV Section. Number of days of guide data to download is the first selection at the top. 2
farside847 39 Posted September 21, 2016 Author Posted September 21, 2016 Thanks! I totally overlooked that. I'm curious, why does it max out at 14 days? Doesn't schedules direct provide up to 21?
kanipek 230 Posted September 21, 2016 Posted September 21, 2016 (edited) Actually I believe via json you can get up to 30 days of data. Though I have found in my case, could be different for others, that after 17 or 18 days the data is a little spotty. Edited September 21, 2016 by kanipek
farside847 39 Posted September 21, 2016 Author Posted September 21, 2016 14 is a good max I think. I got a reply from SD: "we normally have more than 14 days, but honestly I wouldn't trust any data more than 7 days out.. it changes quite often."
blade005 185 Posted September 21, 2016 Posted September 21, 2016 14 is a good max I think. I got a reply from SD: "we normally have more than 14 days, but honestly I wouldn't trust any data more than 7 days out.. it changes quite often." Agree. Anything farther out is highly suspect. I use Zap2XML and pulled 14 days initially, cache 10 days, and let my nightly update refresh the back 4 days. I also put in the option not to cache anything marked as TBA. This keeps a fresh and fairly accurate rolling 14 days and keeps my nightly refresh update to about a 7 minute process. The Refresh Guide task in Emby still takes 45 minutes to an hour, but that runs early in the AM.
EODCrafter 181 Posted August 9, 2018 Posted August 9, 2018 (edited) Go into the Dashboard on Emby Server and select the following: LIVE TV under Dashboard Selections, then SETTINGS at top of Live TV Section. Number of days of guide data to download is the first selection at the top. It's now under the DVR Tab.....I'm trying to figure out how to Purge old guide data. Is there a specific database I can delete? Edited August 9, 2018 by EODCrafter
EODCrafter 181 Posted August 9, 2018 Posted August 9, 2018 (edited) All you have to do is just refresh the guide. OMG, I think it's being cached in my browser then cause I had a whole lot of duplicate channels that were no longer in my latest .m3u file. I went ahead and erased everything in %emby%/appdata/programdata and started over...Didn't need to do this? See...It just did it again. I had to add .0 and .1 to channels cause it was reading the TV Guide Channel List. The single numbered channels don't exist any more..2, 3, 4 ,5 ECT in my .m3u This time I cleared my browser cache and they are still there.... EDIT: My Bad, I was jumping the gun...It's gotta be a full reload of the Guide which takes 20 minutes or so....Sry. Edited August 9, 2018 by EODCrafter
Luke 42244 Posted August 10, 2018 Posted August 10, 2018 It sounds like you completely wiped out the server? no you didn't have to do that. those duplicates are most likely in your m3u. have you checked on that?
EODCrafter 181 Posted August 10, 2018 Posted August 10, 2018 (edited) It sounds like you completely wiped out the server? no you didn't have to do that. those duplicates are most likely in your m3u. have you checked on that? It's the Server Lagging on Guide reload. Is there any possible fix for that when we have VERY large .xml guide files? I know Perfect Player loads 3 guides I have in about 20 seconds, not 20 minutes. I'm considering redoing my channel lineup to fit one simple Xml (zap2xml) local file but I really would rather have all the channels I can for on my Server. Edited August 10, 2018 by EODCrafter
