Help with initial setup
Go to solution Solved by Angelblue05,
I tried to test out this plugin tonight and am clearly missing something but I don't know what I'm doing wrong.  Apologize for my ineptitude as I've never really used Kodi before.
I followed the guide @@xnappo put together showing how to install the Add-on without sideloading.  I got as far as Kodi telling me that the Emby plugin was activated.
But when I go to the videos section and click on Add-Ons it doesn't show anything there.
Did I miss a step?  What else do I need to do to get this working?
  • Solution
Angelblue05
Hi there, you probably installed the Emby repository which contains the Kodi add-ons, which is the first step. Go to Kodi settings > add-ons > install from repository > Do you see Emby stable/beta repostiory? If so, access it > video add-on > install the Emby for Kodi add-on.
Edited by Angelblue05
  • Like 1
Thank you for this assistance.  Looks like it's at least doing something now.
Although it's pegged my CPU to 100% while it scans my library now so I am just going to go to sleep and see how it's doing in the morning.
Edited by moviefan
  • Like 1
Guest
