dansblackcat 37 Posted September 20, 2016 Posted September 20, 2016 Hi all. I have a PVR set top box that runs Android 4.4.2. I'm running Emby for Android on it and the only thing I can't get working is the surround sound. Almost all of my files would be AC3. The Emby app plays everything in 2.0 channel audio. The server dashboard shows the media as being 'Direct Play' so I assume it's not transcoding? If I choose to use an external player and launch the Kodi app then I get 5.1. I'd rather just use Emby instead of jumping between apps. Is there a way to do HDMI Pass-through to get 5.1 or is it a limitation of the app? I've tried Emby for Android TV but it doesn't support 4.4.2, only 5.0+.
dansblackcat 37 Posted October 1, 2016 Author Posted October 1, 2016 It's working fine now. Not sure what fixed it. Could have been server, Android app or firmware update.
dansblackcat 37 Posted October 12, 2016 Author Posted October 12, 2016 Aww it's stopped working Back to 2.0 channel audio. I'll investigate further if I have time on the weekend. I have no idea what's changed.
