schamane 20 Posted September 19, 2016 Posted September 19, 2016 Hi, I watch a movie in the webbrowser when I transcode with vaapi I have a CPU usage of 30 % (but with the already known quality isssues) but if I just wanna watch a movie without any bandwidth limitation it starts to remux and I have a load of 100% and after a few minutes it begins to stutter. I am 100% sure this wasn` t in the past Something changed here? Version 3.1.158.0 beta thx for any hints
Luke 42244 Posted September 19, 2016 Posted September 19, 2016 Hi there, welcome. In order for us to best answer this, please provide the information requested in how to report a media playback issue. Thanks !
schamane 20 Posted September 19, 2016 Author Posted September 19, 2016 Hi Luke, the log wont help me here, it is working as it should, because its remuxing the audio, but it causes so much CPU usage, isnt it possible to use VAAPI here as well? anyways, I will attach the log And as I said in my opinion it worked without 100% ffmpeg in the past ffmpeg-remux-a2c6ff2a-e206-4f14-b2a0-1bfc7a24905a.txt
Luke 42244 Posted September 19, 2016 Posted September 19, 2016 To my knowledge it's not possible to use vaapi for audio transcoding.
schamane 20 Posted September 20, 2016 Author Posted September 20, 2016 But why is Remuxing so expensive at the moment, ffmpeg only uses one Core for remuxing, because usually u dont need more, but at the moment remuxing is more expensive as transcoding
schamane 20 Posted September 20, 2016 Author Posted September 20, 2016 (edited) At the moment I am a bit frustrated to be honest, I cant watch any movie in the browser without stuttering if it has to re-encode sound I have an intel n3700 which should be able to re-encode without any issues. Every week another issue with emby, sorry but this is annoying I tweaked around a bit and its just because of too much quality /usr/bin/ffmpeg -ss 01:25:09.714 -fflags +genpts -i file:"/tmp/test.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 6 -ab 1536000 -af "aresample=async=1" -f mp4 -movflags frag_keyframe+empty_moov -y "/var/lib/emby-server/transcoding-temp/55dc19f7eb27da795d337743908a7ef2.mp4" sorry, but -ab 1536000 ???? If emby really need to reencode for Webbroser this rate is way too much, also -ac 6 Does it make sense all 6 Channels in a Browser? I dont know what is a browser able to play and would it be possible to give us an option to lower these setting for webbrowser? Edited September 20, 2016 by schamane
Luke 42244 Posted September 20, 2016 Posted September 20, 2016 i notice we are encoding the audio to a very high bitrate so i will reduce that and we'll see if that has an effect for the next release.
Luke 42244 Posted September 20, 2016 Posted September 20, 2016 Every week another issue with emby, sorry but this is annoying I apologize but you are using an experimental feature. Should we just not offer the VA API feature? If we didn't offer it, you would never have been able to turn it on, and you would never have been frustrated. What do you think?
schamane 20 Posted September 20, 2016 Author Posted September 20, 2016 Hi Luke, I love vaapi, thats not what I am complaining about. I am not able to view a movie in a Browser cause reencoding of audio (only audio) is too much on an up2date CPU frame= 902 fps= 17 q=-1.0 size= 25089kB time=00:00:37.61 bitrate=5464.1kbits/s speed=0.726x frame= 912 fps= 17 q=-1.0 size= 25089kB time=00:00:38.04 bitrate=5402.9kbits/s speed=0.727x frame= 923 fps= 17 q=-1.0 size= 27303kB time=00:00:38.46 bitrate=5814.6kbits/s speed=0.728x frame= 933 fps= 17 q=-1.0 size= 27303kB time=00:00:38.87 bitrate=5753.9kbits/s speed=0.729x frame= 943 fps= 18 q=-1.0 size= 27303kB time=00:00:39.27 bitrate=5694.5kbits/s speed=0.73x 17 Frames per second are just not enough to watch anything without stuttering. If i use /usr/bin/ffmpeg -fflags +genpts -i file:"/mnt/test.mkv" -map 0:0 -map 0:1 -map -0:s -c:v copy -copyts -avoid_negative_ts disabled -start_at_zero -map_metadata -1 -threads 0 -c:a aac -ac 2 -ab 136000 -af "aresample=async=1,volume=2" -y "/var/lib/emby-server/transcoding-temp/65aeaeb631033d57dcd9eb3ab5cc7028.mkv" It looks like frame= 748 fps=165 q=-1.0 size= 17385kB time=00:00:31.19 bitrate=4565.8kbits/s speed=6.88x frame= 841 fps=167 q=-1.0 size= 20921kB time=00:00:35.07 bitrate=4886.1kbits/s speed=6.97x frame= 931 fps=168 q=-1.0 size= 24559kB time=00:00:38.80 bitrate=5184.0kbits/s speed=7.01x frame= 1036 fps=171 q=-1.0 size= 28870kB time=00:00:43.20 bitrate=5474.1kbits/s speed=7.13x So it would be nice If we could get more options here Like Webplayer = ffmpeg parameters Transcode = ffmpeg parameters and/or user based Because I dont think any Browser will play 5.1 anyways
Luke 42244 Posted September 20, 2016 Posted September 20, 2016 The really high audio bitrate is being resolved for the next release, thanks.
schamane 20 Posted September 20, 2016 Author Posted September 20, 2016 Hi Luke, sounds promising, but just found another thng, vaapi transcoding is as well broken ATM /usr/bin/ffmpeg -ss 00:54:07.985 -fflags +genpts -hwaccel vaapi -hwaccel_output_format yuv420p -vaapi_device /dev/dri/renderD128 -i file:"/mnt/test.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -force_key_frames "expr:gte(t,n_forced*5)" -vf "format=nv12|vaapi,hwupload,scale_vaapi=w=1280:h=538" -b:v 2464000 -maxrate 2464000 -bufsize 4928000 -vsync -1 -level 41 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 6 -ab 1536000 -af "aresample=async=1" -f mp4 -movflags frag_keyframe+empty_moov -y "/var/lib/emby-server/transcoding-temp/d83ac8a72c9ec40ad013cb71478f056e.mp4 results in frame= 26 fps= 10 q=-0.0 size= 1kB time=00:00:01.30 bitrate= 7.3kbits/s speed=0.511x frame= 31 fps= 10 q=-0.0 size= 1kB time=00:00:01.60 bitrate= 5.9kbits/s speed=0.523x frame= 39 fps= 11 q=-0.0 size= 1kB time=00:00:01.87 bitrate= 5.0kbits/s speed=0.525x frame= 47 fps= 11 q=-0.0 size= 1kB time=00:00:02.15 bitrate= 4.4kbits/s speed=0.527x in the past it was /usr/bin/ffmpeg -fflags +genpts -hwaccel vaapi -hwaccel_output_format vaapi -vaapi_device /dev/dri/renderD128 -i file:"/mn/test.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -force_key_frames "expr:gte(t,n_forced*5)" -vf "format=nv12|vaapi,hwupload,scale_vaapi=w=1280:h=538" -copyts -avoid_negative_ts disabled -start_at_zero -b:v 2464002 -maxrate 2464002 -bufsize 4928004 -vsync -1 -level 41 -map_metadata -1 -threads 0 -codec:a:0 libmp3lame -ac 2 -ab 1536000 -af "aresample=async=1,volume=2" -y "/var/lib/emby-server/transcoding-temp/474c84e8e789c72264e6321620d75859.mkv" frame= 106 fps= 70 q=-0.0 size= 797kB time=00:00:04.63 bitrate=1409.1kbits/s speed=3.08x frame= 147 fps= 73 q=-0.0 size= 1228kB time=00:00:06.33 bitrate=1587.5kbits/s speed=3.13x frame= 194 fps= 77 q=-0.0 size= 1521kB time=00:00:08.25 bitrate=1508.6kbits/s speed=3.26x frame= 219 fps= 72 q=-0.0 size= 1874kB time=00:00:09.26 bitrate=1657.0kbits/s speed=3.06x frame= 264 fps= 75 q=-0.0 size= 2493kB time=00:00:11.16 bitrate=1829.8kbits/s speed=3.15x frame= 310 fps= 77 q=-0.0 size= 3130kB time=00:00:13.15 bitrate=1949.2kbits/s speed=3.25x I mean we need 30 FPS to play a movie fluently
schamane 20 Posted September 20, 2016 Author Posted September 20, 2016 Seriously? If u dont know, who maintains this ffmpeg stuff? I am also no genius and its really complicated as f.... As far I can see it is the audio codec as well aac instead of mp3lame
Luke 42244 Posted September 20, 2016 Posted September 20, 2016 i just wanted you to be more specific about your issue. There is no problem in that command line other than the high audio bitrate which I already mentioned is fixed for the next release. It looks like firefox? We use that mp4 output for firefox. The bottom command line is mkv output which we use for chrome, chromecast, android, etc and we can't use that with firefox. So, no problem found.
schamane 20 Posted September 20, 2016 Author Posted September 20, 2016 there was a pasting mistake of me, sorry this is the faster comman /usr/bin/ffmpeg -fflags +genpts -hwaccel vaapi -hwaccel_output_format vaapi -vaapi_device /dev/dri/renderD128 -i file:"/mnt/test.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -force_key_frames "expr:gte(t,n_forced*5)" -vf "format=nv12|vaapi,hwupload,scale_vaapi=w=1280:h=538" -copyts -avoid_negative_ts disabled -start_at_zero -b:v 2464002 -maxrate 2464002 -bufsize 4928004 -vsync -1 -level 41 -map_metadata -1 -threads 0 -codec:a:0 libmp3lame -ac 6 -ab 1536000 -af "aresample=async=1,volume=2" -y "/var/lib/emby-server/transcoding-temp/474c84e8e789c72264e6321620d75859.mkv" found some differences marked them if I change those two it goes up I guess these both are wrong (one should be fixed laready as u said)
Luke 42244 Posted September 20, 2016 Posted September 20, 2016 what are you saying about hwaccel_output_format? it should be removed, or changed to something else?
schamane 20 Posted September 20, 2016 Author Posted September 20, 2016 (edited) at the moment u use -hwaccel_output_format yuv420p instead of hwaccel_output_format vaapi what makes a huge difference I guess Edited September 20, 2016 by schamane
