Jobber8742 9 Posted January 15, 2014 Posted January 15, 2014 (edited) It started this morning. Only some shows and doesn't seem to be affecting any movies. All files are housed on a server computer. The computer did restart last night thanks to a windows update (I really need to fix that). Since then, when I try to access some of the TV shows in MBC, the show will display and the number of episodes that haven't been watched displays fine, but when you get to the seasons, it just shows checkmarks on each season, and when you click the season, no files are shown. Also on the web client the same shows are also showing the number of episodes not watched, but when I click on a season, I get an error that says "Value cannot be null. Parameter name: Item". Any idea what is going wrong and what the heck the error means? I should note that these files play fine outside of mediabrowser via computer on the network. Correction: It appears to be all TV Episodes. Some will let me get to the episode level, but will not play the episodes. Movies are working fine. Edit 2: Just restarted MB Server again, now they are playing fine. I did that before and it was doing nothing, but now it's working. Please lock. Edited January 15, 2014 by Jobber8742
