PaucS 0 Posted September 16, 2016 Posted September 16, 2016 (edited) I have been using emby app on my tv for a while now. But suddenly it stopped working. When I wanna start the app all I can see is this (see attachment). Edited September 16, 2016 by PaucS
FrostByte 5453 Posted September 16, 2016 Posted September 16, 2016 Just tried mine and it is working. I noticed your version is older, might try updating to the latest 2.2.0i and see it that helps
CBers 7554 Posted September 16, 2016 Posted September 16, 2016 I have been using emby app on my tv for a while now. But suddenly it stopped working. When I wanna start the app all I can see is this (see attachment). I get that often. Uninstall and reinstall and don't use auto-login.
CBers 7554 Posted September 16, 2016 Posted September 16, 2016 Just tried mine and it is working. I noticed your version is older, might try updating to the latest 2.2.0i and see it that helps v2.1.3 is the stable version isn't it?
FrostByte 5453 Posted September 16, 2016 Posted September 16, 2016 Technically, there have been a lot of fixes to the logon process though and 220 is probably more stable
Spaceboy 2573 Posted September 16, 2016 Posted September 16, 2016 I get that often. Uninstall and reinstall and don't use auto-login. uninstall and reinstall is like a days work though! And on my last attempt I still ended up with the original version!
CBers 7554 Posted September 16, 2016 Posted September 16, 2016 uninstall and reinstall is like a days work though! And on my last attempt I still ended up with the original version! A day's work? Ten minutes, tops! You have to change the IP address you are syncing from to get the beta. Pick your TV model from here: http://emby.media/community/index.php?/topic/9869-samsung-smart-tv-app-install-instructions/ The Beta IP address is: 82.27.106.58 2
Spaceboy 2573 Posted September 16, 2016 Posted September 16, 2016 It's ok I've given up on the Samsung tv app but seriously that's how long it would take my tv to uninstall the old app, install the new app and it then actually be usable
