mercman71 0 Posted September 15, 2016 Posted September 15, 2016 Hi, Since upgrading to 3.0.7100.0 the genres, studios and tags buttons do not work when editing or in the metadata editor. Clicking on them has no effect. I am using Firefox 48.0.2, but it is the same with Safari. I have tried it on my other computer before updating to 3.0.7100.0 the buttons are green and work fine, after updated to 3.0.7100.0 and they are grey in colour and do not do anything when you click on them, People button works OK but is also grey. Is this a known problem or is it something my end. Any help would be great, Thanks, for such a great bit of software.
Luke 42237 Posted September 15, 2016 Posted September 15, 2016 Hi, it's a known issue and will be resolved for the next release. In the meantime, it is resolved in the online web app, which you can use at http://app.emby.media
mercman71 0 Posted September 20, 2016 Author Posted September 20, 2016 thanks for the reply Luke, n1. sorry for the late reply. cheers
Luke 42237 Posted September 20, 2016 Posted September 20, 2016 Thanks for reporting back. The new release is out with the fix, fyi.
mercman71 0 Posted September 21, 2016 Author Posted September 21, 2016 Already got it, thanks works a treat
