robello84 1 Posted September 15, 2016 Posted September 15, 2016 Good evening guys, is from about 1 week that the ssl connection on port 8920, does not work anymore. I try to restart emby, and it works for about half an hour, then do not work anymore. I have the latest version of emby installed. It works via http. Using the certificate of let'sencrypt from 6 months is it always worked. Can someone help me? The only mistake that I find in the log is this. Thank you 2016-09-15 14:30:14.1333 Error ServiceStackHost: Error occured while Processing Request: Access token is required. *** Error Report *** Version: 3.0.7100.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.19.0.42 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.4.2 (Stable 4.4.2.11/f72fe45 Tue Aug 30 15:48:05 UTC 2016) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Access token is required. MediaBrowser.Controller.Net.SecurityException at MediaBrowser.Server.Implementations.HttpServer.Security.AuthService.ValidateSecurityToken (IServiceRequest request, System.String token) <0x413e2870 + 0x00107> in <filename unknown>:0 at MediaBrowser.Server.Implementations.HttpServer.Security.AuthService.ValidateUser (IServiceRequest request, IAuthenticationAttributes authAttribtues) <0x413e0eb0 + 0x0007b> in <filename unknown>:0 at MediaBrowser.Server.Implementations.HttpServer.Security.AuthService.Authenticate (IServiceRequest request, IAuthenticationAttributes authAttribtues) <0x413e0e80 + 0x00017> in <filename unknown>:0 at MediaBrowser.Controller.Net.AuthenticatedAttribute.RequestFilter (IRequest request, IResponse response, System.Object requestDto) <0x413e0de0 + 0x0007a> in <filename unknown>:0 at ServiceStack.ServiceStackHost.ApplyRequestFiltersSingle (IRequest req, IResponse res, System.Object requestDto) <0x41324b60 + 0x0029e> in <filename unknown>:0 at ServiceStack.ServiceStackHost.ApplyRequestFilters (IRequest req, IResponse res, System.Object requestDto) <0x41322590 + 0x000d5> in <filename unknown>:0 at ServiceStack.Host.RestHandler+<ProcessRequestAsync>d__13.MoveNext () <0x4131d1d0 + 0x00595> in <filename unknown>:0
Luke 42244 Posted September 15, 2016 Posted September 15, 2016 Hi, welcome. Please attach a complete log file. Thanks. 1
robello84 1 Posted September 15, 2016 Author Posted September 15, 2016 (edited) Hi Luke thank you for welcome. I love Emby See attach for log thank you log.txt Edited September 15, 2016 by robello84
Solution anderbytes 141 Posted September 15, 2016 Solution Posted September 15, 2016 Hi Luke thank you for welcome. I love Emby See attach for log thank you It seems to be losing the session token. Are you using which Browser? Have you tried with others? Private or normal browsing? Disabled all addons? Running via Emby Theater works? 1
robello84 1 Posted September 16, 2016 Author Posted September 16, 2016 It seems to be losing the session token. Are you using which Browser? Have you tried with others? Private or normal browsing? Disabled all addons? Running via Emby Theater works? Hi Ander, thank you for reply. i have 50 friend connected with raspberry (OSMC), i use chrome only for access and insert movie, normal browsing. The only plugin i have installed is pushover. I try with other browser but not work.
robello84 1 Posted September 19, 2016 Author Posted September 19, 2016 After make backup, uninstall and install new version without pushbullet plugin. Work like a charm. Thank you guys 1
oneil31 0 Posted October 8, 2016 Posted October 8, 2016 After make backup, uninstall and install new version without pushbullet plugin. Work like a charm. Thank you guys Hi robello, Same issue solved with uninstall only pushbullet By security i make a little script with crontab who check https over 8920 responce log and restart emby-server. But since uninstall of pushbullet no new issue. res="KO" dt="date +%F_%T" res=$(curl -sikm 2 -D - https://127.0.0.1:8920/web/index.html -o /dev/null | grep -e "HTTP.*200 OK") echo $($dt)" : curl - $res" if [ -z "$res" ] || [ "$res" = "KO" ] then echo $($dt)" $0 : KO" echo "EREUR emby => restart" /etc/init.d/emby-server stop /etc/init.d/emby-server start else echo $($dt)" $0 OK" fi Not perfect but it make the job
