easez88 16 Posted September 14, 2016 Posted September 14, 2016 Hi All, On the latest version of the emby app, was the remote functionality removed? It's still available from the mobile web app. A lot of things were moved around so I could just be missing it.
Solution Luke 42243 Posted September 14, 2016 Solution Posted September 14, 2016 Currently you can only get to it once something is playing on the remote device. It's something we need to improve. 1
Filippus 0 Posted September 15, 2016 Posted September 15, 2016 Currently you can only get to it once something is playing on the remote device. It's something we need to improve. When will this be fixed so you can use phone for remote functionality only? just curious.
Luke 42243 Posted September 15, 2016 Posted September 15, 2016 What are you trying to do? because most things you can still do.
easez88 16 Posted September 21, 2016 Author Posted September 21, 2016 What are you trying to do? because most things you can still do. Loading up Emby theater and use my phone as a remote to navigate the menus. I know I can select the media on the phone and play it in Emby Theater, but if I am watching with someone and we want to scroll through options together, that is no longer an option.
Luke 42243 Posted September 21, 2016 Posted September 21, 2016 It's been added to the latest update under the More tab.
