aidbish 0 Posted September 13, 2016 Posted September 13, 2016 Hi All Just starting out with Emby and live TV i have tried using the json feed from schedulesdirect for australia, but it Emby does seem to be applying the timezone offset. i have also tried using the xmltv xml i currently use for Mediaportal and agin it does apply the +10 offset Reading on Schedules direct forum, the json feed is UTC and the application should apply the offset. i have also checked the XMLTX xml and this is also UTC is there anywhere in Emby i need to apply my timezone for the guide to be correct.
pünktchen 1411 Posted September 13, 2016 Posted September 13, 2016 ... Emby does seem to be applying the timezone offset. ... the json feed is UTC and the application should apply the offset. i have also checked the XMLTX xml and this is also UTC Emby is applying the timezone offset as suggested. So where is your problem
aidbish 0 Posted September 13, 2016 Author Posted September 13, 2016 (edited) sorry bad grammar on my part (damn phone) It isnt applying the offset thats the issue when i look at the guide and what it should be its +10 out Edited September 13, 2016 by aidbish
pünktchen 1411 Posted September 13, 2016 Posted September 13, 2016 Ah, okay. Strangely no one other reported this yet. Is your OS timezone set correctly? Especially if run Emby in a docker container, you have to set the timezone for docker also, not only for the host system.
Luke 42242 Posted September 13, 2016 Posted September 13, 2016 Yea the time zone on the host system is the most important thing.
