AceBlade258 3 Posted September 13, 2016 Posted September 13, 2016 (edited) Are there any? I can't seem to find them, even when I am playing something on a Chromecast. Edited September 13, 2016 by AceBlade258
Luke 42186 Posted September 13, 2016 Posted September 13, 2016 Hi, yes we have this. Explore the in-app settings in the app you're casting from. You can specify the max bitrate to use with Chromecast, although we suggest leaving it on Auto because when you do that it will perform bandwidth tests with the server and will measure the ideal bitrate.
