anderbytes 141 Posted December 12, 2016 Author Posted December 12, 2016 I meant "per item" and not "per library". Hi. Any chance that this will make it to the to-do list?
Luke 42198 Posted December 12, 2016 Posted December 12, 2016 We have to finish the per library changes before we can think about per-item. So if you go into the Metadata settings section of the server, we need to get all of those settings moved into per-library. That will take a little bit more time.
anderbytes 141 Posted December 12, 2016 Author Posted December 12, 2016 We have to finish the per library changes before we can think about per-item. So if you go into the Metadata settings section of the server, we need to get all of those settings moved into per-library. That will take a little bit more time. No rush, Luke. I know this is a minor issue... so I'll already be happy if it is in the backlog, for the future
anderbytes 141 Posted March 17, 2017 Author Posted March 17, 2017 We have to finish the per library changes before we can think about per-item. So if you go into the Metadata settings section of the server, we need to get all of those settings moved into per-library. That will take a little bit more time. Are all the settings you wanted to move, already moved to per-library?
Luke 42198 Posted March 17, 2017 Posted March 17, 2017 Not yet. The last ones are the ones in the Metadata tab. They still need to move.
