Volume OnChange
Would be great if you could change at least the volume control to en onchange event rather then after releasing it. its just a small thing which kinda bugged me when i tryed emby for the first time. i understand that its not very usefull on the searchbar of the stream itself since you have to get the data in time and so on. but volume control should be loval so it should be no problem to make the volume change on the fly when draging the green circle around.
thanks
Where are you referring to?
well i basicly would like the volume in the web client to change as soon as a drag the volume control button. not after i release it i want it to change while draging it
Ok thanks for the feedback.
