goodjorb 0 Posted September 12, 2016 Posted September 12, 2016 I'm reaching my limit on patience with this app. Every time there is an update - my password no longer works - no matter how many times i reset it (and there are multiple places to do this - it's not intuitive). The roku app is broken - no longer shows my library. Updates require 3rd party installs (microsoft.net namely). Can you anyone help with: 1) If I see the server running on my PC - why do not I see my library on the ROKU? 2) If I try to login on the Roku it says my password is not correct 3) Is there a different password for Emby connect, my server, my username, etc.?
goodjorb 0 Posted September 12, 2016 Author Posted September 12, 2016 Also, the pin code? what is this? i see it on the Roku, go to login at emby.media/pin - says my password is not valid and asks if I need to register
Guest asrequested Posted September 12, 2016 Posted September 12, 2016 You may have connectivity issues. Take a look at this, to see if helps https://github.com/MediaBrowser/Wiki/wiki/Connectivity
Luke 42186 Posted September 12, 2016 Posted September 12, 2016 Also, the pin code? what is this? i see it on the Roku, go to login at emby.media/pin - says my password is not valid and asks if I need to register Hi, welcome. Apologies about the pin code. There was an issue with that today which has since been resolved and it is now working.
