aziz 16 Posted September 12, 2016 Posted September 12, 2016 Hi, How does auto camera upload works.. How does it collected the pic... where does it store the images... how do you define which area's it should look at and NOT look at... is it per user and stored on user device, or is it per server, and stored on the server... I can seem to find anything on this on the server... many thanks
Solution Luke 42186 Posted September 12, 2016 Solution Posted September 12, 2016 Hi, in the server dashboard, under Sync -> Camera Upload, did you try clicking the Help button? 1
aziz 16 Posted September 13, 2016 Author Posted September 13, 2016 Thank you sir... that answers all my questions... I am still getting used to the tabs within each category on the left side..., OK... for now, I will not be using this feature, but i can see it can be very useful, in terms of automatic backup of your photos. Thanks Luke.. all the best
