goldsworthy1 5 Posted September 12, 2016 Posted September 12, 2016 Not sure if anyone else has experienced this issue, of just me. When i try to access my "all series" option via Emby Theatre or the android app, i just get a never ending spinning circle. Nothing ever loads. Also noticed that the next episode feature has either gone, or been removed?
Luke 42186 Posted September 12, 2016 Posted September 12, 2016 Not sure if anyone else has experienced this issue, of just me. When i try to access my "all series" option via Emby Theatre or the android app, i just get a never ending spinning circle. Nothing ever loads. Also noticed that the next episode feature has either gone, or been removed? Hi, next up is still there, both on the home screen under the libraries as well as in your tv section.
Luke 42186 Posted September 12, 2016 Posted September 12, 2016 As far as the series loading goes, please provide the server log and we'll take a look: http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks!
goldsworthy1 5 Posted September 12, 2016 Author Posted September 12, 2016 Most recent log attached, let me know if you need more... or ive given u the wrong stuff... server-63609276990.txt
Solution Luke 42186 Posted September 12, 2016 Solution Posted September 12, 2016 Somehow your library database has become corrupted. That could have been due to a power failure, disk failure, other hardware failure, or any other number of reasons. You're going to have to shutdown the server and delete the file C:\Users\Goldsworthy\AppData\Roaming\MediaBrowser-Server\data\library.db Then start the server back up and run a library scan. The scan will take a little while due to starting with a fresh database. let us know how it goes. thanks. 2
goldsworthy1 5 Posted October 6, 2016 Author Posted October 6, 2016 Thanks Luke, that fixed it Sent from my Nexus 5 using Tapatalk
