Uroth 0 Posted September 11, 2016 Posted September 11, 2016 (edited) Hello, I have noticed that in the latest releases my server is having issues identifying the movies, defaulting to IMDB which adds almost no info for my new movies added to the server, lacking good posters, banners and backdrops. When I search up the ID on themoviedb and then try to identify the movie in Emby I sometimes have to search 5-30 times for it to actually find the movie. I can browse https://www.themoviedb.org/ without any issues so I am not IP blocked/throttled. Under Metadata downloaders TheMovieDB is highest on the list. Anyone else having this issue? Example: The Nice guys got identified correctly, but not by themoviedb so no additional info is added. Movie only found by IMDB: Should look like this, after I had to manually identify the movie (Took 5 tries this time): Log.txt Edited September 11, 2016 by Uroth
Luke 42213 Posted September 11, 2016 Posted September 11, 2016 Hi there, welcome. In order to best help you, please recreate the problem and then provide the information requested in how to report a problem. Thanks !
Luke 42213 Posted September 11, 2016 Posted September 11, 2016 I would try it again. The requested was aborted internally by Emby Server due to taking longer than 20 seconds.
Uroth 0 Posted September 11, 2016 Author Posted September 11, 2016 Thanks for looking into it. This isn't just one movie that it happens for. It is random, and sometimes I have to try and manually identify the movies with the correct ID 20+ times with the result screen just going being blank not finding the movie almost immediately.
Happy2Play 9802 Posted September 11, 2016 Posted September 11, 2016 Well there website has absolutely nothing to do with their api. So just because their website works doesn't mean their api is working properly.
Happy2Play 9802 Posted September 11, 2016 Posted September 11, 2016 defaulting to IMDB which adds almost no info for my new movies added to the server, lacking good posters, banners and backdrops. Does your media come with any nfo files? Emby does not get any information from IMDB, the IMDB number actually comes from TMDB or OMDB.
Uroth 0 Posted September 11, 2016 Author Posted September 11, 2016 No, no nfo files with my media when I add them. The only nfo files I use are the ones created by Emby after it adds and identify the movies.
Uroth 0 Posted September 17, 2016 Author Posted September 17, 2016 (edited) I still have the problem with Emby not finding any results when I try to identify with themovieDB ID. What could be causing this? Problems with the API? Anyone else been having these issues? Log.txt Edited September 17, 2016 by Uroth
Guest asrequested Posted September 17, 2016 Posted September 17, 2016 I always use media center master, first. It cleans up, renames etc.
Luke 42213 Posted September 17, 2016 Posted September 17, 2016 It looks like you are still having timeout issues. Are you on a slow connection?
Uroth 0 Posted September 17, 2016 Author Posted September 17, 2016 No, I am on a 100/100 connection. I can browse the website without any issues. Pinging www.themoviedb.org [54.240.184.19] with 32 bytes of data: Reply from 54.240.184.19: bytes=32 time=16ms TTL=247 Reply from 54.240.184.19: bytes=32 time=20ms TTL=247 Reply from 54.240.184.19: bytes=32 time=15ms TTL=247 Reply from 54.240.184.19: bytes=32 time=15ms TTL=247 Ping statistics for 54.240.184.19: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 15ms, Maximum = 20ms, Average = 16ms
Luke 42213 Posted September 17, 2016 Posted September 17, 2016 The website and api are completely different, as mentioned earlier
Uroth 0 Posted September 17, 2016 Author Posted September 17, 2016 Ok, What is the address / IP to the API so I can check if I have issues with it?
Luke 42213 Posted September 19, 2016 Posted September 19, 2016 i would just grab one of the urls from the logs you have posted.
neik 874 Posted May 5, 2020 Posted May 5, 2020 (edited) what is new in 1.3.4.0? If you are asking for the changelog, here it is: Treat reported image language of xx as having no language Edited May 5, 2020 by neik
Paxtor 8 Posted May 5, 2020 Posted May 5, 2020 If you are asking for the changelog, here it is: where?
Happy2Play 9802 Posted May 5, 2020 Posted May 5, 2020 where? Normally all the info is available via Emby Dashboard, click the "I" info icon in Alerts.
Paxtor 8 Posted May 6, 2020 Posted May 6, 2020 "Treat reported image language of xx as having no language"thank you.
