dimmiemedia 3 Posted September 9, 2016 Posted September 9, 2016 Hi there.. Something strange happends when i want to delete a label in a movie for example, the window is floating down an nothing will be deleted.
Luke 42186 Posted September 9, 2016 Posted September 9, 2016 Hi, what do you mean label? do you mean a tag?
dimmiemedia 3 Posted September 9, 2016 Author Posted September 9, 2016 I mean when you want to delete a excisting label
Happy2Play 9800 Posted September 9, 2016 Posted September 9, 2016 What server version? Still not sure what you are calling a label.
dimmiemedia 3 Posted September 9, 2016 Author Posted September 9, 2016 I added a screen image to http://www.dimmiemedia.nl/screens/label.png Server version: 3.0.7000.0
Happy2Play 9800 Posted September 9, 2016 Posted September 9, 2016 Okay a translation for Tags. @@Luke I can confirm and the when you select delete in "Edit Info" you are zapped back to the Item detail screen. When you go to Metadata Manager all is well so it is specific to Item edit info. All delete buttons zap back to Item details. I tested in beta so issue in all versions.
dimmiemedia 3 Posted September 10, 2016 Author Posted September 10, 2016 In the new build it works great! Thanks
