b0dyr0ck2006 57 Posted September 9, 2016 Posted September 9, 2016 Yesterday (8th September) I was playing a show remotely at my girlfriends and we were having numerous issues with the playback pausing and glitching. Over the hour shows it must have stopped half a dozen times and wouldnt playback for up to 2 minutes. I tried many things from rebooting her router, to rebooting my server, trying different devices etc. This isnt the first time it has happened there so I initially thought it was a problem with here internet but she has a 3MB connection so should be fine there. I've attached the logs so you can see if there is any issues. Also, I cant tell if other users are having playback issues from end unless they tell me. Is there any way around this? Many Thanks LOG.txt
ebr 16307 Posted September 9, 2016 Posted September 9, 2016 Sounds like a network issue to me. 3Mb isn't very fast when it comes to streaming videos and I would expect potential issues at that speed (depending on bitrate of content). Remember, that number is basically a max, not a minimum. Actual throughput can fall way below that at any given time.
b0dyr0ck2006 57 Posted September 9, 2016 Author Posted September 9, 2016 MB not Mb. Or should I say Megabytes not Megabytes
ebr 16307 Posted September 9, 2016 Posted September 9, 2016 Really? I've never seen a provider quote speeds in MB/s... Looking at your log, you were requesting video at 3.8Mb/s. Is the app set to Auto or a specific rate?
b0dyr0ck2006 57 Posted September 9, 2016 Author Posted September 9, 2016 The app is set to auto, although after a while I wound it back to 1mb just so we got playback. I'm not talking about provider quoted speeds, I can give you the registered download speed the router is providing if you wish. I just translate bites into bytes in my head for ease
b0dyr0ck2006 57 Posted September 9, 2016 Author Posted September 9, 2016 I guess so mate. I can only understand the logs at a basic level, if that is what it is reporting then I have to agree with you...
Luke 42186 Posted September 9, 2016 Posted September 9, 2016 It might be one of those situations where they allow a higher speed for a brief burst. I'll have to think about how to handle that. Thanks. 1
b0dyr0ck2006 57 Posted September 9, 2016 Author Posted September 9, 2016 After I forced the playback down it seems to be ok, so should I force this on all users at a server level if they find they are having playback issues?
Happy2Play 9801 Posted September 9, 2016 Posted September 9, 2016 That depends on your upload speed, this will determine the streaming limit you impose on multiple users to handle multiple streams.
b0dyr0ck2006 57 Posted September 9, 2016 Author Posted September 9, 2016 I very rarely have more than one user consecutively online. My upload speed is 9999Kbps (9.76MB)
Happy2Play 9801 Posted September 9, 2016 Posted September 9, 2016 (edited) That would megabits (Mb) per second not megabytes (MB) per second. So you have an upload speed of about 1.25MB or 9.99Mb. But with media it is all about the bitrate. Edited September 9, 2016 by Happy2Play 1
b0dyr0ck2006 57 Posted September 9, 2016 Author Posted September 9, 2016 My mistake, you are perfectly correct. It's been a long day
ebr 16307 Posted September 9, 2016 Posted September 9, 2016 so she only has 3 but it detected 3.8? No, he said she had 3 MBYTES/s speed. The app detected around 4 Mbits/s (if it was on auto for that log). But, as determined later, even if her speed is that fast, his upload at the server end is slower. Still just sounds like limited bandwidth to me.
b0dyr0ck2006 57 Posted September 9, 2016 Author Posted September 9, 2016 (edited) My connection: Download: 40000kbps - 40 Megabits - 5 Megabytes Upload: 9999kbps - 9.999 Megabits - 1.249 Megabytes Her connection: Download: 25000kbps - 25 Megabits - 3.125 Megabytes I have limited my Streaming bitrate on the server and will try again next time I am round there Edited September 9, 2016 by b0dyr0ck2006
ebr 16307 Posted September 9, 2016 Posted September 9, 2016 Okay, the limiting factor, obviously, is your upload bandwidth. But, as I said before, in my experience, actual throughput can vary widely at any given time so it is usually best to find a hard setting in the app that works all the time. 1
b0dyr0ck2006 57 Posted September 11, 2016 Author Posted September 11, 2016 Okay, the limiting factor, obviously, is your upload bandwidth. But, as I said before, in my experience, actual throughput can vary widely at any given time so it is usually best to find a hard setting in the app that works all the time. Surely, in the view of complete ease of use for non tech savvy users, 'Auto' should be the default setting and emby should communicate with the server to ascertain the correct playback settings?
Guest asrequested Posted September 11, 2016 Posted September 11, 2016 I believe it does test the bandwidth, but it's not dynamic. So if there's a momentary dip it can't adjust for that. I just ran a new cable, because I was having some connection issues. Now it's stablized. But there could also isp fluctuations. 1
Luke 42186 Posted September 11, 2016 Posted September 11, 2016 Auto is the default and does communicate with the server. 1
b0dyr0ck2006 57 Posted September 22, 2016 Author Posted September 22, 2016 So tested this yesterday remotely and even knocking the playback down to as low as 720 1mp I was getting pauses and playback issues. I tried it again this morning at work when I know the server is at idle and the internet is completely free, using my mobile (iOS) I still got pauses and stuttering. http://176.24.35.185:8096/emby/videos/61685dc1dea255b8bcd5ed3662e80ee8/hls1/main/0.ts?DeviceId=8CF18957-546D-4214-A480-947618B0AFEF&MediaSourceId=61685dc1dea255b8bcd5ed3662e80ee8&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=1499071&AudioBitrate=192000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=2afa4a2ca0804d0eaea01658027c2a50&api_key=92867650a7ca445d846f9722a42146c1&CopyTimestamps=false&EnableSubtitlesInManifest=false&Tag=9b7ee268746bac966072c75b4c1be78e {"Protocol":"File","Id":"61685dc1dea255b8bcd5ed3662e80ee8","Path":"E:\\10 Cloverfield Lane.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/AC3","ETag":"9b7ee268746bac966072c75b4c1be78e","RunTimeTicks":62120640000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/60000","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":6123547,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":800,"Width":1920,"AverageFrameRate":29.97003,"RealFrameRate":29.97003,"Profile":"High","Type":"Video","AspectRatio":"2.40:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng Dolby Digital stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"srt","Language":"eng","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"E:\\10 Cloverfield Lane.eng.srt"}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":6123547,"RequiredHttpHeaders":{}} C:\Users\Colin\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -i file:"E:\10 Cloverfield Lane.mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -tune zerolatency -b:v 1499071 -maxrate 1499071 -bufsize 2998142 -vsync -1 -profile:v high -level 41 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -copyts -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -af "adelay=1,aresample=async=1" -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -hls_time 3 -start_number 0 -hls_list_size 0 -y "E:\Transcode\transcoding-temp\d54a914845b62a82bd96e0004050a79e.m3u8" ffmpeg version N-79277-g0c90b2e Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [h264 @ 000000000059dda0] SEI type 5 size 5560 truncated at 200 [h264 @ 000000000059dda0] SEI type 5 size 5560 truncated at 192 Input #0, matroska,webm, from 'file:E:\10 Cloverfield Lane.mkv': Metadata: title : EVO encoder : libebml v1.3.0 + libmatroska v1.4.1 creation_time : 2016-05-04 20:29:09 Duration: 01:43:32.06, start: 0.000000, bitrate: 6123 kb/s Stream #0:0: Video: h264 (High), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc (default) Stream #0:1(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default) [libx264 @ 0000000002bff960] using SAR=399/400 [libx264 @ 0000000002bff960] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0000000002bff960] profile High, level 4.1 Output #0, hls, to 'E:\Transcode\transcoding-temp\d54a914845b62a82bd96e0004050a79e.m3u8': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1280x532 [SAR 399:400 DAR 12:5], q=-1--1, 1499 kb/s, 29.97 fps, 90k tbn, 29.97 tbc (default) Metadata: encoder : Lavc57.34.100 libx264 Side data: cpb: bitrate max/min/avg: 1499000/0/1499000 buffer size: 2998000 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: encoder : Lavc57.34.100 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) Press [q] to stop, [?] for help [h264 @ 0000000002c0f7a0] SEI type 5 size 5560 truncated at 192 frame= 77 fps=0.0 q=16.0 size=N/A time=00:00:02.85 bitrate=N/A speed=5.72x frame= 177 fps=177 q=20.0 size=N/A time=00:00:06.22 bitrate=N/A speed=6.23x frame= 267 fps=178 q=21.0 size=N/A time=00:00:09.19 bitrate=N/A speed=6.13x frame= 333 fps=166 q=24.0 size=N/A time=00:00:11.28 bitrate=N/A speed=5.64x frame= 397 fps=159 q=28.0 size=N/A time=00:00:13.46 bitrate=N/A speed=5.38x frame= 471 fps=157 q=25.0 size=N/A time=00:00:15.89 bitrate=N/A speed=5.29x frame= 546 fps=156 q=26.0 size=N/A time=00:00:18.51 bitrate=N/A speed=5.28x frame= 623 fps=156 q=25.0 size=N/A time=00:00:20.97 bitrate=N/A speed=5.24x frame= 708 fps=157 q=19.0 size=N/A time=00:00:23.91 bitrate=N/A speed= 5.3x frame= 794 fps=158 q=26.0 size=N/A time=00:00:26.66 bitrate=N/A speed=5.32x frame= 870 fps=158 q=28.0 size=N/A time=00:00:29.33 bitrate=N/A speed=5.32x frame= 949 fps=158 q=27.0 size=N/A time=00:00:32.02 bitrate=N/A speed=5.33x frame= 1029 fps=158 q=27.0 size=N/A time=00:00:34.66 bitrate=N/A speed=5.32x frame= 1118 fps=159 q=20.0 size=N/A time=00:00:37.46 bitrate=N/A speed=5.34x frame= 1219 fps=162 q=21.0 size=N/A time=00:00:40.87 bitrate=N/A speed=5.44x frame= 1318 fps=165 q=22.0 size=N/A time=00:00:44.18 bitrate=N/A speed=5.51x frame= 1398 fps=164 q=26.0 size=N/A time=00:00:46.99 bitrate=N/A speed=5.52x frame= 1475 fps=164 q=27.0 size=N/A time=00:00:49.57 bitrate=N/A speed= 5.5x frame= 1555 fps=163 q=26.0 size=N/A time=00:00:52.18 bitrate=N/A speed=5.48x frame= 1629 fps=163 q=24.0 size=N/A time=00:00:54.50 bitrate=N/A speed=5.44x frame= 1703 fps=162 q=24.0 size=N/A time=00:00:57.10 bitrate=N/A speed=5.43x frame= 1779 fps=161 q=25.0 size=N/A time=00:00:59.66 bitrate=N/A speed=5.42x frame= 1855 fps=161 q=25.0 size=N/A time=00:01:02.25 bitrate=N/A speed=5.41x frame= 1930 fps=161 q=26.0 size=N/A time=00:01:04.55 bitrate=N/A speed=5.37x frame= 2005 fps=160 q=26.0 size=N/A time=00:01:07.11 bitrate=N/A speed=5.36x frame= 2078 fps=160 q=25.0 size=N/A time=00:01:09.67 bitrate=N/A speed=5.35x frame= 2153 fps=159 q=25.0 size=N/A time=00:01:11.97 bitrate=N/A speed=5.32x frame= 2218 fps=158 q=27.0 size=N/A time=00:01:14.34 bitrate=N/A speed= 5.3x frame= 2287 fps=158 q=25.0 size=N/A time=00:01:16.50 bitrate=N/A speed=5.27x frame= 2354 fps=157 q=29.0 size=N/A time=00:01:18.76 bitrate=N/A speed=5.24x frame= 2425 fps=156 q=31.0 size=N/A time=00:01:21.13 bitrate=N/A speed=5.23x frame= 2502 fps=156 q=32.0 size=N/A time=00:01:23.69 bitrate=N/A speed=5.22x frame= 2577 fps=156 q=31.0 size=N/A time=00:01:26.16 bitrate=N/A speed=5.21x frame= 2648 fps=156 q=35.0 size=N/A time=00:01:28.66 bitrate=N/A speed=5.21x frame= 2721 fps=155 q=27.0 size=N/A time=00:01:30.98 bitrate=N/A speed=5.19x frame= 2795 fps=155 q=31.0 size=N/A time=00:01:33.46 bitrate=N/A speed=5.18x frame= 2875 fps=155 q=26.0 size=N/A time=00:01:36.17 bitrate=N/A speed=5.19x frame= 2956 fps=155 q=21.0 size=N/A time=00:01:39.02 bitrate=N/A speed= 5.2x frame= 3035 fps=155 q=25.0 size=N/A time=00:01:41.48 bitrate=N/A speed= 5.2x frame= 3113 fps=155 q=26.0 size=N/A time=00:01:44.04 bitrate=N/A speed=5.19x frame= 3188 fps=155 q=25.0 size=N/A time=00:01:46.64 bitrate=N/A speed= 5.2x frame= 3266 fps=155 q=27.0 size=N/A time=00:01:49.22 bitrate=N/A speed=5.19x frame= 3348 fps=155 q=25.0 size=N/A time=00:01:51.91 bitrate=N/A speed= 5.2x frame= 3423 fps=155 q=25.0 size=N/A time=00:01:54.41 bitrate=N/A speed=5.19x frame= 3496 fps=155 q=23.0 size=N/A time=00:01:56.97 bitrate=N/A speed=5.19x frame= 3574 fps=155 q=26.0 size=N/A time=00:01:59.53 bitrate=N/A speed=5.19x frame= 3653 fps=155 q=25.0 size=N/A time=00:02:02.06 bitrate=N/A speed=5.19x frame= 3731 fps=155 q=25.0 size=N/A time=00:02:04.62 bitrate=N/A speed=5.18x frame= 3809 fps=155 q=26.0 size=N/A time=00:02:07.25 bitrate=N/A speed=5.19x frame= 3885 fps=155 q=27.0 size=N/A time=00:02:10.02 bitrate=N/A speed=5.19x frame= 3965 fps=155 q=27.0 size=N/A time=00:02:12.65 bitrate=N/A speed=5.19x frame= 4035 fps=155 q=26.0 size=N/A time=00:02:14.95 bitrate=N/A speed=5.18x frame= 4106 fps=155 q=21.0 size=N/A time=00:02:17.36 bitrate=N/A speed=5.17x frame= 4177 fps=154 q=21.0 size=N/A time=00:02:19.73 bitrate=N/A speed=5.17x frame= 4250 fps=154 q=22.0 size=N/A time=00:02:21.93 bitrate=N/A speed=5.15x frame= 4319 fps=154 q=26.0 size=N/A time=00:02:24.23 bitrate=N/A speed=5.14x frame= 4390 fps=154 q=25.0 size=N/A time=00:02:26.60 bitrate=N/A speed=5.14x frame= 4455 fps=153 q=25.0 size=N/A time=00:02:28.90 bitrate=N/A speed=5.13x frame= 4521 fps=153 q=24.0 size=N/A time=00:02:31.12 bitrate=N/A speed=5.11x frame= 4587 fps=153 q=21.0 size=N/A time=00:02:33.25 bitrate=N/A speed= 5.1x frame= 4648 fps=152 q=25.0 size=N/A time=00:02:35.30 bitrate=N/A speed=5.08x frame= 4712 fps=152 q=24.0 size=N/A time=00:02:37.54 bitrate=N/A speed=5.07x frame= 4782 fps=151 q=22.0 size=N/A time=00:02:39.82 bitrate=N/A speed=5.06x frame= 4848 fps=151 q=28.0 size=N/A time=00:02:41.89 bitrate=N/A speed=5.05x frame= 4912 fps=151 q=28.0 size=N/A time=00:02:44.18 bitrate=N/A speed=5.04x frame= 4978 fps=150 q=29.0 size=N/A time=00:02:46.25 bitrate=N/A speed=5.03x frame= 5040 fps=150 q=32.0 size=N/A time=00:02:48.34 bitrate=N/A speed=5.01x frame= 5103 fps=150 q=31.0 size=N/A time=00:02:50.47 bitrate=N/A speed= 5x frame= 5168 fps=149 q=31.0 size=N/A time=00:02:52.71 bitrate=N/A speed=4.99x frame= 5236 fps=149 q=25.0 size=N/A time=00:02:54.86 bitrate=N/A speed=4.98x frame= 5304 fps=149 q=27.0 size=N/A time=00:02:57.19 bitrate=N/A speed=4.98x frame= 5374 fps=149 q=26.0 size=N/A time=00:02:59.47 bitrate=N/A speed=4.97x frame= 5441 fps=149 q=25.0 size=N/A time=00:03:01.80 bitrate=N/A speed=4.97x frame= 5509 fps=148 q=30.0 size=N/A time=00:03:03.97 bitrate=N/A speed=4.96x frame= 5573 fps=148 q=28.0 size=N/A time=00:03:06.21 bitrate=N/A speed=4.95x frame= 5637 fps=148 q=29.0 size=N/A time=00:03:08.37 bitrate=N/A speed=4.94x frame= 5703 fps=148 q=30.0 size=N/A time=00:03:10.42 bitrate=N/A speed=4.93x frame= 5769 fps=147 q=29.0 size=N/A time=00:03:12.74 bitrate=N/A speed=4.93x frame= 5839 fps=147 q=26.0 size=N/A time=00:03:15.11 bitrate=N/A speed=4.92x frame= 5908 fps=147 q=26.0 size=N/A time=00:03:17.33 bitrate=N/A speed=4.92x frame= 5977 fps=147 q=23.0 size=N/A time=00:03:19.63 bitrate=N/A speed=4.91x frame= 6041 fps=147 q=24.0 size=N/A time=00:03:21.83 bitrate=N/A speed=4.91x frame= 6107 fps=147 q=25.0 size=N/A time=00:03:24.05 bitrate=N/A speed= 4.9x frame= 6177 fps=147 q=26.0 size=N/A time=00:03:26.25 bitrate=N/A speed=4.89x frame= 6271 fps=147 q=23.0 size=N/A time=00:03:29.49 bitrate=N/A speed=4.91x frame= 6336 fps=147 q=26.0 size=N/A time=00:03:31.73 bitrate=N/A speed=4.91x frame= 6401 fps=147 q=27.0 size=N/A time=00:03:33.90 bitrate=N/A speed= 4.9x frame= 6470 fps=146 q=25.0 size=N/A time=00:03:36.02 bitrate=N/A speed=4.89x frame= 6536 fps=146 q=24.0 size=N/A time=00:03:38.32 bitrate=N/A speed=4.89x frame= 6598 fps=146 q=30.0 size=N/A time=00:03:40.33 bitrate=N/A speed=4.88x frame= 6661 fps=146 q=26.0 size=N/A time=00:03:42.42 bitrate=N/A speed=4.87x frame= 6726 fps=146 q=25.0 size=N/A time=00:03:44.61 bitrate=N/A speed=4.86x frame= 6796 fps=146 q=24.0 size=N/A time=00:03:47.09 bitrate=N/A speed=4.86x frame= 6855 fps=145 q=25.0 size=N/A time=00:03:48.97 bitrate=N/A speed=4.85x frame= 6922 fps=145 q=25.0 size=N/A time=00:03:51.14 bitrate=N/A speed=4.85x frame= 6993 fps=145 q=21.0 size=N/A time=00:03:53.45 bitrate=N/A speed=4.84x frame= 7061 fps=145 q=20.0 size=N/A time=00:03:55.79 bitrate=N/A speed=4.84x frame= 7135 fps=145 q=21.0 size=N/A time=00:03:58.31 bitrate=N/A speed=4.84x frame= 7206 fps=145 q=23.0 size=N/A time=00:04:00.66 bitrate=N/A speed=4.84x frame= 7274 fps=145 q=23.0 size=N/A time=00:04:02.92 bitrate=N/A speed=4.84x frame= 7345 fps=145 q=22.0 size=N/A time=00:04:05.41 bitrate=N/A speed=4.84x frame= 7415 fps=145 q=22.0 size=N/A time=00:04:07.78 bitrate=N/A speed=4.84x frame= 7489 fps=145 q=22.0 size=N/A time=00:04:10.19 bitrate=N/A speed=4.84x frame= 7565 fps=145 q=22.0 size=N/A time=00:04:12.58 bitrate=N/A speed=4.84x frame= 7642 fps=145 q=21.0 size=N/A time=00:04:15.33 bitrate=N/A speed=4.84x frame= 7714 fps=145 q=21.0 size=N/A time=00:04:17.70 bitrate=N/A speed=4.84x frame= 7783 fps=145 q=21.0 size=N/A time=00:04:20.01 bitrate=N/A speed=4.84x frame= 7860 fps=145 q=21.0 size=N/A time=00:04:22.48 bitrate=N/A speed=4.84x frame= 7935 fps=145 q=21.0 size=N/A time=00:04:24.93 bitrate=N/A speed=4.84x frame= 8007 fps=145 q=20.0 size=N/A time=00:04:27.56 bitrate=N/A speed=4.84x frame= 8083 fps=145 q=21.0 size=N/A time=00:04:29.97 bitrate=N/A speed=4.84x frame= 8134 fps=145 q=21.0 size=N/A time=00:04:31.76 bitrate=N/A speed=4.83x frame= 8176 fps=144 q=20.0 size=N/A time=00:04:33.04 bitrate=N/A speed=4.81x frame= 8220 fps=143 q=21.0 size=N/A time=00:04:34.53 bitrate=N/A speed=4.79x frame= 8262 fps=143 q=20.0 size=N/A time=00:04:35.94 bitrate=N/A speed=4.77x frame= 8298 fps=142 q=20.0 size=N/A time=00:04:37.22 bitrate=N/A speed=4.75x frame= 8332 fps=142 q=21.0 size=N/A time=00:04:38.18 bitrate=N/A speed=4.73x frame= 8363 fps=141 q=18.0 size=N/A time=00:04:39.21 bitrate=N/A speed= 4.7x frame= 8385 fps=140 q=21.0 size=N/A time=00:04:39.97 bitrate=N/A speed=4.68x frame= 8429 fps=140 q=21.0 size=N/A time=00:04:41.45 bitrate=N/A speed=4.66x frame= 8457 fps=139 q=21.0 size=N/A time=00:04:42.41 bitrate=N/A speed=4.64x frame= 8492 fps=138 q=21.0 size=N/A time=00:04:43.54 bitrate=N/A speed=4.62x frame= 8514 fps=138 q=21.0 size=N/A time=00:04:44.39 bitrate=N/A speed=4.59x frame= 8557 fps=137 q=20.0 size=N/A time=00:04:45.67 bitrate=N/A speed=4.58x frame= 8596 fps=137 q=20.0 size=N/A time=00:04:47.01 bitrate=N/A speed=4.56x frame= 8618 fps=136 q=21.0 size=N/A time=00:04:47.82 bitrate=N/A speed=4.53x frame= 8655 fps=135 q=22.0 size=N/A time=00:04:48.93 bitrate=N/A speed=4.52x frame= 8686 fps=135 q=20.0 size=N/A time=00:04:50.02 bitrate=N/A speed= 4.5x frame= 8715 fps=134 q=21.0 size=N/A time=00:04:50.98 bitrate=N/A speed=4.48x frame= 8740 fps=133 q=18.0 size=N/A time=00:04:51.86 bitrate=N/A speed=4.45x frame= 8775 fps=133 q=20.0 size=N/A time=00:04:53.09 bitrate=N/A speed=4.43x frame= 8818 fps=132 q=21.0 size=N/A time=00:04:54.50 bitrate=N/A speed=4.42x frame= 8841 fps=132 q=21.0 size=N/A time=00:04:55.21 bitrate=N/A speed= 4.4x frame= 8876 fps=131 q=20.0 size=N/A time=00:04:56.49 bitrate=N/A speed=4.38x frame= 8898 fps=130 q=22.0 size=N/A time=00:04:57.23 bitrate=N/A speed=4.36x frame= 8933 fps=130 q=21.0 size=N/A time=00:04:58.41 bitrate=N/A speed=4.34x frame= 8968 fps=129 q=21.0 size=N/A time=00:04:59.56 bitrate=N/A speed=4.32x frame= 9002 fps=129 q=21.0 size=N/A time=00:05:00.58 bitrate=N/A speed=4.31x frame= 9030 fps=128 q=21.0 size=N/A time=00:05:01.46 bitrate=N/A speed=4.29x frame= 9074 fps=128 q=21.0 size=N/A time=00:05:02.99 bitrate=N/A speed=4.27x frame= 9111 fps=128 q=20.0 size=N/A time=00:05:04.34 bitrate=N/A speed=4.26x frame= 9138 fps=127 q=21.0 size=N/A time=00:05:05.17 bitrate=N/A speed=4.24x frame= 9165 fps=127 q=21.0 size=N/A time=00:05:05.96 bitrate=N/A speed=4.22x frame= 9195 fps=126 q=22.0 size=N/A time=00:05:07.17 bitrate=N/A speed=4.21x frame= 9221 fps=125 q=20.0 size=N/A time=00:05:07.94 bitrate=N/A speed=4.19x frame= 9255 fps=125 q=22.0 size=N/A time=00:05:09.01 bitrate=N/A speed=4.18x frame= 9292 fps=125 q=21.0 size=N/A time=00:05:10.29 bitrate=N/A speed=4.16x frame= 9336 fps=124 q=19.0 size=N/A time=00:05:11.65 bitrate=N/A speed=4.15x frame= 9371 fps=124 q=20.0 size=N/A time=00:05:12.93 bitrate=N/A speed=4.14x frame= 9395 fps=124 q=21.0 size=N/A time=00:05:13.62 bitrate=N/A speed=4.12x frame= 9418 fps=123 q=22.0 size=N/A time=00:05:14.38 bitrate=N/A speed= 4.1x frame= 9456 fps=123 q=19.0 size=N/A time=00:05:15.73 bitrate=N/A speed=4.09x frame= 9487 fps=122 q=23.0 size=N/A time=00:05:16.82 bitrate=N/A speed=4.08x frame= 9519 fps=122 q=22.0 size=N/A time=00:05:17.90 bitrate=N/A speed=4.07x frame= 9551 fps=121 q=22.0 size=N/A time=00:05:19.08 bitrate=N/A speed=4.05x frame= 9570 fps=121 q=23.0 size=N/A time=00:05:19.53 bitrate=N/A speed=4.03x frame= 9593 fps=120 q=28.0 size=N/A time=00:05:20.29 bitrate=N/A speed=4.02x frame= 9618 fps=120 q=29.0 size=N/A time=00:05:21.23 bitrate=N/A speed= 4x frame= 9647 fps=119 q=25.0 size=N/A time=00:05:22.06 bitrate=N/A speed=3.99x frame= 9672 fps=119 q=21.0 size=N/A time=00:05:23.09 bitrate=N/A speed=3.97x frame= 9710 fps=119 q=19.0 size=N/A time=00:05:24.37 bitrate=N/A speed=3.96x frame= 9740 fps=118 q=25.0 size=N/A time=00:05:25.16 bitrate=N/A speed=3.95x frame= 9777 fps=118 q=25.0 size=N/A time=00:05:26.50 bitrate=N/A speed=3.94x frame= 9803 fps=117 q=28.0 size=N/A time=00:05:27.25 bitrate=N/A speed=3.92x frame= 9832 fps=117 q=19.0 size=N/A time=00:05:28.27 bitrate=N/A speed=3.91x frame= 9863 fps=117 q=19.0 size=N/A time=00:05:29.30 bitrate=N/A speed= 3.9x frame= 9893 fps=116 q=24.0 size=N/A time=00:05:30.32 bitrate=N/A speed=3.89x frame= 9930 fps=116 q=22.0 size=N/A time=00:05:31.56 bitrate=N/A speed=3.88x frame= 9966 fps=116 q=21.0 size=N/A time=00:05:32.69 bitrate=N/A speed=3.87x frame=10002 fps=116 q=23.0 size=N/A time=00:05:34.03 bitrate=N/A speed=3.86x frame=10043 fps=115 q=22.0 size=N/A time=00:05:35.25 bitrate=N/A speed=3.85x frame=10090 fps=115 q=22.0 size=N/A time=00:05:36.91 bitrate=N/A speed=3.85x frame=10128 fps=115 q=21.0 size=N/A time=00:05:38.19 bitrate=N/A speed=3.84x frame=10164 fps=115 q=19.0 size=N/A time=00:05:39.34 bitrate=N/A speed=3.83x frame=10217 fps=115 q=19.0 size=N/A time=00:05:41.14 bitrate=N/A speed=3.83x frame=10264 fps=115 q=19.0 size=N/A time=00:05:42.67 bitrate=N/A speed=3.83x frame=10316 fps=115 q=19.0 size=N/A time=00:05:44.59 bitrate=N/A speed=3.83x frame=10365 fps=114 q=19.0 size=N/A time=00:05:46.13 bitrate=N/A speed=3.82x frame=10417 fps=114 q=19.0 size=N/A time=00:05:47.86 bitrate=N/A speed=3.82x frame=10487 fps=114 q=19.0 size=N/A time=00:05:50.16 bitrate=N/A speed=3.82x frame=10521 fps=114 q=16.0 size=N/A time=00:05:51.21 bitrate=N/A speed= 3.8x frame=10561 fps=113 q=19.0 size=N/A time=00:05:52.81 bitrate=N/A speed=3.79x frame=10600 fps=113 q=19.0 size=N/A time=00:05:53.89 bitrate=N/A speed=3.78x frame=10642 fps=113 q=19.0 size=N/A time=00:05:55.34 bitrate=N/A speed=3.78x frame=10682 fps=113 q=22.0 size=N/A time=00:05:56.65 bitrate=N/A speed=3.77x frame=10716 fps=113 q=22.0 size=N/A time=00:05:57.73 bitrate=N/A speed=3.76x frame=10746 fps=112 q=24.0 size=N/A time=00:05:58.80 bitrate=N/A speed=3.75x frame=10787 fps=112 q=23.0 size=N/A time=00:06:00.10 bitrate=N/A speed=3.75x frame=10831 fps=112 q=22.0 size=N/A time=00:06:01.51 bitrate=N/A speed=3.74x frame=10867 fps=112 q=23.0 size=N/A time=00:06:02.96 bitrate=N/A speed=3.74x frame=10911 fps=112 q=23.0 size=N/A time=00:06:04.45 bitrate=N/A speed=3.73x frame=10960 fps=112 q=23.0 size=N/A time=00:06:05.86 bitrate=N/A speed=3.73x frame=10988 fps=111 q=24.0 size=N/A time=00:06:06.95 bitrate=N/A speed=3.72x frame=11024 fps=111 q=23.0 size=N/A time=00:06:08.02 bitrate=N/A speed=3.71x frame=11065 fps=111 q=24.0 size=N/A time=00:06:09.42 bitrate=N/A speed=3.71x frame=11103 fps=111 q=23.0 size=N/A time=00:06:10.73 bitrate=N/A speed= 3.7x frame=11150 fps=111 q=21.0 size=N/A time=00:06:12.20 bitrate=N/A speed=3.69x frame=11188 fps=111 q=24.0 size=N/A time=00:06:13.48 bitrate=N/A speed=3.69x frame=11221 fps=110 q=24.0 size=N/A time=00:06:14.80 bitrate=N/A speed=3.68x frame=11263 fps=110 q=25.0 size=N/A time=00:06:16.21 bitrate=N/A speed=3.68x frame=11304 fps=110 q=26.0 size=N/A time=00:06:17.49 bitrate=N/A speed=3.67x frame=11350 fps=110 q=25.0 size=N/A time=00:06:18.98 bitrate=N/A speed=3.67x frame=11382 fps=110 q=25.0 size=N/A time=00:06:19.98 bitrate=N/A speed=3.66x frame=11417 fps=109 q=23.0 size=N/A time=00:06:21.26 bitrate=N/A speed=3.66x frame=11448 fps=109 q=25.0 size=N/A time=00:06:22.31 bitrate=N/A speed=3.65x frame=11493 fps=109 q=24.0 size=N/A time=00:06:23.89 bitrate=N/A speed=3.64x frame=11526 fps=109 q=24.0 size=N/A time=00:06:24.74 bitrate=N/A speed=3.63x frame=11565 fps=109 q=25.0 size=N/A time=00:06:26.34 bitrate=N/A speed=3.63x frame=11601 fps=109 q=28.0 size=N/A time=00:06:27.28 bitrate=N/A speed=3.62x frame=11633 fps=108 q=26.0 size=N/A time=00:06:28.33 bitrate=N/A speed=3.62x frame=11678 fps=108 q=26.0 size=N/A time=00:06:29.86 bitrate=N/A speed=3.61x frame=11717 fps=108 q=26.0 size=N/A time=00:06:31.27 bitrate=N/A speed=3.61x frame=11753 fps=108 q=25.0 size=N/A time=00:06:32.46 bitrate=N/A speed= 3.6x frame=11792 fps=108 q=25.0 size=N/A time=00:06:33.81 bitrate=N/A speed= 3.6x frame=11826 fps=108 q=25.0 size=N/A time=00:06:34.83 bitrate=N/A speed=3.59x frame=11862 fps=107 q=25.0 size=N/A time=00:06:35.98 bitrate=N/A speed=3.59x frame=11905 fps=107 q=25.0 size=N/A time=00:06:37.52 bitrate=N/A speed=3.58x frame=11937 fps=107 q=24.0 size=N/A time=00:06:38.54 bitrate=N/A speed=3.58x frame=11969 fps=107 q=25.0 size=N/A time=00:06:39.59 bitrate=N/A speed=3.57x frame=12002 fps=107 q=23.0 size=N/A time=00:06:40.78 bitrate=N/A speed=3.57x frame=12048 fps=107 q=24.0 size=N/A time=00:06:42.38 bitrate=N/A speed=3.56x frame=12085 fps=107 q=25.0 size=N/A time=00:06:43.41 bitrate=N/A speed=3.56x frame=12127 fps=106 q=24.0 size=N/A time=00:06:44.90 bitrate=N/A speed=3.55x frame=12160 fps=106 q=25.0 size=N/A time=00:06:45.97 bitrate=N/A speed=3.55x frame=12202 fps=106 q=24.0 size=N/A time=00:06:47.50 bitrate=N/A speed=3.54x frame=12246 fps=106 q=25.0 size=N/A time=00:06:48.74 bitrate=N/A speed=3.54x frame=12289 fps=106 q=29.0 size=N/A time=00:06:50.28 bitrate=N/A speed=3.53x frame=12320 fps=106 q=32.0 size=N/A time=00:06:51.30 bitrate=N/A speed=3.53x frame=12357 fps=105 q=27.0 size=N/A time=00:06:52.58 bitrate=N/A speed=3.52x frame=12390 fps=105 q=26.0 size=N/A time=00:06:53.61 bitrate=N/A speed=3.51x frame=12435 fps=105 q=26.0 size=N/A time=00:06:55.18 bitrate=N/A speed=3.51x frame=12473 fps=105 q=26.0 size=N/A time=00:06:56.46 bitrate=N/A speed=3.51x frame=12537 fps=105 q=28.0 size=N/A time=00:06:58.60 bitrate=N/A speed=3.51x frame=12598 fps=105 q=27.0 size=N/A time=00:07:00.65 bitrate=N/A speed=3.51x frame=12665 fps=105 q=25.0 size=N/A time=00:07:02.80 bitrate=N/A speed=3.52x frame=12730 fps=105 q=25.0 size=N/A time=00:07:05.04 bitrate=N/A speed=3.52x frame=12802 fps=106 q=24.0 size=N/A time=00:07:07.28 bitrate=N/A speed=3.52x frame=12872 fps=106 q=24.0 size=N/A time=00:07:09.80 bitrate=N/A speed=3.53x frame=12946 fps=106 q=24.0 size=N/A time=00:07:12.14 bitrate=N/A speed=3.54x frame=13027 fps=106 q=21.0 size=N/A time=00:07:14.85 bitrate=N/A speed=3.54x frame=13106 fps=106 q=23.0 size=N/A time=00:07:17.71 bitrate=N/A speed=3.55x frame=13183 fps=107 q=24.0 size=N/A time=00:07:20.21 bitrate=N/A speed=3.56x frame=13258 fps=107 q=22.0 size=N/A time=00:07:22.66 bitrate=N/A speed=3.56x frame=13332 fps=107 q=25.0 size=N/A time=00:07:25.07 bitrate=N/A speed=3.57x frame=13405 fps=107 q=25.0 size=N/A time=00:07:27.65 bitrate=N/A speed=3.57x frame=13475 fps=107 q=25.0 size=N/A time=00:07:29.83 bitrate=N/A speed=3.58x frame=13545 fps=107 q=26.0 size=N/A time=00:07:32.11 bitrate=N/A speed=3.58x frame=13611 fps=107 q=25.0 size=N/A time=00:07:34.37 bitrate=N/A speed=3.58x frame=13681 fps=108 q=22.0 size=N/A time=00:07:36.91 bitrate=N/A speed=3.59x frame=13757 fps=108 q=25.0 size=N/A time=00:07:39.30 bitrate=N/A speed= 3.6x frame=13829 fps=108 q=29.0 size=N/A time=00:07:41.54 bitrate=N/A speed= 3.6x frame=13897 fps=108 q=27.0 size=N/A time=00:07:43.89 bitrate=N/A speed= 3.6x frame=13956 fps=108 q=26.0 size=N/A time=00:07:45.81 bitrate=N/A speed= 3.6x frame=14023 fps=108 q=27.0 size=N/A time=00:07:48.05 bitrate=N/A speed=3.61x frame=14092 fps=108 q=24.0 size=N/A time=00:07:50.37 bitrate=N/A speed=3.61x frame=14164 fps=108 q=24.0 size=N/A time=00:07:52.74 bitrate=N/A speed=3.61x frame=14235 fps=108 q=24.0 size=N/A time=00:07:55.15 bitrate=N/A speed=3.62x frame=14300 fps=109 q=27.0 size=N/A time=00:07:57.39 bitrate=N/A speed=3.62x frame=14372 fps=109 q=24.0 size=N/A time=00:07:59.76 bitrate=N/A speed=3.63x frame=14444 fps=109 q=25.0 size=N/A time=00:08:02.13 bitrate=N/A speed=3.63x frame=14518 fps=109 q=25.0 size=N/A time=00:08:04.62 bitrate=N/A speed=3.64x frame=14589 fps=109 q=26.0 size=N/A time=00:08:06.95 bitrate=N/A speed=3.64x frame=14666 fps=109 q=25.0 size=N/A time=00:08:09.57 bitrate=N/A speed=3.65x frame=14743 fps=109 q=25.0 size=N/A time=00:08:12.07 bitrate=N/A speed=3.65x frame=14820 fps=110 q=26.0 size=N/A time=00:08:14.67 bitrate=N/A speed=3.66x frame=14896 fps=110 q=24.0 size=N/A time=00:08:17.36 bitrate=N/A speed=3.66x frame=14976 fps=110 q=23.0 size=N/A time=00:08:20.05 bitrate=N/A speed=3.67x frame=15055 fps=110 q=23.0 size=N/A time=00:08:22.67 bitrate=N/A speed=3.67x frame=15135 fps=110 q=24.0 size=N/A time=00:08:25.19 bitrate=N/A speed=3.68x frame=15213 fps=110 q=25.0 size=N/A time=00:08:27.92 bitrate=N/A speed=3.69x frame=15292 fps=111 q=25.0 size=N/A time=00:08:30.44 bitrate=N/A speed=3.69x frame=15368 fps=111 q=26.0 size=N/A time=00:08:33.13 bitrate=N/A speed= 3.7x frame=15448 fps=111 q=26.0 size=N/A time=00:08:35.79 bitrate=N/A speed= 3.7x frame=15515 fps=111 q=27.0 size=N/A time=00:08:37.90 bitrate=N/A speed= 3.7x frame=15585 fps=111 q=23.0 size=N/A time=00:08:40.29 bitrate=N/A speed=3.71x frame=15658 fps=111 q=28.0 size=N/A time=00:08:42.79 bitrate=N/A speed=3.71x frame=15730 fps=111 q=28.0 size=N/A time=00:08:45.01 bitrate=N/A speed=3.71x frame=15792 fps=111 q=26.0 size=N/A time=00:08:47.08 bitrate=N/A speed=3.72x frame=15860 fps=111 q=27.0 size=N/A time=00:08:49.42 bitrate=N/A speed=3.72x frame=15930 fps=112 q=27.0 size=N/A time=00:08:51.69 bitrate=N/A speed=3.72x frame=16009 fps=112 q=23.0 size=N/A time=00:08:54.50 bitrate=N/A speed=3.73x frame=16089 fps=112 q=25.0 size=N/A time=00:08:57.13 bitrate=N/A speed=3.73x frame=16156 fps=112 q=24.0 size=N/A time=00:08:59.30 bitrate=N/A speed=3.74x frame=16225 fps=112 q=27.0 size=N/A time=00:09:01.61 bitrate=N/A speed=3.74x frame=16295 fps=112 q=26.0 size=N/A time=00:09:04.10 bitrate=N/A speed=3.74x frame=16370 fps=112 q=27.0 size=N/A time=00:09:06.47 bitrate=N/A speed=3.75x frame=16446 fps=112 q=22.0 size=N/A time=00:09:09.07 bitrate=N/A speed=3.75x frame=16520 fps=112 q=24.0 size=N/A time=00:09:11.57 bitrate=N/A speed=3.76x frame=16594 fps=113 q=26.0 size=N/A time=00:09:13.94 bitrate=N/A speed=3.76x frame=16666 fps=113 q=26.0 size=N/A time=00:09:16.24 bitrate=N/A speed=3.76x frame=16734 fps=113 q=28.0 size=N/A time=00:09:18.61 bitrate=N/A speed=3.77x frame=16810 fps=113 q=24.0 size=N/A time=00:09:21.19 bitrate=N/A speed=3.77x frame=16886 fps=113 q=23.0 size=N/A time=00:09:23.62 bitrate=N/A speed=3.77x frame=16962 fps=113 q=26.0 size=N/A time=00:09:26.25 bitrate=N/A speed=3.78x frame=17037 fps=113 q=21.0 size=N/A time=00:09:28.66 bitrate=N/A speed=3.78x frame=17114 fps=113 q=27.0 size=N/A time=00:09:31.30 bitrate=N/A speed=3.79x frame=17185 fps=114 q=25.0 size=N/A time=00:09:33.73 bitrate=N/A speed=3.79x frame=17260 fps=114 q=24.0 size=N/A time=00:09:36.17 bitrate=N/A speed=3.79x frame=17337 fps=114 q=22.0 size=N/A time=00:09:38.79 bitrate=N/A speed= 3.8x frame=17417 fps=114 q=20.0 size=N/A time=00:09:41.39 bitrate=N/A speed= 3.8x frame=17493 fps=114 q=26.0 size=N/A time=00:09:43.91 bitrate=N/A speed=3.81x frame=17563 fps=114 q=26.0 size=N/A time=00:09:46.15 bitrate=N/A speed=3.81x frame=17635 fps=114 q=26.0 size=N/A time=00:09:48.62 bitrate=N/A speed=3.81x frame=17709 fps=114 q=24.0 size=N/A time=00:09:51.21 bitrate=N/A speed=3.82x frame=17785 fps=114 q=23.0 size=N/A time=00:09:53.68 bitrate=N/A speed=3.82x frame=17860 fps=115 q=22.0 size=N/A time=00:09:56.33 bitrate=N/A speed=3.82x frame=17933 fps=115 q=19.0 size=N/A time=00:09:58.63 bitrate=N/A speed=3.83x frame=18004 fps=115 q=23.0 size=N/A time=00:10:00.91 bitrate=N/A speed=3.83x frame=18086 fps=115 q=23.0 size=N/A time=00:10:03.73 bitrate=N/A speed=3.84x frame=18168 fps=115 q=20.0 size=N/A time=00:10:06.44 bitrate=N/A speed=3.84x frame=18251 fps=115 q=21.0 size=N/A time=00:10:09.17 bitrate=N/A speed=3.85x frame=18328 fps=115 q=25.0 size=N/A time=00:10:11.66 bitrate=N/A speed=3.85x frame=18395 fps=115 q=27.0 size=N/A time=00:10:14.12 bitrate=N/A speed=3.85x frame=18469 fps=115 q=26.0 size=N/A time=00:10:16.46 bitrate=N/A speed=3.85x frame=18549 fps=116 q=24.0 size=N/A time=00:10:19.09 bitrate=N/A speed=3.86x frame=18625 fps=116 q=26.0 size=N/A time=00:10:21.65 bitrate=N/A speed=3.86x frame=18699 fps=116 q=24.0 size=N/A time=00:10:24.23 bitrate=N/A speed=3.87x frame=18778 fps=116 q=24.0 size=N/A time=00:10:26.73 bitrate=N/A speed=3.87x frame=18853 fps=116 q=27.0 size=N/A time=00:10:29.29 bitrate=N/A speed=3.87x frame=18922 fps=116 q=29.0 size=N/A time=00:10:31.57 bitrate=N/A speed=3.88x frame=18996 fps=116 q=26.0 size=N/A time=00:10:34.06 bitrate=N/A speed=3.88x frame=19070 fps=116 q=29.0 size=N/A time=00:10:36.50 bitrate=N/A speed=3.88x frame=19141 fps=116 q=26.0 size=N/A time=00:10:38.99 bitrate=N/A speed=3.89x frame=19217 fps=116 q=23.0 size=N/A time=00:10:41.49 bitrate=N/A speed=3.89x frame=19295 fps=117 q=24.0 size=N/A time=00:10:44.05 bitrate=N/A speed=3.89x frame=19373 fps=117 q=25.0 size=N/A time=00:10:46.63 bitrate=N/A speed= 3.9x frame=19445 fps=117 q=26.0 size=N/A time=00:10:49.10 bitrate=N/A speed= 3.9x frame=19520 fps=117 q=26.0 size=N/A time=00:10:51.54 bitrate=N/A speed= 3.9x frame=19591 fps=117 q=21.0 size=N/A time=00:10:54.03 bitrate=N/A speed=3.91x frame=19663 fps=117 q=25.0 size=N/A time=00:10:56.55 bitrate=N/A speed=3.91x frame=19734 fps=117 q=27.0 size=N/A time=00:10:58.73 bitrate=N/A speed=3.91x frame=19806 fps=117 q=24.0 size=N/A time=00:11:01.07 bitrate=N/A speed=3.91x frame=19879 fps=117 q=22.0 size=N/A time=00:11:03.57 bitrate=N/A speed=3.92x frame=19958 fps=117 q=22.0 size=N/A time=00:11:06.06 bitrate=N/A speed=3.92x frame=20029 fps=117 q=25.0 size=N/A time=00:11:08.50 bitrate=N/A speed=3.92x frame=20107 fps=118 q=20.0 size=N/A time=00:11:11.06 bitrate=N/A speed=3.92x frame=20183 fps=118 q=23.0 size=N/A time=00:11:13.83 bitrate=N/A speed=3.93x frame=20258 fps=118 q=23.0 size=N/A time=00:11:16.30 bitrate=N/A speed=3.93x frame=20335 fps=118 q=26.0 size=N/A time=00:11:18.69 bitrate=N/A speed=3.93x frame=20411 fps=118 q=18.0 size=N/A time=00:11:21.38 bitrate=N/A speed=3.94x frame=20484 fps=118 q=24.0 size=N/A time=00:11:23.69 bitrate=N/A speed=3.94x frame=20558 fps=118 q=23.0 size=N/A time=00:11:26.18 bitrate=N/A speed=3.94x frame=20634 fps=118 q=23.0 size=N/A time=00:11:28.78 bitrate=N/A speed=3.95x frame=20710 fps=118 q=21.0 size=N/A time=00:11:31.24 bitrate=N/A speed=3.95x frame=20786 fps=118 q=21.0 size=N/A time=00:11:33.86 bitrate=N/A speed=3.95x frame=20863 fps=119 q=26.0 size=N/A time=00:11:36.49 bitrate=N/A speed=3.96x frame=20941 fps=119 q=22.0 size=N/A time=00:11:39.05 bitrate=N/A speed=3.96x frame=21019 fps=119 q=26.0 size=N/A time=00:11:41.48 bitrate=N/A speed=3.96x frame=21081 fps=119 q=28.0 size=N/A time=00:11:43.57 bitrate=N/A speed=3.96x frame=21147 fps=119 q=24.0 size=N/A time=00:11:45.87 bitrate=N/A speed=3.97x frame=21206 fps=119 q=24.0 size=N/A time=00:11:47.79 bitrate=N/A speed=3.96x frame=21274 fps=119 q=28.0 size=N/A time=00:11:50.16 bitrate=N/A speed=3.97x frame=21344 fps=119 q=29.0 size=N/A time=00:11:52.36 bitrate=N/A speed=3.97x frame=21414 fps=119 q=27.0 size=N/A time=00:11:54.79 bitrate=N/A speed=3.97x frame=21483 fps=119 q=27.0 size=N/A time=00:11:57.03 bitrate=N/A speed=3.97x frame=21555 fps=119 q=26.0 size=N/A time=00:11:59.53 bitrate=N/A speed=3.97x frame=21629 fps=119 q=27.0 size=N/A time=00:12:02.06 bitrate=N/A speed=3.98x frame=21703 fps=119 q=25.0 size=N/A time=00:12:04.39 bitrate=N/A speed=3.98x frame=21773 fps=119 q=28.0 size=N/A time=00:12:06.74 bitrate=N/A speed=3.98x frame=21850 fps=119 q=20.0 size=N/A time=00:12:09.36 bitrate=N/A speed=3.98x frame=21926 fps=119 q=23.0 size=N/A time=00:12:11.94 bitrate=N/A speed=3.99x frame=21998 fps=120 q=24.0 size=N/A time=00:12:14.22 bitrate=N/A speed=3.99x frame=22073 fps=120 q=23.0 size=N/A time=00:12:16.81 bitrate=N/A speed=3.99x frame=22148 fps=120 q=24.0 size=N/A time=00:12:19.17 bitrate=N/A speed=3.99x frame=22224 fps=120 q=23.0 size=N/A time=00:12:21.86 bitrate=N/A speed= 4x frame=22302 fps=120 q=24.0 size=N/A time=00:12:24.34 bitrate=N/A speed= 4x frame=22380 fps=120 q=22.0 size=N/A time=00:12:26.92 bitrate=N/A speed= 4x frame=22455 fps=120 q=27.0 size=N/A time=00:12:29.65 bitrate=N/A speed=4.01x frame=22521 fps=120 q=27.0 size=N/A time=00:12:31.65 bitrate=N/A speed=4.01x frame=22587 fps=120 q=27.0 size=N/A time=00:12:33.83 bitrate=N/A speed=4.01x frame=22659 fps=120 q=24.0 size=N/A time=00:12:36.26 bitrate=N/A speed=4.01x frame=22730 fps=120 q=27.0 size=N/A time=00:12:38.74 bitrate=N/A speed=4.01x frame=22799 fps=120 q=26.0 size=N/A time=00:12:41.06 bitrate=N/A speed=4.01x frame=22875 fps=120 q=23.0 size=N/A time=00:12:43.47 bitrate=N/A speed=4.02x frame=22950 fps=120 q=25.0 size=N/A time=00:12:45.97 bitrate=N/A speed=4.02x frame=23020 fps=120 q=25.0 size=N/A time=00:12:48.34 bitrate=N/A speed=4.02x frame=23085 fps=120 q=23.0 size=N/A time=00:12:50.58 bitrate=N/A speed=4.02x frame=23155 fps=121 q=26.0 size=N/A time=00:12:52.94 bitrate=N/A speed=4.02x frame=23228 fps=121 q=23.0 size=N/A time=00:12:55.25 bitrate=N/A speed=4.03x frame=23313 fps=121 q=21.0 size=N/A time=00:12:58.19 bitrate=N/A speed=4.03x frame=23396 fps=121 q=22.0 size=N/A time=00:13:00.88 bitrate=N/A speed=4.03x frame=23479 fps=121 q=23.0 size=N/A time=00:13:03.65 bitrate=N/A speed=4.04x frame=23554 fps=121 q=24.0 size=N/A time=00:13:06.13 bitrate=N/A speed=4.04x frame=23629 fps=121 q=24.0 size=N/A time=00:13:08.71 bitrate=N/A speed=4.04x frame=23705 fps=121 q=25.0 size=N/A time=00:13:11.14 bitrate=N/A speed=4.04x frame=23781 fps=121 q=25.0 size=N/A time=00:13:13.70 bitrate=N/A speed=4.05x frame=23860 fps=121 q=26.0 size=N/A time=00:13:16.33 bitrate=N/A speed=4.05x frame=23935 fps=121 q=25.0 size=N/A time=00:13:18.89 bitrate=N/A speed=4.05x frame=24012 fps=122 q=25.0 size=N/A time=00:13:21.45 bitrate=N/A speed=4.06x frame=24090 fps=122 q=23.0 size=N/A time=00:13:23.98 bitrate=N/A speed=4.06x frame=24165 fps=122 q=24.0 size=N/A time=00:13:26.67 bitrate=N/A speed=4.06x frame=24243 fps=122 q=22.0 size=N/A time=00:13:29.19 bitrate=N/A speed=4.06x frame=24323 fps=122 q=22.0 size=N/A time=00:13:31.81 bitrate=N/A speed=4.07x frame=24399 fps=122 q=23.0 size=N/A time=00:13:34.44 bitrate=N/A speed=4.07x frame=24478 fps=122 q=23.0 size=N/A time=00:13:36.87 bitrate=N/A speed=4.07x frame=24552 fps=122 q=27.0 size=N/A time=00:13:39.41 bitrate=N/A speed=4.07x frame=24620 fps=122 q=26.0 size=N/A time=00:13:41.67 bitrate=N/A speed=4.08x frame=24700 fps=122 q=20.0 size=N/A time=00:13:44.46 bitrate=N/A speed=4.08x frame=24781 fps=122 q=22.0 size=N/A time=00:13:47.24 bitrate=N/A speed=4.08x frame=24862 fps=122 q=27.0 size=N/A time=00:13:49.78 bitrate=N/A speed=4.08x frame=24934 fps=122 q=28.0 size=N/A time=00:13:52.21 bitrate=N/A speed=4.09x frame=25002 fps=122 q=28.0 size=N/A time=00:13:54.58 bitrate=N/A speed=4.09x frame=25072 fps=123 q=26.0 size=N/A time=00:13:56.69 bitrate=N/A speed=4.09x frame=25144 fps=123 q=23.0 size=N/A time=00:13:59.14 bitrate=N/A speed=4.09x frame=25220 fps=123 q=24.0 size=N/A time=00:14:01.70 bitrate=N/A speed=4.09x frame=25294 fps=123 q=23.0 size=N/A time=00:14:04.18 bitrate=N/A speed=4.09x frame=25369 fps=123 q=25.0 size=N/A time=00:14:06.61 bitrate=N/A speed= 4.1x frame=25441 fps=123 q=24.0 size=N/A time=00:14:09.19 bitrate=N/A speed= 4.1x frame=25517 fps=123 q=24.0 size=N/A time=00:14:11.69 bitrate=N/A speed= 4.1x frame=25592 fps=123 q=24.0 size=N/A time=00:14:14.16 bitrate=N/A speed= 4.1x frame=25668 fps=123 q=25.0 size=N/A time=00:14:16.72 bitrate=N/A speed=4.11x frame=25741 fps=123 q=25.0 size=N/A time=00:14:19.22 bitrate=N/A speed=4.11x frame=25811 fps=123 q=27.0 size=N/A time=00:14:21.48 bitrate=N/A speed=4.11x frame=25883 fps=123 q=26.0 size=N/A time=00:14:23.97 bitrate=N/A speed=4.11x frame=25956 fps=123 q=25.0 size=N/A time=00:14:26.28 bitrate=N/A speed=4.11x frame=26026 fps=123 q=24.0 size=N/A time=00:14:28.71 bitrate=N/A speed=4.11x frame=26097 fps=123 q=26.0 size=N/A time=00:14:30.95 bitrate=N/A speed=4.11x frame=26165 fps=123 q=23.0 size=N/A time=00:14:33.23 bitrate=N/A speed=4.12x frame=26232 fps=123 q=26.0 size=N/A time=00:14:35.56 bitrate=N/A speed=4.12x frame=26302 fps=123 q=27.0 size=N/A time=00:14:37.73 bitrate=N/A speed=4.12x frame=26370 fps=123 q=29.0 size=N/A time=00:14:40.23 bitrate=N/A speed=4.12x frame=26440 fps=123 q=29.0 size=N/A time=00:14:42.41 bitrate=N/A speed=4.12x frame=26508 fps=123 q=27.0 size=N/A time=00:14:44.84 bitrate=N/A speed=4.12x frame=26584 fps=124 q=21.0 size=N/A time=00:14:47.27 bitrate=N/A speed=4.12x frame=26665 fps=124 q=20.0 size=N/A time=00:14:49.96 bitrate=N/A speed=4.13x frame=26746 fps=124 q=21.0 size=N/A time=00:14:52.62 bitrate=N/A speed=4.13x frame=26820 fps=124 q=30.0 size=N/A time=00:14:55.06 bitrate=N/A speed=4.13x frame=26902 fps=124 q=22.0 size=N/A time=00:14:57.83 bitrate=N/A speed=4.13x frame=26981 fps=124 q=23.0 size=N/A time=00:15:00.50 bitrate=N/A speed=4.14x frame=27065 fps=124 q=28.0 size=N/A time=00:15:03.33 bitrate=N/A speed=4.14x frame=27149 fps=124 q=20.0 size=N/A time=00:15:06.02 bitrate=N/A speed=4.14x frame=27229 fps=124 q=21.0 size=N/A time=00:15:08.88 bitrate=N/A speed=4.15x frame=27311 fps=124 q=21.0 size=N/A time=00:15:11.59 bitrate=N/A speed=4.15x frame=27391 fps=124 q=20.0 size=N/A time=00:15:14.13 bitrate=N/A speed=4.15x frame=27473 fps=124 q=21.0 size=N/A time=00:15:17.03 bitrate=N/A speed=4.15x frame=27552 fps=125 q=27.0 size=N/A time=00:15:19.44 bitrate=N/A speed=4.16x frame=27625 fps=125 q=26.0 size=N/A time=00:15:22.06 bitrate=N/A speed=4.16x frame=27703 fps=125 q=25.0 size=N/A time=00:15:24.71 bitrate=N/A speed=4.16x frame=27781 fps=125 q=24.0 size=N/A time=00:15:27.18 bitrate=N/A speed=4.16x frame=27858 fps=125 q=27.0 size=N/A time=00:15:29.94 bitrate=N/A speed=4.17x frame=27936 fps=125 q=23.0 size=N/A time=00:15:32.37 bitrate=N/A speed=4.17x frame=28015 fps=125 q=24.0 size=N/A time=00:15:35.12 bitrate=N/A speed=4.17x frame=28094 fps=125 q=24.0 size=N/A time=00:15:37.55 bitrate=N/A speed=4.17x frame=28170 fps=125 q=25.0 size=N/A time=00:15:40.11 bitrate=N/A speed=4.17x frame=28246 fps=125 q=22.0 size=N/A time=00:15:42.82 bitrate=N/A speed=4.18x frame=28329 fps=125 q=23.0 size=N/A time=00:15:45.51 bitrate=N/A speed=4.18x frame=28410 fps=125 q=24.0 size=N/A time=00:15:48.13 bitrate=N/A speed=4.18x frame=28482 fps=125 q=23.0 size=N/A time=00:15:50.57 bitrate=N/A speed=4.18x frame=28562 fps=125 q=24.0 size=N/A time=00:15:53.30 bitrate=N/A speed=4.19x frame=28639 fps=125 q=24.0 size=N/A time=00:15:55.73 bitrate=N/A speed=4.19x frame=28721 fps=126 q=23.0 size=N/A time=00:15:58.50 bitrate=N/A speed=4.19x frame=28799 fps=126 q=24.0 size=N/A time=00:16:01.19 bitrate=N/A speed=4.19x frame=28884 fps=126 q=22.0 size=N/A time=00:16:03.92 bitrate=N/A speed= 4.2x frame=28967 fps=126 q=22.0 size=N/A time=00:16:06.76 bitrate=N/A speed= 4.2x frame=29048 fps=126 q=25.0 size=N/A time=00:16:09.49 bitrate=N/A speed= 4.2x frame=29127 fps=126 q=25.0 size=N/A time=00:16:12.13 bitrate=N/A speed= 4.2x frame=29201 fps=126 q=23.0 size=N/A time=00:16:14.69 bitrate=N/A speed=4.21x frame=29275 fps=126 q=23.0 size=N/A time=00:16:17.13 bitrate=N/A speed=4.21x frame=29354 fps=126 q=24.0 size=N/A time=00:16:19.60 bitrate=N/A speed=4.21x frame=29432 fps=126 q=21.0 size=N/A time=00:16:22.29 bitrate=N/A speed=4.21x frame=29511 fps=126 q=23.0 size=N/A time=00:16:24.91 bitrate=N/A speed=4.21x frame=29589 fps=126 q=25.0 size=N/A time=00:16:27.54 bitrate=N/A speed=4.21x frame=29665 fps=126 q=22.0 size=N/A time=00:16:30.16 bitrate=N/A speed=4.22x frame=29746 fps=126 q=21.0 size=N/A time=00:16:32.74 bitrate=N/A speed=4.22x frame=29826 fps=126 q=23.0 size=N/A time=00:16:35.37 bitrate=N/A speed=4.22x frame=29903 fps=127 q=22.0 size=N/A time=00:16:38.10 bitrate=N/A speed=4.22x frame=29986 fps=127 q=23.0 size=N/A time=00:16:40.78 bitrate=N/A speed=4.23x frame=30064 fps=127 q=24.0 size=N/A time=00:16:43.47 bitrate=N/A speed=4.23x frame=30142 fps=127 q=23.0 size=N/A time=00:16:46.05 bitrate=N/A speed=4.23x frame=30222 fps=127 q=23.0 size=N/A time=00:16:48.78 bitrate=N/A speed=4.23x frame=30301 fps=127 q=19.0 size=N/A time=00:16:51.49 bitrate=N/A speed=4.24x frame=30383 fps=127 q=22.0 size=N/A time=00:16:54.05 bitrate=N/A speed=4.24x frame=30461 fps=127 q=21.0 size=N/A time=00:16:56.66 bitrate=N/A speed=4.24x frame=30541 fps=127 q=23.0 size=N/A time=00:16:59.28 bitrate=N/A speed=4.24x frame=30618 fps=127 q=22.0 size=N/A time=00:17:01.78 bitrate=N/A speed=4.24x frame=30698 fps=127 q=25.0 size=N/A time=00:17:04.55 bitrate=N/A speed=4.25x frame=30773 fps=127 q=24.0 size=N/A time=00:17:06.98 bitrate=N/A speed=4.25x frame=30854 fps=127 q=23.0 size=N/A time=00:17:09.86 bitrate=N/A speed=4.25x frame=30929 fps=127 q=28.0 size=N/A time=00:17:12.29 bitrate=N/A speed=4.25x frame=30998 fps=127 q=26.0 size=N/A time=00:17:14.70 bitrate=N/A speed=4.25x frame=31068 fps=127 q=28.0 size=N/A time=00:17:16.90 bitrate=N/A speed=4.25x frame=31142 fps=127 q=22.0 size=N/A time=00:17:19.33 bitrate=N/A speed=4.25x frame=31216 fps=127 q=24.0 size=N/A time=00:17:21.74 bitrate=N/A speed=4.25x frame=31291 fps=128 q=24.0 size=N/A time=00:17:24.37 bitrate=N/A speed=4.26x frame=31370 fps=128 q=21.0 size=N/A time=00:17:26.95 bitrate=N/A speed=4.26x frame=31450 fps=128 q=24.0 size=N/A time=00:17:29.55 bitrate=N/A speed=4.26x frame=31526 fps=128 q=22.0 size=N/A time=00:17:32.18 bitrate=N/A speed=4.26x frame=31606 fps=128 q=22.0 size=N/A time=00:17:34.99 bitrate=N/A speed=4.26x frame=31687 fps=128 q=23.0 size=N/A time=00:17:37.64 bitrate=N/A speed=4.27x frame=31763 fps=128 q=23.0 size=N/A time=00:17:40.01 bitrate=N/A speed=4.27x frame=31840 fps=128 q=27.0 size=N/A time=00:17:42.63 bitrate=N/A speed=4.27x frame=31911 fps=128 q=24.0 size=N/A time=00:17:45.00 bitrate=N/A speed=4.27x frame=31985 fps=128 q=25.0 size=N/A time=00:17:47.49 bitrate=N/A speed=4.27x frame=32059 fps=128 q=25.0 size=N/A time=00:17:49.97 bitrate=N/A speed=4.27x frame=32134 fps=128 q=26.0 size=N/A time=00:17:52.53 bitrate=N/A speed=4.27x frame=32216 fps=128 q=22.0 size=N/A time=00:17:55.11 bitrate=N/A speed=4.28x frame=32295 fps=128 q=23.0 size=N/A time=00:17:57.86 bitrate=N/A speed=4.28x frame=32374 fps=128 q=25.0 size=N/A time=00:18:00.53 bitrate=N/A speed=4.28x frame=32453 fps=128 q=23.0 size=N/A time=00:18:03.17 bitrate=N/A speed=4.28x frame=32531 fps=128 q=22.0 size=N/A time=00:18:05.84 bitrate=N/A speed=4.28x frame=32612 fps=128 q=24.0 size=N/A time=00:18:08.34 bitrate=N/A speed=4.29x frame=32689 fps=128 q=22.0 size=N/A time=00:18:10.90 bitrate=N/A speed=4.29x frame=32768 fps=129 q=23.0 size=N/A time=00:18:13.54 bitrate=N/A speed=4.29x frame=32844 fps=129 q=23.0 size=N/A time=00:18:16.23 bitrate=N/A speed=4.29x frame=32922 fps=129 q=26.0 size=N/A time=00:18:18.83 bitrate=N/A speed=4.29x frame=33004 fps=129 q=20.0 size=N/A time=00:18:21.41 bitrate=N/A speed= 4.3x frame=33085 fps=129 q=21.0 size=N/A time=00:18:24.23 bitrate=N/A speed= 4.3x frame=33167 fps=129 q=21.0 size=N/A time=00:18:26.83 bitrate=N/A speed= 4.3x frame=33248 fps=129 q=24.0 size=N/A time=00:18:29.73 bitrate=N/A speed= 4.3x frame=33329 fps=129 q=23.0 size=N/A time=00:18:32.36 bitrate=N/A speed= 4.3x frame=33407 fps=129 q=24.0 size=N/A time=00:18:34.98 bitrate=N/A speed=4.31x frame=33481 fps=129 q=24.0 size=N/A time=00:18:37.61 bitrate=N/A speed=4.31x frame=33559 fps=129 q=25.0 size=N/A time=00:18:39.97 bitrate=N/A speed=4.31x frame=33634 fps=129 q=26.0 size=N/A time=00:18:42.47 bitrate=N/A speed=4.31x frame=33712 fps=129 q=24.0 size=N/A time=00:18:45.14 bitrate=N/A speed=4.31x frame=33790 fps=129 q=21.0 size=N/A time=00:18:47.65 bitrate=N/A speed=4.31x frame=33868 fps=129 q=25.0 size=N/A time=00:18:50.28 bitrate=N/A speed=4.31x frame=33947 fps=129 q=25.0 size=N/A time=00:18:52.97 bitrate=N/A speed=4.32x frame=34023 fps=129 q=24.0 size=N/A time=00:18:55.50 bitrate=N/A speed=4.32x frame=34102 fps=129 q=27.0 size=N/A time=00:18:58.06 bitrate=N/A speed=4.32x frame=34169 fps=129 q=23.0 size=N/A time=00:19:00.39 bitrate=N/A speed=4.32x frame=34249 fps=129 q=25.0 size=N/A time=00:19:02.95 bitrate=N/A speed=4.32x frame=34323 fps=130 q=23.0 size=N/A time=00:19:05.49 bitrate=N/A speed=4.32x frame=34401 fps=130 q=25.0 size=N/A time=00:19:08.01 bitrate=N/A speed=4.32x frame=34477 fps=130 q=24.0 size=N/A time=00:19:10.69 bitrate=N/A speed=4.33x frame=34546 fps=130 q=25.0 size=N/A time=00:19:12.98 bitrate=N/A speed=4.33x frame=34619 fps=130 q=25.0 size=N/A time=00:19:15.30 bitrate=N/A speed=4.33x frame=34720 fps=130 q=21.0 size=N/A time=00:19:18.76 bitrate=N/A speed=4.33x frame=34796 fps=130 q=21.0 size=N/A time=00:19:21.23 bitrate=N/A speed=4.33x frame=34878 fps=130 q=22.0 size=N/A time=00:19:24.01 bitrate=N/A speed=4.34x frame=34957 fps=130 q=22.0 size=N/A time=00:19:26.76 bitrate=N/A speed=4.34x frame=35036 fps=130 q=25.0 size=N/A time=00:19:29.42 bitrate=N/A speed=4.34x frame=35111 fps=130 q=25.0 size=N/A time=00:19:31.79 bitrate=N/A speed=4.34x frame=35180 fps=130 q=24.0 size=N/A time=00:19:34.10 bitrate=N/A speed=4.34x frame=35252 fps=130 q=26.0 size=N/A time=00:19:36.53 bitrate=N/A speed=4.34x frame=35324 fps=130 q=25.0 size=N/A time=00:19:39.05 bitrate=N/A speed=4.34x frame=35400 fps=130 q=24.0 size=N/A time=00:19:41.39 bitrate=N/A speed=4.34x frame=35477 fps=130 q=22.0 size=N/A time=00:19:44.04 bitrate=N/A speed=4.34x frame=35558 fps=130 q=23.0 size=N/A time=00:19:46.60 bitrate=N/A speed=4.35x frame=35639 fps=130 q=23.0 size=N/A time=00:19:49.33 bitrate=N/A speed=4.35x frame=35718 fps=130 q=23.0 size=N/A time=00:19:51.95 bitrate=N/A speed=4.35x frame=35789 fps=130 q=25.0 size=N/A time=00:19:54.47 bitrate=N/A speed=4.35x frame=35863 fps=130 q=26.0 size=N/A time=00:19:56.88 bitrate=N/A speed=4.35x frame=35936 fps=130 q=25.0 size=N/A time=00:19:59.40 bitrate=N/A speed=4.35x frame=36013 fps=130 q=25.0 size=N/A time=00:20:01.83 bitrate=N/A speed=4.35x frame=36087 fps=130 q=23.0 size=N/A time=00:20:04.50 bitrate=N/A speed=4.36x frame=36164 fps=131 q=26.0 size=N/A time=00:20:06.82 bitrate=N/A speed=4.36x frame=36241 fps=131 q=23.0 size=N/A time=00:20:09.55 bitrate=N/A speed=4.36x frame=36320 fps=131 q=23.0 size=N/A time=00:20:12.13 bitrate=N/A speed=4.36x frame=36398 fps=131 q=24.0 size=N/A time=00:20:14.69 bitrate=N/A speed=4.36x frame=36481 fps=131 q=22.0 size=N/A time=00:20:17.51 bitrate=N/A speed=4.36x frame=36559 fps=131 q=26.0 size=N/A time=00:20:20.07 bitrate=N/A speed=4.36x frame=36633 fps=131 q=24.0 size=N/A time=00:20:22.54 bitrate=N/A speed=4.37x frame=36701 fps=131 q=24.0 size=N/A time=00:20:24.74 bitrate=N/A speed=4.37x frame=36779 fps=131 q=20.0 size=N/A time=00:20:27.34 bitrate=N/A speed=4.37x frame=36862 fps=131 q=22.0 size=N/A time=00:20:30.12 bitrate=N/A speed=4.37x frame=36943 fps=131 q=22.0 size=N/A time=00:20:33.04 bitrate=N/A speed=4.37x frame=37021 fps=131 q=23.0 size=N/A time=00:20:35.56 bitrate=N/A speed=4.37x frame=37098 fps=131 q=24.0 size=N/A time=00:20:38.16 bitrate=N/A speed=4.37x frame=37174 fps=131 q=24.0 size=N/A time=00:20:40.53 bitrate=N/A speed=4.37x frame=37256 fps=131 q=21.0 size=N/A time=00:20:43.43 bitrate=N/A speed=4.38x frame=37338 fps=131 q=22.0 size=N/A time=00:20:45.99 bitrate=N/A speed=4.38x frame=37416 fps=131 q=26.0 size=N/A time=00:20:48.78 bitrate=N/A speed=4.38x frame=37493 fps=131 q=22.0 size=N/A time=00:20:51.34 bitrate=N/A speed=4.38x frame=37498 fps=131 q=24.0 Lsize=N/A time=00:20:51.39 bitrate=N/A speed=4.38x video:223743kB audio:29603kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0000000002bff960] frame I:709 Avg QP:16.22 size: 35294
b0dyr0ck2006 57 Posted October 17, 2016 Author Posted October 17, 2016 More testing remotely shows that it's more stable via the web than the iOS app, both airplayed to an Apple tv3 box. Via the web interface I did get a stutter 3 minutes in but that was it. Not the usual buffer pause every 5-10 minutes via iOS. Perhaps an issue with the iOS app @@ebr? Let me know if there is anything you want me to test/report.
