ciceroripi 0 Posted June 19, 2017 Posted June 19, 2017 @@Luke, thanks for the answer. Just to be sure, they are not at the bottom. Look ar the attached photo. Ill test the language, but Ill wait for the auto fix, I kind have a lot... Hehe
Luke 42243 Posted June 19, 2017 Posted June 19, 2017 I've pushed a fix to keep the subtitles at the bottom. Please reboot your chromecast receiver and try again. thanks.
ciceroripi 0 Posted June 19, 2017 Posted June 19, 2017 Nice, thanks. I'll test and let you know. Regarding the subs, is there a way to force Emby to recognize all my subs in my language?
Luke 42243 Posted June 19, 2017 Posted June 19, 2017 We don't have a setting for that but it's a possibility to add in the future, thanks.
ciceroripi 0 Posted June 20, 2017 Posted June 20, 2017 I tested, the subs look way better now, but they are not at the bottom yet, they are lower though. As you can see in the image, when in 2 lines kinda gets in the image for movies. The Portuguese setup worked fine, however when the language is not set, no configuration is made, so the subs are still big and high, your fix is not working for it.
Luke 42243 Posted June 20, 2017 Posted June 20, 2017 I tested, the subs look way better now, but they are not at the bottom yet, they are lower though. As you can see in the image, when in 2 lines kinda gets in the image for movies. The Portuguese setup worked fine, however when the language is not set, no configuration is made, so the subs are still big and high, your fix is not working for it. At this point we are applying zero customization to the subtitle location, therefore they are at the default location chosen by Chromecast.
ciceroripi 0 Posted June 20, 2017 Posted June 20, 2017 Nop, what I say is that the subs look way different when they have language than when they don't.
