Hijinxx 3 Posted September 8, 2016 Posted September 8, 2016 Hi, When im setting up the server should I be using the local path ie /volume2/tv or the network path ie \\192.168.67.1\tv ? When I added the folders with the local path emby found the media files no problem but no files were showing in KODI, When I try and add the folders using the network path to see if this resolves the issue it does not let me add the path giving me a path error. Im thinking this could be because it cant see the network path as it is the same IP as the NAS itself so it wouldnt be able to route to it ? The folders have r/w permisson. Any ideas?
shad0h 8 Posted September 9, 2016 Posted September 9, 2016 Hi @Hijinxx You add the folders to Emby using the local path e.g. /volume2/tv etc. If you want your apps or devices to directly play the files, you then need to go into the path substitution tab to add the SMB path e.g. \\192.168.67.1\tv. Here is a link to the wiki about path substitution - https://github.com/MediaBrowser/Wiki/wiki/Path-Substitution For Kodi to see and sync the library you need to have the emby for kodi plugin installed on your kodi client, which syncs the emby library to your Kodi clients https://emby.media/emby-for-kodi.html Regards, Shane
solabc16 379 Posted September 9, 2016 Posted September 9, 2016 Hello @@Hijinxx Following on from @@shad0h, have you read through the steps here also, which covers path substitution: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Setting-Up-Your-Media-Library-Share Best - James
solabc16 379 Posted September 9, 2016 Posted September 9, 2016 Hello @@Hijinxx Is this all working for you now? Anything else you need? - James
Hijinxx 3 Posted September 12, 2016 Author Posted September 12, 2016 (edited) I cant get the path substitution to work, I've re scanned my media a whole load of times. If you look at the screen shot I have attached you can see that the path substitution is there but not being picked up !! Edited September 12, 2016 by Hijinxx 1
solabc16 379 Posted September 12, 2016 Posted September 12, 2016 Hello @@Hijinxx Your configuration looks ok from the screenshots, and you shouldn't need to rescan the library to bring this into effect. What version of Emby Server are you running? If possible, can you send me your logs: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs - James
Hijinxx 3 Posted September 13, 2016 Author Posted September 13, 2016 Hi James, Im running Version 3.0.7100.0 on Synology. I will send my emby logs to you now. How will you know which ones are mine ? Thx
Hijinxx 3 Posted September 13, 2016 Author Posted September 13, 2016 OK this is how you know : ) sendlogs_MediaNAS_synology_cedarview_1813+_20160913T044046UTC.tgz
Solution solabc16 379 Posted September 13, 2016 Solution Posted September 13, 2016 Thanks @@Hijinxx, I believe you will find that the problem is being caused by your 'From' paths containing leading white space, see below. "PathSubstitutions":[{"From":" /volume2/TV/","To":"\\\\192.168.3.1\\tv\\"},{"From":" /volume2/movies/","To":"\\\\192.168.3.1\\movies\\"}] ^ ^ Can you edit/readd these and let me know how you get on. @@Luke could we consider adding a trim on save when committing these settings? - James 2
Hijinxx 3 Posted September 14, 2016 Author Posted September 14, 2016 Hi solabc1 I cant believe that was the problem and I didnt spot it. Thanks very much for the help. ; )
solabc16 379 Posted September 14, 2016 Posted September 14, 2016 Hi @@Hijinxx No problem and thanks for letting us know it solved the problem. It's impossible to spot from the UI, so without looking in the logs you wouldn't have seen it. - James
Luke 42240 Posted September 14, 2016 Posted September 14, 2016 Thanks @@Hijinxx, I believe you will find that the problem is being caused by your 'From' paths containing leading white space, see below. "PathSubstitutions":[{"From":" /volume2/TV/","To":"\\\\192.168.3.1\\tv\\"},{"From":" /volume2/movies/","To":"\\\\192.168.3.1\\movies\\"}] ^ ^ Can you edit/readd these and let me know how you get on. @@Luke could we consider adding a trim on save when committing these settings? - James Excellent idea, thanks.
