trpltongue 0 Posted January 15, 2014 Author Posted January 15, 2014 Yeah, I played with the edit functions a bit, I just don't want to have to edit all of my stuff manually....again.... I'd prefer to be able to tell it to download wide graphical banners and be done with it
ebr 16354 Posted January 15, 2014 Posted January 15, 2014 Are you looking at Art instead of banners, perhaps?
trpltongue 0 Posted January 16, 2014 Author Posted January 16, 2014 I actually tried that with no luck. So I toggled from compatible to MB2/3 and then saved. Restarted MBServer. Then toggled to compatible and saved. Then quit MBServer. Manually deleted all artwork and metadata from my folders as well as deleting all the cache files in the appdata folder. Restarted MBServer and it automatically scanned the library and downloaded new items. This time it named the images differently and everything is right except it is still downloading a fanart.jpg and a landscape.jpg for the series. It is also downloading a seasonxx-landscape.jpg instead of a seasonxx-fanart.jpg. Otherwise I think everything is good. Not sure why toggling the setting for compatible worked, but I promise you that I did NOT modify that setting during or after the installation until just now to toggle it.
Luke 42287 Posted January 16, 2014 Posted January 16, 2014 The fanart naming is by design. During development of our xbmc image saving we had several xbmc users involved, and the resulting file names are all based on the xbmc wiki and their test results.
trpltongue 0 Posted January 16, 2014 Author Posted January 16, 2014 I must admit I'm no expert on xbmc naming so I'm sure it works because you guys have honestly done a great job with this. I love the interface and simplicity of it. I was just going on the following wiki info for XBMC Frodo: http://wiki.xbmc.org/index.php?title=XBMC_v12_(Frodo)_FAQ#How_should_local_images_be_named_for_Frodo.3F Which describe the labeling as seasonxx-fanart.jpg?
trpltongue 0 Posted January 16, 2014 Author Posted January 16, 2014 that's what we get for banners, wide and graphical Hmm... not sure why but the ones it scraped for me (Dexter and CSI) were not graphical. They were rectangular with the show picture, but no name on them. I'm going to do a fresh install with all the download options set and see if maybe something got messed up in my initial install.
Koleckai Silvestri 1154 Posted January 16, 2014 Posted January 16, 2014 This is the CSI banner that MediaBrowser retrieved for me:
trpltongue 0 Posted January 16, 2014 Author Posted January 16, 2014 Weird! I don't have that, but instead have the following file called banner.jpg I've just uninstalled. I'm going to restart and then reinstall and use my test db to see what happens.
Luke 42287 Posted January 16, 2014 Posted January 16, 2014 that's what we get for banners, wide and graphical
trpltongue 0 Posted January 16, 2014 Author Posted January 16, 2014 Okay, fresh install is working MUCH better. Files are going where they are supposed to go for MB3. I think there is a bit of a compatibility issue with XBMC though in both naming convention and location of metadata. For TV shows: MB3 uses backdrop.jpg, seasonXX-landscape.jpg and thumb.jpg but XBMC does not recognize those names (at least not with Frodo naming convention). Additionally, MB3 stores the episode artwork in a "metadata" folder inside each season folder. I haven't tested it yet, but I'm pretty sure XBMC expects the images in the same folder as the episodes? Also, according to the updated Frodo documentation, each episode art should be called episodename-thumb.jpg but MB3 uses episodename.jpg. For Movies: Again, MB3 uses backdrop.jpg and thumb.jpg which XBMC does not recognize. I definitely don't mean to step on toes here, I just was trying to understand what MB3 is doing with regards to artwork as I am pretty picky about my art and metadata. I may just have MB3 store metadata and limited artwork to my C: drive so that I can navigate MB3 on my tablets understanding that the info and images will be slightly different between xbmc and MB3. Shouldn't be more than a few hundred megabytes if I just to banners / posters / episode art for TV shows and posters for movies.
Luke 42287 Posted January 16, 2014 Posted January 16, 2014 Sounds like you picked the MB2/MB3 image saving convention. You should have left it at the default and it would have used xbmc compatible file names. So, working as expected.
Koleckai Silvestri 1154 Posted January 16, 2014 Posted January 16, 2014 In the Server Dashboard do you have "Image Saving Convention" set to "Compatible - MB3/Plex/XBMC"?
trpltongue 0 Posted January 16, 2014 Author Posted January 16, 2014 Guys, I didn't touch any options in the setup wizard and the setting for "Image Saving Convention" is set to "Compatible - MB3/Plex/XBMC".
Luke 42287 Posted January 16, 2014 Posted January 16, 2014 i would still double check the metadata settings
trpltongue 0 Posted January 16, 2014 Author Posted January 16, 2014 (edited) I did. They are definitely set to compatible. The only change I made was to disable chapter image extraction. I can change it to MB2/MB3, save, and then change it back if that will help? Is there any way to force an update of the metadata that is cached? Edited January 15, 2014 by trpltongue
Koleckai Silvestri 1154 Posted January 16, 2014 Posted January 16, 2014 You can click on the MediaBrowser icon in the dashboard, go to the item and edit to force a refresh. You can edit your Media Folders to refresh all child items.
trpltongue 0 Posted January 17, 2014 Author Posted January 17, 2014 (edited) Okay, I did a bunch of testing over the last couple of days and this is what I sorted out: Tested using "An Idiot Abroad" TV show. Series art is scraped as expected and with the XBMC compatible file names and folders (poster.jpg, banner.jpg, fanart.jpg, etc). Additionally, a "landscape.jpg" file is scraped which is the same dimensions as fanart, but is a "thumb" for the series according to fanart.tv. "extrafanart" and "extrathumbs" folders are created in the right place and files populated with the XBMC compatible names. I still have to check for the ".actors" folder and files, didn't have time for that yet. Season art is *mostly* scraped with XBMC compatible file names. Season Posters are scraped properly, but season fanart is NOT. Fanart.tv doesn't list a category for season "fanart" or "backgrounds", instead they have season "thumbs" which is what MB3 downloads and saves as "seasonxx-landscape.jpg". However, this is NOT an XBMC compatible file name. "seasonxx-landscape.jpg" should be labeled "seasonxx-fanart.jpg". Manual renaming fixes the problem and XBMC picks up the seasonxx-fanart.jpg perfectly. Movies tested using 2 Guns and A Good Day to Die Hard: Movies grouped in folders- MB3 grabs all the relevant pictures, creates the extrafanart and extrathumbs folders and names everything properly (note I haven't tested the .actors folder functionality yet). Movies in VIDEO_TS folder structure - MB3 grabs all the relevant pictures and names them with XBMC compatible names, BUT the extrafanart and extrathumbs folders are created in the wrong directory. XBMC requires "extrafanart" and "extrathumb" folders to be in the same directory as the relevant movie file. In the case of VIDEO_TS folder structure, that means the extrafanart and extrathumbs folders must be in the VIDEO_TS folder, NOT the main movie folder. Movies\2 Guns (2013)\VIDEO_TS\extrafanart\ Not Movies\2 Guns (2013)\extrafanart\ This testing was done using both Confluence and Aeon Nox skins on latest Stable 12.3 Frodo release. Edited January 17, 2014 by trpltongue
Luke 42287 Posted January 17, 2014 Posted January 17, 2014 Okay, I did a bunch of testing over the last couple of days and this is what I sorted out: Tested using "An Idiot Abroad" TV show. Series art is scraped as expected and with the XBMC compatible file names and folders (poster.jpg, banner.jpg, fanart.jpg, etc). Additionally, a "landscape.jpg" file is scraped which is the same dimensions as fanart, but is a "thumb" for the series according to fanart.tv. "extrafanart" and "extrathumbs" folders are created in the right place and files populated with the XBMC compatible names. I still have to check for the ".actors" folder and files, didn't have time for that yet. Season art is *mostly* scraped with XBMC compatible file names. Season Posters are scraped properly, but season fanart is NOT. Fanart.tv doesn't list a category for season "fanart" or "backgrounds", instead they have season "thumbs" which is what MB3 downloads and saves as "seasonxx-landscape.jpg". However, this is NOT an XBMC compatible file name. "seasonxx-landscape.jpg" should be labeled "seasonxx-fanart.jpg". Manual renaming fixes the problem and XBMC picks up the seasonxx-fanart.jpg perfectly. Movies tested using 2 Guns and A Good Day to Die Hard: Movies grouped in folders- MB3 grabs all the relevant pictures, creates the extrafanart and extrathumbs folders and names everything properly (note I haven't tested the .actors folder functionality yet). Movies in VIDEO_TS folder structure - MB3 grabs all the relevant pictures and names them with XBMC compatible names, BUT the extrafanart and extrathumbs folders are created in the wrong directory. XBMC requires these folders to be in the same directory as the relevant movie file. In the case of VIDEO_TS folder structure, that means the extrafanart and extrathumbs folders must be in the VIDEO_TS folder, NOT the main movie folder. Movies\2 Guns (2013)\VIDEO_TS\extrafanart\ Not Movies\2 Guns (2013)\extrafanart\ This testing was done using both Confluence and Aeon Nox skins on latest Stable 12.3 Frodo release. @@sfnetwork can you verify these?
trpltongue 0 Posted January 17, 2014 Author Posted January 17, 2014 (edited) Forgot to mention, MB3 is not currently pulling art for "all-seasons". By default this should be the same art as the series art but named: season-all-(poster/banner/fanart).(png/jpg) I should also mention that "landscape.jpg" may be a valid file name in some skins, but it is NOT the standard filename for season fanart, which is what we want. Edited January 17, 2014 by trpltongue
trpltongue 0 Posted January 23, 2014 Author Posted January 23, 2014 Luke, any luck confirming these with sfnetwork? I'm using MB3 web client on a regular basis now and getting down to a single medata manager would be great. Thanks!
saitoh183 137 Posted February 27, 2014 Posted February 27, 2014 (edited) Just doing some test with a movie and it doesnt seem to pick up the xbmc format for backdrops <movie_name>-fanart.jpg. It just creates a fanart.jpg Posters seems to work <movie_name>-poster.jpg. Edited February 26, 2014 by saitoh183
saitoh183 137 Posted February 27, 2014 Posted February 27, 2014 Just doing some test with a movie and it doesnt seem to pick up the xbmc format for backdrops <movie_name>-fanart.jpg. It just creates a fanart.jpg Posters seems to work <movie_name>-poster.jpg. Will this be fixed next release by any chance?
saitoh183 137 Posted February 27, 2014 Posted February 27, 2014 (edited) can i post any log that will help...i tried multiple times and it always just creates a fanart.jpg Here is the log after i delete the fanart.jpb and do a refresh all: 2014-02-27 09:23:07.4229 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/edititemmetadata.html?id=269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:07.4229 Warn - StringMapTypeDeserializer: Property 'id' does not exist on type 'MediaBrowser.WebDashboard.Api.GetDashboardResource' 2014-02-27 09:23:07.4229 Debug - HttpServer: HTTP Response 304 to [::1]:61986. Response time: 1.0007 ms Url: http://localhost:8096/mediabrowser/dashboard/edititemmetadata.html?id=269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:07.6059 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/Ancestors?userId=f6c51e6fd330e59d16f4cc52886702e1 2014-02-27 09:23:07.6059 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 2.0008 ms Url: http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/Ancestors?userId=f6c51e6fd330e59d16f4cc52886702e1 2014-02-27 09:23:07.6329 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:07.6479 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 16.0008 ms Url: http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:07.7089 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/ExternalIdInfos 2014-02-27 09:23:07.7089 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 0 ms Url: http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/ExternalIdInfos 2014-02-27 09:23:07.7369 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-02-27 09:23:07.7379 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 1.0004 ms Url: http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-02-27 09:23:07.9119 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Library/MediaFolders 2014-02-27 09:23:07.9119 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/LiveTv/Info? 2014-02-27 09:23:07.9119 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 1.0014 ms Url: http://localhost:8096/mediabrowser/Library/MediaFolders 2014-02-27 09:23:07.9909 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 79.0068 ms Url: http://localhost:8096/mediabrowser/LiveTv/Info? 2014-02-27 09:23:08.0559 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items?ParentId=0fbe90bb17617b540805be65ebf7dbfd&Fields=Settings&SortBy=SortName 2014-02-27 09:23:08.0559 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 3.0006 ms Url: http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items?ParentId=0fbe90bb17617b540805be65ebf7dbfd&Fields=Settings&SortBy=SortName 2014-02-27 09:23:28.0901 Debug - HttpServer: HTTP POST http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/Refresh?forced=true&recursive=true 2014-02-27 09:23:28.0972 Debug - App: Running FFProbeProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009)-trailer.avi 2014-02-27 09:23:28.0972 Debug - App: Saving \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009)-trailer.avi to database. 2014-02-27 09:23:28.0972 Debug - App: Running OmdbItemProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.0972 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0472033&tomatoes=true 2014-02-27 09:23:28.2241 Debug - App: Running MovieDbProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Debug - App: Running MovieXmlProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Debug - App: MovieXmlProvider returned no metadata for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Debug - App: Running FFProbeProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Debug - App: Running MovieDbImageProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/jTki4a30PUskfGtOFx6PgYr74H7.jpg 2014-02-27 09:23:28.4562 Debug - ProviderManager: Saving image to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg 2014-02-27 09:23:28.4592 Debug - LibraryMonitor: Watcher sees change of type Created to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg 2014-02-27 09:23:28.4592 Debug - LibraryMonitor: Ignoring change to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg 2014-02-27 09:23:28.4592 Debug - ProviderManager: Saving \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv to Xbmc nfo. 2014-02-27 09:23:28.4792 Debug - LibraryMonitor: Watcher sees change of type Changed to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).nfo 2014-02-27 09:23:28.4792 Debug - LibraryMonitor: Ignoring change to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).nfo 2014-02-27 09:23:28.4792 Debug - LibraryMonitor: Watcher sees change of type Changed to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).nfo 2014-02-27 09:23:28.4792 Debug - LibraryMonitor: Ignoring change to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).nfo 2014-02-27 09:23:28.4792 Debug - App: Saving \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv to database. 2014-02-27 09:23:28.4792 Debug - HttpServer: HTTP Response 204 to [::1]:61988. Response time: 394.0683 ms Url: http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/Refresh?forced=true&recursive=true 2014-02-27 09:23:28.5101 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:28.5101 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 6.0002 ms Url: http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:28.5212 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/ExternalIdInfos 2014-02-27 09:23:28.5212 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 0.9529 ms Url: http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/ExternalIdInfos 2014-02-27 09:23:28.5561 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-02-27 09:23:28.5561 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 1.0017 ms Url: http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-02-27 09:23:29.7092 Debug - LibraryMonitor: Watcher sees change of type Changed to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg 2014-02-27 09:23:29.7092 Debug - LibraryMonitor: Ignoring change to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg Edited February 27, 2014 by saitoh183
sfnetwork 514 Posted February 27, 2014 Posted February 27, 2014 There is a lot of information in this tread... I'm confused a bit... Would it be possible to list all issues one by one with screenshots of the folder structure if you don't mind just to have a summary because I didn't follow this tread actively and there are several separate issue mentioned here...
saitoh183 137 Posted February 27, 2014 Posted February 27, 2014 Just doing some test with a movie and it doesnt seem to pick up the xbmc format for backdrops <movie_name>-fanart.jpg. It just creates a fanart.jpg Posters seems to work <movie_name>-poster.jpg. can i post any log that will help...i tried multiple times and it always just creates a fanart.jpg Here is the log after i delete the fanart.jpb and do a refresh all: 2014-02-27 09:23:07.4229 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/edititemmetadata.html?id=269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:07.4229 Warn - StringMapTypeDeserializer: Property 'id' does not exist on type 'MediaBrowser.WebDashboard.Api.GetDashboardResource' 2014-02-27 09:23:07.4229 Debug - HttpServer: HTTP Response 304 to [::1]:61986. Response time: 1.0007 ms Url: http://localhost:8096/mediabrowser/dashboard/edititemmetadata.html?id=269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:07.6059 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/Ancestors?userId=f6c51e6fd330e59d16f4cc52886702e1 2014-02-27 09:23:07.6059 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 2.0008 ms Url: http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/Ancestors?userId=f6c51e6fd330e59d16f4cc52886702e1 2014-02-27 09:23:07.6329 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:07.6479 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 16.0008 ms Url: http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:07.7089 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/ExternalIdInfos 2014-02-27 09:23:07.7089 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 0 ms Url: http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/ExternalIdInfos 2014-02-27 09:23:07.7369 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-02-27 09:23:07.7379 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 1.0004 ms Url: http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-02-27 09:23:07.9119 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Library/MediaFolders 2014-02-27 09:23:07.9119 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/LiveTv/Info? 2014-02-27 09:23:07.9119 Debug - HttpServer: HTTP Response 200 to [::1]:61986. Response time: 1.0014 ms Url: http://localhost:8096/mediabrowser/Library/MediaFolders 2014-02-27 09:23:07.9909 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 79.0068 ms Url: http://localhost:8096/mediabrowser/LiveTv/Info? 2014-02-27 09:23:08.0559 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items?ParentId=0fbe90bb17617b540805be65ebf7dbfd&Fields=Settings&SortBy=SortName 2014-02-27 09:23:08.0559 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 3.0006 ms Url: http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items?ParentId=0fbe90bb17617b540805be65ebf7dbfd&Fields=Settings&SortBy=SortName 2014-02-27 09:23:28.0901 Debug - HttpServer: HTTP POST http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/Refresh?forced=true&recursive=true 2014-02-27 09:23:28.0972 Debug - App: Running FFProbeProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009)-trailer.avi 2014-02-27 09:23:28.0972 Debug - App: Saving \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009)-trailer.avi to database. 2014-02-27 09:23:28.0972 Debug - App: Running OmdbItemProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.0972 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0472033&tomatoes=true 2014-02-27 09:23:28.2241 Debug - App: Running MovieDbProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Debug - App: Running MovieXmlProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Debug - App: MovieXmlProvider returned no metadata for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Debug - App: Running FFProbeProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Debug - App: Running MovieDbImageProvider for \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv 2014-02-27 09:23:28.2241 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/jTki4a30PUskfGtOFx6PgYr74H7.jpg 2014-02-27 09:23:28.4562 Debug - ProviderManager: Saving image to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg 2014-02-27 09:23:28.4592 Debug - LibraryMonitor: Watcher sees change of type Created to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg 2014-02-27 09:23:28.4592 Debug - LibraryMonitor: Ignoring change to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg 2014-02-27 09:23:28.4592 Debug - ProviderManager: Saving \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv to Xbmc nfo. 2014-02-27 09:23:28.4792 Debug - LibraryMonitor: Watcher sees change of type Changed to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).nfo 2014-02-27 09:23:28.4792 Debug - LibraryMonitor: Ignoring change to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).nfo 2014-02-27 09:23:28.4792 Debug - LibraryMonitor: Watcher sees change of type Changed to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).nfo 2014-02-27 09:23:28.4792 Debug - LibraryMonitor: Ignoring change to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).nfo 2014-02-27 09:23:28.4792 Debug - App: Saving \\SRV-SAITOH\Videos\T_Movies\9 (2009)\9 (2009).mkv to database. 2014-02-27 09:23:28.4792 Debug - HttpServer: HTTP Response 204 to [::1]:61988. Response time: 394.0683 ms Url: http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/Refresh?forced=true&recursive=true 2014-02-27 09:23:28.5101 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:28.5101 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 6.0002 ms Url: http://localhost:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/269880ed5e9c82118612d25bb7689906 2014-02-27 09:23:28.5212 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/ExternalIdInfos 2014-02-27 09:23:28.5212 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 0.9529 ms Url: http://localhost:8096/mediabrowser/Items/269880ed5e9c82118612d25bb7689906/ExternalIdInfos 2014-02-27 09:23:28.5561 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-02-27 09:23:28.5561 Debug - HttpServer: HTTP Response 200 to [::1]:61988. Response time: 1.0017 ms Url: http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-02-27 09:23:29.7092 Debug - LibraryMonitor: Watcher sees change of type Changed to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg 2014-02-27 09:23:29.7092 Debug - LibraryMonitor: Ignoring change to \\SRV-SAITOH\Videos\T_Movies\9 (2009)\fanart.jpg That is the log of after i erase the backdrop and leave only 9 (2009)-poster.jpg and 9 (2009)-fanart.jpg in the movie folder. It picks up the 9 (2009)-poster.jpg but not 9 (2009)-fanart.jpg (unless i rename it to fanart.jpg before i refresh)
