anvpbe 0 Posted September 7, 2016 Posted September 7, 2016 I want to start using Emby Theater but there are a couple of issues that are annoying and prevents me from using it. I'm running Theater on a Microsoft Surface Pro 4 and if I drag from the bottom of the screen up or from the top of the screen down it will resize Theater. Actually it resizes a part within Theater. See this screencast (http://recordit.co/ren667SrXS). You might think, well just don't drag there... well, it can be unintentional and then it's very difficult to restore. I then have to close down Theater and start it up again. The second issue is when I have clicked on a setting for example display language. There is no back arrow at the top left. When using a touch screen this is necessary. The same goes for if I start a movie and it asks to resume or start from the beginning. If this was an unintentional press then I have to resume the movie and then stop it.
Luke 42242 Posted September 7, 2016 Posted September 7, 2016 Hi, welcome. Thanks we'll look at these.
