UncleJohnsBand 1 Posted September 17, 2016 Posted September 17, 2016 Well the log earlier had 500 errors coming from the tuner status url. Maybe the Emby plugin needs to change the url that it is hitting? The only 500 I have seen posted since I jumped into the thread is for the version check. I just know that going directly to the API url is working from the API side.... but it is not working within Emby... so it could be something in the plugin. This API call has not changed for a long time.
UncleJohnsBand 1 Posted September 17, 2016 Posted September 17, 2016 Does it require any specific headers? It should be a standard Ajax call that gets a json response.... nothing out of the ordinary.
pünktchen 1410 Posted September 17, 2016 Posted September 17, 2016 It should be a standard Ajax call that gets a json response.... nothing out of the ordinary.Is the NextPVR API case sensitive? @@Luke havn't you replaced Ajax by Fetch in Emby?
UncleJohnsBand 1 Posted September 17, 2016 Posted September 17, 2016 Is the NextPVR API case sensitive? @@Luke havn't you replaced Ajax by Fetch in Emby? No...... example..... Both are valid.... http://localhost:8866/public/Util/NPVR/VersionCheck/ http://localhost:8866/public/util/npvr/versioncheck/
Luke 42239 Posted September 17, 2016 Posted September 17, 2016 Is the NextPVR API case sensitive? @@Luke havn't you replaced Ajax by Fetch in Emby? He's just referring to an http request in general. ajax/fetch is strictly related to javascript.
UncleJohnsBand 1 Posted September 17, 2016 Posted September 17, 2016 He's just referring to an http request in general. ajax/fetch is strictly related to javascript. Correct.... needs to be an http GET request.
Scott D 69 Posted September 19, 2016 Author Posted September 19, 2016 Ok..... lets make sure you have a good set of files for the NPVR web interface (NEWA). Stop the NPVR service. Delete everything in the web directory except for the Bin folder. Then unzip this file which has all the files from the 3.7.7 release. Restart NPVR service. Let me know if there is any difference following the update. Completed the above. No change. Emby version currently installed 3.1.158.0 NPVR 3.7.7 Attached current Emby Server log. server-63609863797.txt
UncleJohnsBand 1 Posted September 19, 2016 Posted September 19, 2016 Completed the above. No change. Emby version currently installed 3.1.158.0 NPVR 3.7.7 Attached current Emby Server log. Thanks.... this appears to be something environmental.... I can rerun the request from your fiddler file (select line and click on rerun in menu) and it works fine. Lets try this.... Close all browsers Stop the npvr recording service go to program files (x86)\npvr and open a command window enter nrecord run Open the Emby Dashboard Go to the Live Tv item under Extras Send screen shot of what is appearing in the command window In the command window hit Ctrl C to end the process.... you can then restart NPVR as normal
Scott D 69 Posted September 19, 2016 Author Posted September 19, 2016 Thanks.... this appears to be something environmental.... I can rerun the request from your fiddler file (select line and click on rerun in menu) and it works fine. Lets try this.... Close all browsers Stop the npvr recording service go to program files (x86)\npvr and open a command window enter nrecord run Open the Emby Dashboard Go to the Live Tv item under Extras Send screen shot of what is appearing in the command window In the command window hit Ctrl C to end the process.... you can then restart NPVR as normal See attached.
Plunkett 0 Posted September 21, 2016 Posted September 21, 2016 Thanks.... this appears to be something environmental.... I can rerun the request from your fiddler file (select line and click on rerun in menu) and it works fine. Lets try this.... Close all browsers Stop the npvr recording service go to program files (x86)\npvr and open a command window enter nrecord run Open the Emby Dashboard Go to the Live Tv item under Extras Send screen shot of what is appearing in the command window In the command window hit Ctrl C to end the process.... you can then restart NPVR as normal Thought i'd do it too:
serpi 82 Posted September 26, 2016 Posted September 26, 2016 I had the same problem and here is the fix. Hope this helps. Ciao, Alfred
UncleJohnsBand 1 Posted September 26, 2016 Posted September 26, 2016 I had the same problem and here is the fix. Hope this helps. Ciao, Alfred Worth a shot...as this is a really odd issue that is for sure environmental. You could also change the npvr recording service to run as a local administrator account instead of a system account.
Scott D 69 Posted September 29, 2016 Author Posted September 29, 2016 Tried this, and nothing changed. Still getting 500 error in Emby.
Plunkett 0 Posted October 2, 2016 Posted October 2, 2016 I had the same problem and here is the fix. Hope this helps. Ciao, Alfred I tried the link in this thread and it shows up all the channels with no issues. The folder described in the thread already exists.
Plunkett 0 Posted October 7, 2016 Posted October 7, 2016 (edited) Hi Guys, I was able to fix my issue by changing the port in NPVR and matching that in the plugin too of course. I assume I was using a port that was reserved or in use? I also changed the Web Server Admin password in NPVR to match the XBMC Touch Client password. (Not to sure which one of these actually fixed it). Now I just have an issue with Live TV playing on the Clients, just gets stuck on loading circle (Have posted over on Emby Theater forum) Thank you all and a special thanks to UncleJohnsBand Edited October 7, 2016 by Plunkett
jeflatt 6 Posted December 10, 2016 Posted December 10, 2016 (edited) I cannot get any of the tuners to show up either. I have just installed the NextPVR plugin, but it doesn't seem to do anything. No tuners show. I've been trying to follow this thread, but I admit that most of it is going way over my head. I'm running NPVR version 3.9.2 and the program itself is working just fine. I can watch live TV and recordings, etc. The NextPVR plugin for EMBY is version 3.0.6137.25461. I've tried some of the links in this thread and have attached the results below. Since I'm just setting this up now, I'm hoping that I've just not done something right and this is a simple matter, but for the moment I am completely stumped.version check.pdftuner status.pdf Edited December 10, 2016 by jeflatt
UncleJohnsBand 1 Posted December 10, 2016 Posted December 10, 2016 (edited) I cannot get any of the tuners to show up either. I have just installed the NextPVR plugin, but it doesn't seem to do anything. No tuners show. I've been trying to follow this thread, but I admit that most of it is going way over my head. I'm running NPVR version 3.9.2 and the program itself is working just fine. I can watch live TV and recordings, etc. The NextPVR plugin for EMBY is version 3.0.6137.25461. I've tried some of the links in this thread and have attached the results below. Since I'm just setting this up now, I'm hoping that I've just not done something right and this is a simple matter, but for the moment I am completely stumped.emby live tv screen.pngversion check.pdftuner status.pdf What is the date on your: Users\Public\NPVR\web\App_Code\UtilServiceController.cs file? Edit: Try replacing that file with the attached version.... Stop your recording service, extract this file into that location, start your recording service. Check to see if you now get your tuner status and also then post the Users\Public\NPVR\Logs\web.log file. UtilServiceController.zip Edited December 10, 2016 by UncleJohnsBand
jeflatt 6 Posted December 10, 2016 Posted December 10, 2016 (edited) What is the date on your: Users\Public\NPVR\web\App_Code\UtilServiceController.cs file? Edit: Try replacing that file with the attached version.... Stop your recording service, extract this file into that location, start your recording service. Check to see if you now get your tuner status and also then post the Users\Public\NPVR\Logs\web.log file. Still no change. Here are the web.log files.web.log [Edit] Okay, there has been one change. The version check and status check have different results now. I've attached them as well. tuner status 2.pdfversion check 2.pdf Edited December 10, 2016 by jeflatt
UncleJohnsBand 1 Posted December 11, 2016 Posted December 11, 2016 Still no change. Here are the web.log files.web.log [Edit] Okay, there has been one change. The version check and status check have different results now. I've attached them as well. tuner status 2.pdfversion check 2.pdf yea....that's odd... nothing changed there.... have you rebooted? If not give that a go. If you reboot(ed) and still having this issue....then stop the recording service, delete the web directory and then unzip this.....it has everything that should be in the web directory and when you restart the recording service it should pull in all the dll's from npvr it needs. 1
jeflatt 6 Posted December 11, 2016 Posted December 11, 2016 yea....that's odd... nothing changed there.... have you rebooted? If not give that a go. If you reboot(ed) and still having this issue....then stop the recording service, delete the web directory and then unzip this.....it has everything that should be in the web directory and when you restart the recording service it should pull in all the dll's from npvr it needs. Everything is still exactly the same after trying all of that. I've attached the version check, status check, etc. It is interesting that before I started trying these fixes, the version check failed, but the tuner status was fine. Also when I navigate to HTTP:\\localhost:8866 it used to take me to the guide. Now I get an error. I've attached that error screen as well. NPVR Port 3.pdfversion check 3.pdftuner status 3.pdf
emveepee 133 Posted December 11, 2016 Posted December 11, 2016 @jefaltt Those errors indicate a failed upgrade of NextPVR. Download the installer again and rerun it. Martin
Solution jeflatt 6 Posted December 12, 2016 Solution Posted December 12, 2016 @jefaltt Those errors indicate a failed upgrade of NextPVR. Download the installer again and rerun it. Martin THANK YOU THANK YOU THANK YOU!!!!! That did the trick. Problem solved.
