Guest petwri Posted September 6, 2016 Posted September 6, 2016 I found out that the latest beta app for android now supports original audio syncing, which is awesome, thanks. But I haven't found a global setting to always use the original file, I have to adjust it for every sync job manually, it initially gets set to "custom", whatever that means. Is that intentionally? Would really love to have such an app-wide setting.
jamvids 39 Posted September 6, 2016 Posted September 6, 2016 Kudos for this one, I have been waiting for it and is working well. It's in the offline sync settings. Sent from my E6853 using Tapatalk
jamvids 39 Posted September 6, 2016 Posted September 6, 2016 If it's a playlist you have to put a bit rate in. I put 99999 and it's syncing flac okay Sent from my E6853 using Tapatalk
Guest petwri Posted September 6, 2016 Posted September 6, 2016 In the app settings I can only choose between "None", 320K, 256K, 192K, 128K and 64K.
jamvids 39 Posted September 6, 2016 Posted September 6, 2016 I have it set to none Sent from my E6853 using Tapatalk
Guest petwri Posted September 6, 2016 Posted September 6, 2016 So setting it to None will use flac quality, although it is displayed as custom in the sync job?
Luke 42243 Posted September 6, 2016 Posted September 6, 2016 how are you starting the sync? audio sync is supposed to just be one-click. meaning, no options to pick from. i will need to fix that with playlists.
Guest petwri Posted September 6, 2016 Posted September 6, 2016 In settings, I chose "None" for Max audio file bitrate. After that, hitting "Make available offline", a sync job appears under Downloads. Clicking on the sync job shows the qualitiy options "Original", "High", "Medium", "Low" and "Custom", which has nothing to do with the options I could choose in the settings sections. So long story short: will leaving it to "Custom" sync the original files or do I need to set it to "Original" by hand?
Luke 42243 Posted September 6, 2016 Posted September 6, 2016 yea just leave it. the sync job info screen needs some updating,
Guest petwri Posted September 6, 2016 Posted September 6, 2016 Thanks, I'll give it a try, will come back to this if it doesn't work.
Guest petwri Posted September 7, 2016 Posted September 7, 2016 Everything works described: just hit "make available offline, and it'll get copied as flac. But you guys should really do sth about the UI, those settings just don't make sense.
Luke 42243 Posted September 7, 2016 Posted September 7, 2016 Thanks. Do you have a suggestion? I could rename None to Original Quality 1
