lonelycode 0 Posted September 4, 2016 Posted September 4, 2016 Hi, I have Emby Theater installed on Windows (7) HTPC, and gamebrwoeser installed as a server plugin: Game directory i set up as per instructions Gamebrowser platforms are all set up Game library is accessible and scanned as part of media library External players set up for all platforms with the {path} and options as described in the forum elsewhere with the appropriate command line options for each I have two issues: 1. When trying to hit "play" on the game screen, I get a spinner and nothing else, no error, and no emulator, it just spins and then eventually gives up. I've changed the path to the external player to be notepad.exe and I get the same behaviour, so the shell isn't even being invoked. 2. The second issue is that Emby isn't scanning the folders properly, and only some games (SNES / SegaCD, PS1) have the play button and metadata, while Genesis games do not have one. The first issue is more of a problem, because in the old WMC plugin the games always launched. But I really like ET (and have a premium sub) so would like to get this feature working as well. I noticed someone else had a similar issue but no resolution at all. I can't find any useful log messages either - where can I find the logs for the ET client? Hope someone can help :-S M.
Luke 42197 Posted September 5, 2016 Posted September 5, 2016 Hi, welcome. If you can zip up a sample games library for me and send it to me, I'll test it out. Thanks.
Lioooo 0 Posted September 17, 2016 Posted September 17, 2016 Hi Luke I have the same problem ! Can you please test the below PlayStation1 game ? direct link is https://dl3.loveroms.com/r/Playstation/L-O/Medal%20of%20Honor%20[sLUS-00974].rar Waiting your reply please Thanks Lioooo
vinc010 0 Posted December 31, 2016 Posted December 31, 2016 Hi, I have exactly the same problem too and I don't find any solution on the forum. Please help me. Vinc
Luke 42197 Posted December 31, 2016 Posted December 31, 2016 Hi @@vinc010, can you please describe your problem in more detail? thanks !
vinc010 0 Posted January 1, 2017 Posted January 1, 2017 Yes, of course. I have an HTPC with Windows 10 64 bits, Emby Server and Emby Theater installed on it. I recently installed gamebrowser with instructions found on this topic : https://emby.media/community/index.php?/topic/16380-gamebrowser-guide/ In plugin configuration page, I have : In Emby Theater, I configure as instructions too : But when I want to play a game, I get a spinner and nothing else ; no error and no emulator launched : When I try to launch a game in command line, all works fine : Thanks for your help @@Luke....and happy new year ! Vinc
Luke 42197 Posted January 7, 2017 Posted January 7, 2017 have you tested those exact arguments on the command line? the arguments in your command line screenshot are different from your emby theater configuration.
vinc010 0 Posted January 9, 2017 Posted January 9, 2017 If you're talking about the fullscreen argument, I've try this three methods and they are all working (not that the drive letter is different because i'm on an other PC):
vinc010 0 Posted January 14, 2017 Posted January 14, 2017 (edited) Up please. Edited January 14, 2017 by vinc010
Luke 42197 Posted January 16, 2017 Posted January 16, 2017 @@vinc010, try switching to lowercase {path} I am pushing out an update to allow it to handle all casing. thanks.
vinc010 0 Posted January 20, 2017 Posted January 20, 2017 (edited) Thanks for the reply @@Luke.I have already tried this solution that unfortunately generates the same problem. I also tried to put the arguments on the same line (contrary to what marked in the options) but still the same. Is it possible, in a log file, to see the exact command line that is executed? Edited January 20, 2017 by vinc010
