Notfast 7 Posted September 3, 2016 Posted September 3, 2016 To day when I wanted to play a video clip, then there where no sound when playing video with AC3. If I play AAC there is sound. I use Wasapi and I have not changed a thing, only change I can see is that emby has updated it self. If I change audio render to default, then AC3 plays fine. theater-63608487855.txt
Guest asrequested Posted September 3, 2016 Posted September 3, 2016 Assuming that you have tried other files of the same type and got the same result, can you share a sample of the file? Also, can you post a screenshot of your audio config?
Luke 42242 Posted September 3, 2016 Posted September 3, 2016 Does your audio equipment support that format?
Notfast 7 Posted September 3, 2016 Author Posted September 3, 2016 Okay. Weird things. A couple rebooting later, and same settings as normally used plays AC3 again. When wasapi didn't work I had no audio in menu's. I haven't changed a thing in Windows sound panel (only confirmed settings) and changed Emby back to wasapi and playing video between rebooting.
Guest asrequested Posted September 3, 2016 Posted September 3, 2016 (edited) Okay. Weird things. A couple rebooting later, and same settings as normally used plays AC3 again. When wasapi didn't work I had no audio in menu's. I haven't changed a thing in Windows sound panel (only confirmed settings) and changed Emby back to wasapi and playing video between rebooting. It might be a device recognition glitch. If you're using WASAPI set the device to your receiver. Edited September 3, 2016 by Doofus
