SangheiliDragon 0 Posted September 2, 2016 Posted September 2, 2016 (edited) Hey all, New to Emby, having a minor bug. Audio when streamed to clients, have been using Kodi 16.01 (tested on 2 devices)(Kodi Emby plugin installed), Chromecast 1st Gen (FW ver. 1.20.66189), and a Samsung Smart TV Series 6 (DLNA), all have very low audio. I would say roughly half volume compared to when they are played via a shared network drive or via direct hard drive connect. (not using Emby). Emby server version 3.0.6400.0 running on MS Windows 10 build 10.0.14393 any help would be greatly appreciated Regards Jayden Edited September 2, 2016 by SangheiliDragon
Solution Luke 42208 Posted September 2, 2016 Solution Posted September 2, 2016 Hi, welcome. if the audio is transcoding, then you can configure the audio boost when downmixing in the server dashboard under Playback -> transcoding. If the audio is not transcoding then it is out of Emby's control and is up the device you're playing on. In that case you'll just want to turn up the volume. Let us know how it goes. Thanks. 1
SangheiliDragon 0 Posted September 4, 2016 Author Posted September 4, 2016 Hey Luke, Thanks for the help. The audio boost when down mixing was set to 2. setting it to 1 corrected this and fixed the audio problem. At least from what i can tell it has. Thanks Jayden
caic 0 Posted April 5, 2017 Posted April 5, 2017 Hello, Same problem here with Emby 3.2.10.0 and it was solved setting audio boost to 1. Thank you!
Francinildo Gomes da Silva 0 Posted September 23, 2020 Posted September 23, 2020 Olá bom dia, Estou com problemas de áudio em português, tem como ajudar?
Luke 42208 Posted September 25, 2020 Posted September 25, 2020 On 9/23/2020 at 8:13 AM, Francinildo Gomes da Silva said: Olá bom dia, Estou com problemas de áudio em português, tem como ajudar? Olá, qual é o problema que você está tendo?
Francinildo Gomes da Silva 0 Posted September 25, 2020 Posted September 25, 2020 (edited) Ola bom dia. Já resolvido o problema, foi um erro de configuração dos usuários, que eu tinha desativa a " Permitir reprodução de áudio que necessita de transcodificação" com isso os arquivos de AC3 não conseguia se reproduzir pelo chorme. Ativei de volta e resolveu o problem. Abrigado pela atenção. Edited September 25, 2020 by Francinildo Gomes da Silva
Luke 42208 Posted October 10, 2020 Posted October 10, 2020 On 9/25/2020 at 10:19 AM, Francinildo Gomes da Silva said: Ola bom dia. Já resolvido o problema, foi um erro de configuração dos usuários, que eu tinha desativa a " Permitir reprodução de áudio que necessita de transcodificação" com isso os arquivos de AC3 não conseguia se reproduzir pelo chorme. Ativei de volta e resolveu o problem. Abrigado pela atenção. Obrigado pelo feedback.
