icthusman1 23 Posted August 31, 2016 Posted August 31, 2016 I am trying to edit Metadata through the Metadata Manager. When using MS Edge I just get a spinny wheel when I save changes. Works just fine in Opera. Any thoughts anyone?
Solution Luke 42186 Posted August 31, 2016 Solution Posted August 31, 2016 Hi, just tested, no problem found here, but will try additional scenarios. 1
icthusman1 23 Posted August 31, 2016 Author Posted August 31, 2016 Well bugger. Now it works just fine. Same Edge window but I have been jumping accounts inside it for testing Emby from my sons account. Looks like there might be an occasional issue but it could very well be on the end of Edge not you. Thanks @@Luke for the quick follow up.
