AFFASocial 6 Posted August 30, 2016 Posted August 30, 2016 (edited) I have Re-installed Emby server 2 times now fresh . I am running Windows 7 Ultimate,,, was running Windows 7 Enterprise is it possible i have turned off a service that controls real time monitoring???? it use to work and all my drives have the check on real time monitoing in emby.. or maybe a drive feature setting, I have 4 drives and again I would just drop the file/folder where it belongs and it would update automatically .... ANY Suggestions ??? also the drives have Indexing checked on the explorer Edited August 30, 2016 by cnjnorton
Happy2Play 9800 Posted August 30, 2016 Posted August 30, 2016 Have you went to Dashboard-Library and clicked on each Library? Updated in 6.0.6200.0 •Move realtime monitor setting from global to per-library
AFFASocial 6 Posted September 14, 2016 Author Posted September 14, 2016 thank you for the reply after another update its all working again
