ebr 16332 Posted March 23, 2020 Posted March 23, 2020 Hola, después de adquirir la membrisa me ha llegado el código, lo he puesto en el server pero ahora la app en Nvidia Shield no reconoce el premiere! Veo que hay más de uno con este problema. Alguna ayuda? Hi. You need to be sure that the Shield can get out to our servers to validate as well. What, exactly is happening when you try to use that app?
Javiemitv1 0 Posted May 9, 2025 Posted May 9, 2025 Hola que tal quisiera información para comprar y activar el servicio en el panel
seanbuff 1356 Posted May 9, 2025 Posted May 9, 2025 9 minutes ago, Javiemitv1 said: Hello, how are you? I would like information on how to purchase and activate the service on the panel. Hi, this would be a good place for you to start: Quick Start If you believe Emby is the right software solution for you, then please see: https://emby.media/premiere.html -- playing close attention to the red text at the top of that page.
