heerssimpson 3 Posted August 29, 2016 Posted August 29, 2016 I have these dvds and I am creating mkv files for them: http://creativeworks.byu.edu/catalog/ViewItem.aspx?item=KB250 I am wondering what is the best way to save the file structure, and how to name each file, so that when I add it to the Emby TV library it can read what I input. I anticipate there is no metadata out there for this show. Any help would be appreciated.
Solution bluemonkey07 590 Posted August 29, 2016 Solution Posted August 29, 2016 I think the usual advise for exercise videos is to add then as a "home videos" library so that they will not attempt to be identified online and you can add your own metadata 1
heerssimpson 3 Posted August 29, 2016 Author Posted August 29, 2016 I think the usual advise for exercise videos is to add then as a "home videos" library so that they will not attempt to be identified online and you can add your own metadata Got it, thanks.
Luke 42186 Posted August 29, 2016 Posted August 29, 2016 You can also just use a regular tv library and then lock the metadata.
