McSatan 0 Posted August 29, 2016 Posted August 29, 2016 I couldn't find another post on this Via search for this new update. 3.0.6300.0 Just wondering what happened to the start in full screen in the profile setup ? or am I just missing something? did it move .. I haven't found it if it did even after a while looking for it ... Really annoying having to fullcreen every episode . Any chance of it comming back ? It even doesn't stay full screen on windows app...super annoying. Thanks for a great program this far .
Luke 42186 Posted August 29, 2016 Posted August 29, 2016 Start in full screen? What app are you referring to?
McSatan 0 Posted August 29, 2016 Author Posted August 29, 2016 (edited) it used to be in settings for the account, I believe in playback or display . not too sure now , had it set a forgot about it ...kind of thing last week it was going well... everything was full screen, now its not .it has to be manually put in full screen and the app that I was referring to was the win 10 app... I've found that if you try everything once, you find what works best .. I don't use it much now , as chrome seems to play better VIA browser Edited August 29, 2016 by McSatan
McSatan 0 Posted August 31, 2016 Author Posted August 31, 2016 ok - I think i finnaly figured out what the hell is wrong with me , not with Emby ..I was using the Emby app for Win 10, and it was play in full screen, and went to full screen automatiacly when the next episode started ... the update happened and it wasn't doing that anymore, as, it was what i was using in my bedroom to watch mindless shows as i fell asleep. I updated to the beta, and it works again as it did before. I use Chrome for movies .. and so I never noticed that it never went to full screen on next episode. So ... in summary , I was crazy... Now for a suggestion , is there anyway there could be (for) browsers setting, to make next episode full screen on auto? or just open full screen in auto as video was loaded ? as I do find that there is a lot less hic-ups when using Chrome.. and would like to move away from the app. I'm sure others feel this pain also . or is there a setting that I'm missing somewhere ?
7illusions 1249 Posted August 31, 2016 Posted August 31, 2016 I'm not sure I understand the issue, and I don't recognize the behavior of full screen for the app. Can you provide a screenshot of the app that you use?
